Action Behaviors
Contents List
  • Animation Action Behaviors
  • Control Action Behaviors
  • Custom
  • Gesture Action Behaviors
  • Property Action Behaviors
  • Scroll Action Behaviors
  • Streaming Action Behaviors
  • Transition Action Behaviors
  • Set Culture
    Configure and Play Animation
    Class Reference
    Common Properties
    Animation Candera::Animation::AnimationPlayer The animation that should be controlled.
    Action CgiStudioControl::AnimationAction::Enum Action that shall be executed on the animation:
    Start, Stop, Pause, Resume, Speedup, Finish, Change.
    Direction CgiStudioControl::AnimationDirection::Enum Playback direction of the animation.
    Speed FeatStd::Float Playback speed of the animation.
    Advanced Properties
    RepeatMode CgiStudioControl::RepeatMode::Enum Defines how the animation shall be repeated.
    RepeatCount CgiStudioControl::RepeatCount::Enum Count of replays. If set to 0 the animation loops till it gets stopped.
    EventDispatchStrategy CgiStudioControl::EventDispatchStrategyType::Enum The way the event gets sent.
    DedicatedBehavior Candera::Behavior* A dedicated behavior that will receive the animation event.
    FinishTime Candera::Animation::WorldTimeType Finish time in milliseconds.
    IncreasedSpeed FeatStd::Float Increased playback speed of the animation. If set and Play is executed again during playback, animation will speed up (can be used only once per animation!). Zero means immediate position seek.
    IncreasedSpeedRevertMargin Candera::Animation::WorldTimeType Defines trailing part of animation (in milliseconds) that will be played at normal speed again. If not set, speedup will last until the end of animation.
    SequenceStartTime Candera::Animation::SequenceTimeType The start point of the animation. [ms]
    SequenceDurationTime Candera::Animation::SequenceTimeType The duration of the animation. [ms]
    Back to the menu
    Breadcrumb Action
    Class Reference
    An Action Behavior that sends breadcrumb action events. It allows you to control a Breadcrumb or a node with a Breadcrumb Behavior attached.
    • SetPath - sets elements contained in the breadcrumb.
    • BackToPrevious - calls breadcrumb to create a path without the last element from the ones existing in the breadcrumb.
    • BackToElement - the action will be called if the element exists in the breadcrumb. It will create a path from beginning to the selected element from the breadcrumb.
    Common Properties
    Action CgiStudioControl::AnimationAction::Enum Action that shall be executed on the animation.
    Path CgiStudioControl::AnimationDirection::Enum The Path that will be set when the action is triggered. Only available for 'Set Path'. The path-separator is defined in the receiving breadcrumb.
    BreadcrumbNode Candera::AbstractNodePointer Breadcrumb Control Node.
    Back to the menu
    Change selection
    Class Reference
    Checks if the culture has changed and is fulfilled if this culture matches the locale.
    Common Properties
    Back to the menu
    Conditional Action
    Class Reference</small
    Common Properties
    Actions Candera::ActionBehaviorArrayProperty The set of ActionBehaviors that TriggerBehavior invokes in the even that it receives a positive response from Condition.
    Postpone bool Set this flag to true to perform the actions after all other actions have been performed. This may become nessecary if the actions alter the state and other conditional actions may be invoked due to that changed state.
    Back to the menu
    Change Drawer State
    Class Reference
    An Action that allows to hide/show the contents of a Drawer or a Node with a Drawer Behavior attached.
    Common Properties
    Action CgiStudioControl::DrawerEventType::Enum The action that should be performed.
    Advanced Properties
    DedicatedBehavior Candera::Behavior* A dedicated behavior that will receive the event. Only available when Dispatch Strategy is set to 'DedicatedBehavior'.
    Back to the menu
    Set Focus
    Sets the Keyboard Focus to a control.
    Common Properties
    TargetNode Candera::AbstractNodePointer The Node which is modified. If not set, then the node where the bihaviors is attached to, will be modified.
    Back to the menu
    Interpolate Value Action
    Action Behavior which sends specific action event allows you control the InterpolateProcessValueBehavior.
    Action ActionTYpe The Node which gets the given text. If not set, then the node where the behavior is attached to, will be modified.
    AnimationMode AnimationModeType The Style that will be set to the Text Node.
    TargetNode TargetNodeType The Node to which the event should be sent.
    Back to the menu
    Interval Switch Action
    TargetNode TargetNodeType The Node which is mofified. If not set, then the node where the behavior is attached to, will be modified.
