Action Behaviors
Contents List
- Animation Action Behaviors
- Control Action Behaviors
- Custom
- Gesture Action Behaviors
- Property Action Behaviors
- Scroll Action Behaviors
- Streaming Action Behaviors
- Transition Action Behaviors
Class Reference
Common Properties
| Property Name |
Type |
Description |
| Animation |
Candera::Animation::AnimationPlayer |
The animation that should be controlled. |
| Action |
CgiStudioControl::AnimationAction::Enum |
Action that shall be executed on the animation: Start, Stop, Pause, Resume, Speedup, Finish, Change. |
| Direction |
CgiStudioControl::AnimationDirection::Enum |
Playback direction of the animation. |
| Speed |
FeatStd::Float |
Playback speed of the animation. |
Advanced Properties
| Property Name |
Type |
Description |
| RepeatMode |
CgiStudioControl::RepeatMode::Enum |
Defines how the animation shall be repeated. |
| RepeatCount |
CgiStudioControl::RepeatCount::Enum |
Count of replays. If set to 0 the animation loops till it gets stopped. |
| EventDispatchStrategy |
CgiStudioControl::EventDispatchStrategyType::Enum |
The way the event gets sent. |
| DedicatedBehavior |
Candera::Behavior* |
A dedicated behavior that will receive the animation event. |
| FinishTime |
Candera::Animation::WorldTimeType |
Finish time in milliseconds. |
| IncreasedSpeed |
FeatStd::Float |
Increased playback speed of the animation. If set and Play is executed again during playback, animation will speed up (can be used only once per animation!). Zero means immediate position seek. |
| IncreasedSpeedRevertMargin |
Defines trailing part of animation (in milliseconds) that will be played at normal speed again. If not set, speedup will last until the end of animation. |
| SequenceStartTime |
Candera::Animation::SequenceTimeType |
The start point of the animation. [ms] |
| SequenceDurationTime |
The duration of the animation. [ms] |
Breadcrumb Action
Class Reference
An Action Behavior that sends breadcrumb action events. It allows you to control a Breadcrumb or a node with a Breadcrumb Behavior attached.
SetPath - sets elements contained in the breadcrumb.
BackToPrevious - calls breadcrumb to create a path without the last element from the ones existing in the breadcrumb.
BackToElement - the action will be called if the element exists in the breadcrumb. It will create a path from beginning to the selected element from the breadcrumb.
Common Properties
Property Name
Type
Action
Action that shall be executed on the animation.
Path
The Path that will be set when the action is triggered. Only available for 'Set Path'. The path-separator is defined in the receiving breadcrumb.
BreadcrumbNode
Candera::AbstractNodePointer
Breadcrumb Control Node.
Change selection
Class Reference
Checks if the culture has changed and is fulfilled if this culture matches the locale.
Common Properties
Conditional Action
Class Reference</small
Common Properties
Property Name
Type
Condition
Candera::ConditionBehavior*
The ConditionBehavior that TriggerBehavior passes a value to and expect a response from to see if Action needs to be invoked.
Actions
Candera::ActionBehaviorArrayProperty
The set of ActionBehaviors that TriggerBehavior invokes in the even that it receives a positive response from Condition.
Postpone
bool
Set this flag to true to perform the actions after all other actions have been performed. This may become nessecary if the actions alter the state and other conditional actions may be invoked due to that changed state.
Change Drawer State
Class Reference
An Action that allows to hide/show the contents of a Drawer or a Node with a Drawer Behavior attached.
Common Properties
Property Name
Type
Action
CgiStudioControl::DrawerEventType::Enum
The action that should be performed.
TargetNode
The target node to which the events are routed from the source node. If the property is not set, the event will be routed to the node of the behavior
Advanced Properties
Property Name
Type
DedicatedBehavior
Candera::Behavior*
A dedicated behavior that will receive the event. Only available when Dispatch Strategy is set to 'DedicatedBehavior'.
Set Focus
Sets the Keyboard Focus to a control.
Common Properties
Property Name
Type
TargetNode
The Node which is modified. If not set, then the node where the bihaviors is attached to, will be modified.
Interpolate Value Action
Action Behavior which sends specific action event allows you control the InterpolateProcessValueBehavior.
