Control Center Scripts
Via the Applications & Modules tab it is possible to edit various reference paths for scripts used by Control Center that launch executables, generate codes and assets, and more.
Script Files
  • Run Analyzer Script: Script which will be executed when the action is triggered from the menu
  • Edit Application Project Script: Script which will be executed when the action is triggered from the menu
  • Open CMake Script: Script which will be executed when the action is triggered from the menu
  • Edit Scene Composer Solution Script: Script which will be executed when the action is triggered from the menu
  • Edit Stand-Alone Application Project Script: Script which will be executed when the action is triggered from the menu
  • Run Stand-Alone Application Script: Script which will be executed when the action is triggered from the menu
  • Generate Application Code: Generates the application code based on the courier definitions
  • Generate Target Asset Script: Generates Target asset
  • Generate Simulation Asset Script: Generates Simulation asset
  • Edit Model Definition: Edit Model Definition
  • Edit Application Definition: Edit Application Definition