    SwitchState SwitchStateType SwitchState: IntervalSwitchState: Enum
    Back to the menu
    Keyboard Action
    Keyboard action to manage keyboard control.
    Action ActionType Keyboard action to execute.
    KeyboardNode KeyboardNodeType Keyboard Node.
    Layout LayoutType Layout name.
    AutoHideKeyboard AutoHideKeyboardType Should keyboard be hidden when node loses focus and show again when node is focused?
    Back to the menu
    Map Action
    MapNode MapNodeType Map node on which this action should be called.
    Action ActionType Action that will be called on the MapBehavior.
    Latitude LatitudeType GPS latitude at which the camera looks at.
    Longitude LongitudeType GPS longitude at which the camera looks at.
    Zoomlevel ZoomLevelType Determines how close is the camera to the groud level.
    Bearing BearingType Determines the bearing angle at which the camera is rotated relative to north.
    Tilt TiltType Determines the tilt angle at which the camera looks at specified location.
    SyleUrl StyleUrlType Theme that describes how the map looks like and how is styled.
    Back to the menu
    Map Location Action
    TargetNode TargetNodeType Map node on which this action should be called.
    Latitude LatitudeType Latitude of the location.
    LongitudeLayout LongitudeType Longitude of the location.
    Address AddressType Address of the location (usually street name).
    Back to the menu
    Navigation Action
    Actoin ActionType Action that will be called on the MapNode.
    Back to the menu
    MenuScreenAction
    Action Behavior which sends menuscreen action event allows you control the menu screen. The operations it can do are: add, dlete element and change screen page.
    Common Properties
    Action MenuScreenAction::Enum Action that will be called on the menu screen.
    Back to the menu
    Page Indicator Action
    Class Reference
    It is also used by PageIndicatorElement (ActivateDot) to activate clicked element and to define visual properties of the PageIndicatorElement.
    Common Properties
    Action PageIndicatorAction::Enum Action to perform on PageIndicator (change number of pages, change active index)
    PageIndicatorNode Candera::AbstractNodePointer PageIndicator node to communicate with.
    Value FeatStd::Int32 Value to be sent to PageIndicator (for ChangeActiveIndex and ChangeNumberOfPages actions)
    ChangeValue ChangeValue::Enum Type of value change to be sent to PageIndicator (for ChangeActiveIndex and ChangeNumberOfPages actions)
    RenderNode Candera::AbstractNodePointer Render node for current PageIndicatorElement.
    NormalImagePropertyProvider Behavior* Property Behavior which contains the image of normal (unselected) PageIndicatorElement.
    ActiveImagePropertyProvider Behavior* Property Behavior which contains the image of active (selected) PageIndicatorElement.
    Back to the menu
    Set Control State
    Class Reference
    Supports
    Used In
    Example Usage
    Common Properties
    State Candera::AbstractNodePointer Choose the State which has to be changed to True or False.
    ChangeTo bool Switch the state of the control to True or False.
    EventDispatchStrategy Candera::AbstractNodePointer The way the event gets sent
    Advanced Properties
    See also
    Set Image, Set Text, Set Color
    Back to the menu
    Start Timer
    Class Reference
    Used In
    Example Usage
    Common Properties
    Delay FeatStd::UInt32 Delay time for the timer event (specification in milliseconds)
    See also
    Check Timer, OnTimer
    Back to the menu
    Custom
    • Click To Message
    • Copy Texture
    Click to Message
    Common Properties
    Back to the menu
    Copy Texture
    When triggered, the texutures of an appearance are used on the appearance of the node. SAMPLE USAGE ONLY.
    Appearance AppearanceType The appearance to set on the node
    TargetNode TargetNodeType The node which gets the given image. If not set,then the node where the behavior is attached to, will be modified.
    Back to the menu
    Transform Gesture Action
    Use the transform gesture action to apply the transformation of a transform gesture event (pan, pinch and rotate) to a node. You can use tis behavior as an action or directly without an event handler.
    Pan
    • Use the Maximum/Minimum properties for X/Y to limit the movement of the position to a certain area.
    • Use the Pan mode selector to limit the transformation to X or Y axis.
    • Deactivate the Pan to disallow any position change.
    Pinch
    • Use the Maximum/Minimum properties to limit the absolute scale of the node.
    • Use the Pinch mode selector to either limit the scaling to X or Y axis or to switch to non-uniform scaling where both axis are scaled individually.
    • Deactivate the Pinch to disallow any scale change.