Property Name
Type
Action
ActionTYpe
The Node which gets the given text. If not set, then the node where the behavior is attached to, will be modified.
AnimationMode
AnimationModeType
TargetNode
TargetNodeType
The Node to which the event should be sent.
Interval Switch Action
Property Name
Type
TargetNode
TargetNodeType
The Node which is mofified. If not set, then the node where the behavior is attached to, will be modified.
SwitchState
SwitchStateType
SwitchState: IntervalSwitchState: Enum
Keyboard Action
Keyboard action to manage keyboard control.
Property Name
Type
Action
ActionType
Keyboard action to execute.
KeyboardNode
KeyboardNodeType
Keyboard Node.
Layout
LayoutType
Layout name.
AutoHideKeyboard
AutoHideKeyboardType
Should keyboard be hidden when node loses focus and show again when node is focused?
Map Action
Property Name
Type
MapNode
MapNodeType
Map node on which this action should be called.
Action
ActionType
Action that will be called on the MapBehavior.
Latitude
LatitudeType
GPS latitude at which the camera looks at.
Longitude
LongitudeType
GPS longitude at which the camera looks at.
Zoomlevel
ZoomLevelType
Determines how close is the camera to the groud level.
Bearing
BearingType
Determines the bearing angle at which the camera is rotated relative to north.
Tilt
TiltType
Determines the tilt angle at which the camera looks at specified location.
SyleUrl
StyleUrlType
Theme that describes how the map looks like and how is styled.
Map Location Action
Property Name
Type
TargetNode
TargetNodeType
Latitude
LatitudeType
Latitude of the location.
LongitudeLayout
LongitudeType
Longitude of the location.
Address
AddressType
Address of the location (usually street name).
Navigation Action
Property Name
Type
MapNode
MapNodeType
Actoin
ActionType
Action that will be called on the MapNode.
Action Behavior which sends menuscreen action event allows you control the menu screen. The operations it can do are: add, dlete element and change screen page.
Common Properties
Property Name
Type
Action
MenuScreenAction::Enum
Action that will be called on the menu screen.
MenuItemNode
Needed to identify which node should be deleted.
MenuScreenNode
MenuScreen node to which event will be sent.
Page Indicator Action
Class Reference
It is also used by PageIndicatorElement (ActivateDot) to activate clicked element and to define visual properties of the PageIndicatorElement.
Common Properties
Property Name
Type
Action
PageIndicatorAction::Enum
Action to perform on PageIndicator (change number of pages, change active index)
PageIndicatorNode
PageIndicator node to communicate with.
Value
FeatStd::Int32
Value to be sent to PageIndicator (for ChangeActiveIndex and ChangeNumberOfPages actions)
ChangeValue
ChangeValue::Enum
Type of value change to be sent to PageIndicator (for ChangeActiveIndex and ChangeNumberOfPages actions)
Property Name
Type
RenderNode
Render node for current PageIndicatorElement.
NormalImagePropertyProvider
Behavior*
Property Behavior which contains the image of normal (unselected) PageIndicatorElement.
ActiveImagePropertyProvider
Behavior*
Property Behavior which contains the image of active (selected) PageIndicatorElement.
Set Control State
Class Reference
Supports
Any Node with a Handle Control State attached.
Used In
Example Usage
Common Properties
Property Name
Type
State
Choose the State which has to be changed to True or False.
ChangeTo
bool
Switch the state of the control to True or False.
TargetNode
Advanced Properties
Property Name
Type
DedicatedBehavior
Candera::Behavior*
See also
Set Image, Set Text, Set Color
Start Timer
Class Reference
Used In
Example Usage
Common Properties
Property Name
Type
Delay
FeatStd::UInt32
Delay time for the timer event (specification in milliseconds)
Target Node
See also
Check Timer, OnTimer
Custom
Click To Message
Copy Texture
Click to Message
Common Properties
Copy Texture
When triggered, the texutures of an appearance are used on the appearance of the node. SAMPLE USAGE ONLY.
Property Name
Type
Appearance
AppearanceType
The appearance to set on the node
TargetNode
TargetNodeType
The node which gets the given image. If not set,then the node where the behavior is attached to, will be modified.
