Control Center Menu
With the "File" menu you can:
  • open a solution
  • close the current solution
  • save the current solution
  • open recent solutions from a list
  • exit the Control Center
In the "Edit" menu you can undo or redo your changes.
You can also open Visual Studio to edit Application Definition or Data Model Definition (like in Control Center Advanced "Courier" Section)
The "Build" menu lets you build the Panel (like in Build Panel) or the Application (like in Build Application).
Using the "Run" menu you can access editing the Panel (like in Edit Panel) or the Application (like in Edit Application). You can also run the SceneComposer or the Player (like in Control Center Dashboard "Run" Section).
You can also Cleanup temporary SceneComposer data, which deletes AppData.
Through the "Help" menu you can choose to view a Help file, a Tutorial or display Info about the Control Center.