    Rotate
    • Use the Pinch mode selector to either limit the scaling to X or Y axis or to switch to none uniform scaling where both axis are scaled individually.
    Example Usage
    Common Properties
    TargetNode Candera::AbstractNodePointer The Node which is manipulated. If not set, then the node where the behavior is attached to, will will be manipulated
    Pan FeatStd::Optional<PanGestureType::Enum> The pan transformation of a pan gesture is applied to the node.
    PanMinimumX FeatStd::Optional<FeatStd::Float> The minimum pan X value.
    PanMinimumY FeatStd::Optional<FeatStd::Float> The minimum pan Y value.
    PanMaximumY FeatStd::Optional<FeatStd::Float> The maximum pan X value.
    PanMaximumX FeatStd::Optional<FeatStd::Float> The maximum pan Y value.
    Pinch FeatStd::Optional<PinchGestureType::Enum> The scale transformation of a pinch gesture is applied to the node.
    PinchMinimumX FeatStd::Optional<FeatStd::Float> The minimum pinch X value.
    PinchMinimumY FeatStd::Optional<FeatStd::Float> The minimum pinch Y value.
    PinchMaximumX FeatStd::Optional<FeatStd::Float> The maximum pinch X value.
    PinchMaximumY FeatStd::Optional<FeatStd::Float> The maximum pinch Y value.
    PinchMinimumUniform FeatStd::Optional<FeatStd::Float> The minimum pinch uniform value.
    PinchMaximumUniform FeatStd::Optional<FeatStd::Float> The maximum pinch uniform value.
    Rotate bool The rotate transformation of a rotate gesture is applied to the node.
    RotateMinimum FeatStd::Optional<FeatStd::Float> The minimum rotate value
    RotateMaximum FeatStd::Optional<FeatStd::Float> The maximum rotate value
    Back to the menu
    • Set Appearance
    • Send Value as Event
    • Set Appearance
    • Set Color
    • Set Image
    • Render Child Nodes Action
    • Set Text
    • Set Text Style
    • Enable Rendering
    Set Appearance
    Class Reference
    Common Properties
    PropertyReference CgiStudioControl::PropertyReference The appearance to set on the node.
    Appearance Candera::MemoryManagement::SharedPointer<Candera::Appearance>" The color to set.
    PropertyProvider Behavior* Property Behavior which contains the color which has to be set on the effect.
    Back to the menu
    Send Value as Event
    Class Reference
    Example Usage
    Common Properties
    Value Variant The value of the event which gets sent.
    Change Value Enum (Absolute, Relative) How the event value shall be handled by the receiving.
    Event Dispatch Strategy Enum (Direct, Broadcast, Bubble, Tunnel, DedicatedBehavior) The way the event gets sent.
    Dedicated Behavior ProcessValueBehavior *
    Target Node AbstractNodePointer The target node which the events are routed from the source node. If this property is not set, the event will be routed to the node of the behavior.
    DedicatedBehavior Candera::ProcessValueBehavior* The dedicated process value behavior that will receive the change value event.
    Advanced Properties
    PropertyProvider "Behavior* Property provider which contains the value which has to be set on the send value as event action.
    Back to the menu
    Set Appearance
    Class Reference
    Common Properties
    Back to the menu
    Set Color
    Class Reference
    See also
    Set Image, Set Text, Set Control State
    Sets the color of a node with a Color effect attached (e.g. BitmapBrushColorBlend or SolidColorBrush).
    Supports
    • Controls:
      • Text
      • Text Value
    • Effects:
      • BitmapBrushColorBlend (as used in TextNode)
      • GlBitmapBrushColorMaskBlend
      • GlDropShadowBitmapBrushColorBlend
      • GlFlipBitmapBrushColorBlend
      • GlOutlineBitmapBrushColorBlend
      • SolidColorBrushColorBlend (as used in SolidColorNode)
    Example Usage
    Common Properties
    Property Reference Enum (Self, Other) Choose how the property gets set. Via own property or from another Behavior.
    Color Color The color to set.
    Use For Child Nodes Bool If set to true, also child nodes are affected by this action.
    Levels UInt8 Number of levels to step down through groups. Default is zero.
    Target Node Node2D * The node which is modified. If not set, then the node where the behavior is attached too, will be modified.
    Advanced Properties
    Property Provider Behavior * Property Provider which contains the color which has to be set on the effect.
    Back to the menu
    Set Image
    Class Reference
    See also
    Set Text, Set Color, Set Control State
    When triggered, sets an image on a node.