Use the transform gesture action to apply the transformation of a transform gesture event (pan, pinch and rotate) to a node. You can use tis behavior as an action or directly without an event handler.
Pan
Use the Maximum/Minimum properties for X/Y to limit the movement of the position to a certain area.
Use the Pan mode selector to limit the transformation to X or Y axis.
Deactivate the Pan to disallow any position change.
Pinch
Use the Maximum/Minimum properties to limit the absolute scale of the node.
Use the Pinch mode selector to either limit the scaling to X or Y axis or to switch to non-uniform scaling where both axis are scaled individually.
Deactivate the Pinch to disallow any scale change.
Rotate
Use the Pinch mode selector to either limit the scaling to X or Y axis or to switch to none uniform scaling where both axis are scaled individually.
Example Usage
Common Properties
Property Name
Type
TargetNode
The Node which is manipulated. If not set, then the node where the behavior is attached to, will will be manipulated
Pan
FeatStd::Optional<PanGestureType::Enum>
The pan transformation of a pan gesture is applied to the node.
PanMinimumX
FeatStd::Optional<FeatStd::Float>
The minimum pan X value.
PanMinimumY
The minimum pan Y value.
PanMaximumY
The maximum pan X value.
PanMaximumX
The maximum pan Y value.
Pinch
FeatStd::Optional<PinchGestureType::Enum>
The scale transformation of a pinch gesture is applied to the node.
PinchMinimumX
The minimum pinch X value.
PinchMinimumY
The minimum pinch Y value.
PinchMaximumX
The maximum pinch X value.
PinchMaximumY
The maximum pinch Y value.
PinchMinimumUniform
The minimum pinch uniform value.
PinchMaximumUniform
The maximum pinch uniform value.
Rotate
bool
The rotate transformation of a rotate gesture is applied to the node.
RotateMinimum
The minimum rotate value
RotateMaximum
The maximum rotate value
Set Appearance
Send Value as Event
Set Appearance
Set Color
Set Image
Render Child Nodes Action
Set Text
Set Text Style
Enable Rendering
Set Appearance
Class Reference
Common Properties
Property Name
Type
PropertyReference
CgiStudioControl::PropertyReference
The appearance to set on the node.
Appearance
Candera::MemoryManagement::SharedPointer<Candera::Appearance>"
The color to set.
PropertyProvider
Behavior*
Send Value as Event
Class Reference
Example Usage
Common Properties
Property Name
Type
PropertyReference
CgiStudioControl::PropertyReference::Enum
Value
Variant
The value of the event which gets sent.
Change Value
Enum (Absolute, Relative)
How the event value shall be handled by the receiving.
Event Dispatch Strategy
Enum (Direct, Broadcast, Bubble, Tunnel, DedicatedBehavior)
Dedicated Behavior
ProcessValueBehavior *
Target Node
AbstractNodePointer
The target node which the events are routed from the source node. If this property is not set, the event will be routed to the node of the behavior.
DedicatedBehavior
Candera::ProcessValueBehavior*
Advanced Properties
Property Name
Type
PropertyProvider
"Behavior*
Property provider which contains the value which has to be set on the send value as event action.
DedicatedBehavior
Set Appearance
Class Reference
Common Properties
Property Name
Type
PropertyReference
Appearance
The color to set.
PropertyProvider
Behavior*
Set Color
Class Reference
See also
Set Image, Set Text, Set Control State
Sets the color of a node with a Color effect attached (e.g. BitmapBrushColorBlend or SolidColorBrush).
Supports
Controls:
Text
Text Value
Effects:
BitmapBrushColorBlend (as used in TextNode)
GlBitmapBrushColorMaskBlend
GlDropShadowBitmapBrushColorBlend
GlFlipBitmapBrushColorBlend
GlOutlineBitmapBrushColorBlend
SolidColorBrushColorBlend (as used in SolidColorNode)
Example Usage
Common Properties
Property Name
Type
Property Reference
Enum (Self, Other)
Color
Color
The color to set.
Use For Child Nodes
Bool
If set to true, also child nodes are affected by this action.
Levels
UInt8
Number of levels to step down through groups. Default is zero.