    Example Usage
    Common Properties
    Image SharedPointer<Image2D> The image to set on the effect.
    Use As Default Bool True if the image shall be used as default image.
    Target Node AbstractNodePointer The node which gets the given image. If not set, then the node where the behavior is attached too, will be modified.
    Advanced Properties
    Texture Candera::MemoryManagement::SharedPointer<Candera::TextureImage> The image to set on the appearance.
    Back to the menu
    Class Reference
    If invoked by a TriggerBehavior, enables/disables Child nodes corresponding to the received value and the behavior settings.
    Example Usage
    Common Properties
    Index Float Index of the child node which shall be active.
    Operation Mode Enum (MultipleNodes, SingleNode) When set to MultipleNodes, EnableChildNodes will enable the first N children of Group Node. When Operation Mode is set to SingleNode, only the Nth node is enabled.
    Normalize Value Bool If set to true, the received value has to be between 0 and 1 and will be mapped to the number of children. Otherwise the value has to be the index of the child.
    Target Node Node 2D* The node which switches child nodes. If not set, then the node where the behavior is attached to, will modified its children.
    Back to the menu
    Set Text
    Class Reference
    See also
    Set Image, Set Color, Set Control State
    Example Usage
    Common Properties
    Text String The text that will be set to the Text Node.
    Target Node AbstractNodePointer The Node which gets the given text. If not set, then the node where the behavior is attached to, will be modified.
    Advanced Properties
    Property Provider Behavior * Property Behavior which contains the color which has to be set on the effect.
    Back to the menu
    Set Text Style
    An Action Behavior that sends change style action. It allows to control the style of text Nodes.
    Common Properties
    Target Node TargetNodeType The Node which gets the given text. If not set, then the node where the behavior is attached to, will be modified.
    Style StyleType The Style that will be set to the Text Node.
    Back to the menu
    Enable Rendering
    Class Reference
    Example Usage
    Common Properties
    Visible Bool According to this value, the affected node gets rendered or not.
    Target Node AbstractNodePointer The node which gets the visibility flag. If not set, then the node where the behavior is attached to, will be modified.
    Back to the menu
    Send Scrollable Event
    Enables scrolling a scrollable behavior (e.g. a ListBehavior) to a specific target position that is specified by the scrolling Type and the Value.
    Common Properties
    Direction ScrollDirection::Enum The direction in which the scroll should be performed.
    Type ScrollableEventType::Enum The scrolling type. It can be either relative or absolute scrolling in combination of being either itemwise or pagewise scrolling.
    Value FeatStd::Float The number of items or pages scrolled to.
    Animated Bool If set, the scrolling will be animated. Otherwise, the scrollable behavior will imediatelly jump to the target position.
    Back to the menu
    Configure and Play Stream
    Class Reference
    Common Properties
    Action VideoControl::Enum The action that will be executed on the stream. Options are Play, Replay, Pause, Resume, Stop.
    EventDispatchStrategy CgiStudioControl::EventDispatchStrategyType::Enum The strategy in which the event is sent. Options are Direct, Broadcast, Bubble, Tunnel, DedicatedBehavior.
    TargetNode Candera::AbstractNodePointer The node which receives the event. If not set, then the node where the behavior is attached to, will receive it.
    DedicatedBehavior Candera::Behavior* A dedicated behavior that will receive the event, in case DedicatedBehavior EventDispatchStrategy is selected.
    Back to the menu
    • Perform Transition Requests
    • Transition Request
    Class Reference
    See also
    Transition Request
    Example Usage
    Common Properties
    Requests ArrayProperty<TransitionRequestBehavior *> The first TransitionRequestBehavior in the request-set.
    Variant String Default Variant which will be used for attached Requests. Not that Requests can also have their own Variant.
    Back to the menu
    Transition Request
    Class Reference
    Example Usage
    Common Properties
    RequestType CgiStudioControl::TransitionRequestType::Enum Whether a node should be Activated or Deactivated by the transition. Currently running transitions on a node can be ended using the Finish transition type.
    Variant FeatStd::String Variant which will be used for this Request.
    Identifier Candera::Transitions::Identifier The Node or Scene that will be subject to the transition.
    Back to the menu
    Set Culture
    Class Reference
    Action Behavior which activates a culture based on its 'locale' value.
    Common Properties
    Locale FeatStd::String Locale of a culture. Invoking the action will set the culture active.
    Back to the menu