Target Node
Node2D *
The node which is modified. If not set, then the node where the behavior is attached too, will be modified.
Advanced Properties
Property Name
Type
Property Provider
Behavior *
Property Provider which contains the color which has to be set on the effect.
Class Reference
See also
Set Text, Set Color, Set Control State
When triggered, sets an image on a node.
Example Usage
Common Properties
Property Name
Type
Property Reference
Enum (Self, Other)
SharedPointer<Image2D>
Use As Default
Bool
True if the image shall be used as default image.
Target Node
AbstractNodePointer
The node which gets the given image. If not set, then the node where the behavior is attached too, will be modified.
Advanced Properties
Property Name
Type
Property Provider
Behavior *
Texture
Candera::MemoryManagement::SharedPointer<Candera::TextureImage>
Class Reference
If invoked by a TriggerBehavior, enables/disables Child nodes corresponding to the received value and the behavior settings.
Example Usage
Common Properties
Property Name
Type
Index
Float
Index of the child node which shall be active.
Operation Mode
Enum (MultipleNodes, SingleNode)
Levels
UInt8
Normalize Value
Bool
If set to true, the received value has to be between 0 and 1 and will be mapped to the number of children. Otherwise the value has to be the index of the child.
Target Node
Node 2D*
The node which switches child nodes. If not set, then the node where the behavior is attached to, will modified its children.
Set Text
Class Reference
See also
Set Image, Set Color, Set Control State
Example Usage
Common Properties
Property Name
Type
Property Reference
Enum (Self, Other)
Text
String
The text that will be set to the Text Node.
Target Node
AbstractNodePointer
Advanced Properties
Property Name
Type
Property Provider
Behavior *
Set Text Style
An Action Behavior that sends change style action. It allows to control the style of text Nodes.
Common Properties
Property Name
Type
Target Node
TargetNodeType
Style
StyleType
Enable Rendering
Class Reference
Example Usage
Common Properties
Property Name
Type
Visible
Bool
According to this value, the affected node gets rendered or not.
Target Node
AbstractNodePointer
The node which gets the visibility flag. If not set, then the node where the behavior is attached to, will be modified.
Enables scrolling a scrollable behavior (e.g. a ListBehavior) to a specific target position that is specified by the scrolling Type and the Value.
Common Properties
Property Name
Type
Direction
ScrollDirection::Enum
The direction in which the scroll should be performed.
Type
ScrollableEventType::Enum
The scrolling type. It can be either relative or absolute scrolling in combination of being either itemwise or pagewise scrolling.
Value
FeatStd::Float
The number of items or pages scrolled to.
Animated
Bool
If set, the scrolling will be animated. Otherwise, the scrollable behavior will imediatelly jump to the target position.
Class Reference
Common Properties
Property Name
Type
Action
VideoControl::Enum
The action that will be executed on the stream. Options are Play, Replay, Pause, Resume, Stop.
The strategy in which the event is sent. Options are Direct, Broadcast, Bubble, Tunnel, DedicatedBehavior.
TargetNode
The node which receives the event. If not set, then the node where the behavior is attached to, will receive it.
DedicatedBehavior
Candera::Behavior*
A dedicated behavior that will receive the event, in case DedicatedBehavior EventDispatchStrategy is selected.
Perform Transition Requests
Transition Request
Class Reference
See also
Transition Request
Example Usage
Common Properties
Property Name
Type
Requests
ArrayProperty<TransitionRequestBehavior *>
The first TransitionRequestBehavior in the request-set.
Variant
String
Default Variant which will be used for attached Requests. Not that Requests can also have their own Variant.
Transition Request
Class Reference
Example Usage
Common Properties
Property Name
Type
RequestType
CgiStudioControl::TransitionRequestType::Enum
Whether a node should be Activated or Deactivated by the transition. Currently running transitions on a node can be ended using the Finish transition type.
Variant
FeatStd::String
Variant which will be used for this Request.
Identifier
Candera::Transitions::Identifier
The Node or Scene that will be subject to the transition.
Set Culture
Class Reference
Action Behavior which activates a culture based on its 'locale' value.
Common Properties
Property Name
Type
Locale
FeatStd::String
Locale of a culture. Invoking the action will set the culture active.
