Python-based Data Binding
The Player Connector Library is a simple library written in python and c++ that provides functionality to start and load scene composer binary assets and interact with a predefined set of data binding items (Variant) through python scripting.
Player Connector Library Package
The main functionality of the library is contained in two files, CanderaAppConnector.py [1] and BindingSourceEnum.py [2]. These files contain three classes.
  • CanderaAppConnector: This is the main class to be used to play assets and interact with them using data binding
  • BindingSourceEnum: A python enum generated by the build pipeline that contains the enum keys to be used when setting and getting data binding items. The keys underlay the nomenclature "SOURCE<sourceIndex>ITEM<itemIndex>". Source - and item index start at one and go to ten, as we currently have ten predefined binding sources and ten items per source.
  • Logger: Logger class that my be used to generate logs with compliant format and logging levels
The sources and types listed above are contained in a file system python package that can be installed with pip.
It is suggested to install the library to a virtual environment and not to the global Python installation. For an exemplary usage refer to the Blood Pressure Sample documentation and source code.
[1]: bin/Player/PlayerConnector/Python/CanderaAppConnector/CanderaAppConnector.py
[2]: bin/Player/PlayerConnector/Python/Generated/BindingSourceEnum.py
Workflow
  1. Constructing the library with the Player Connector Library binary contained in the delivered package (PlayerConnectorLibrary)
  2. Initializing the library with the asset binary
  3. Optionally register data binding callbacks
  4. Continuously calling step to invoke the render loop and internal message delivery
  5. Interact with data bindings. Note that internally, changes to the data bindings are reflected on the view when step is called
  6. Shutdown library and gracefully exit program
Documentation
Constructor
Parameters
  1. BinaryLibraryPath: Absolute or relative path to the Player Connector Library binary
Init
Parameters
  1. AssetPath: Absolute or relative path to the asset binary
Returns The bool value
Step
Parameters None
SetIntValue
Parameters
  1. BindingSourceItem: Enum that specifies the binding source item. Enum is defined in Generated/BindingSourceEnum.py
  2. Value: The integer value
SetBoolValue
Parameters
  2. Value: The bool value
SetStringValue
Parameters
  2. Value: The string
SetFloatValue
Parameters
  2. Value: The float value
GetIntValue
Parameters
Returns The integer value
GetBoolValue
Parameters
GetStringValue
Parameters
Returns The string
GetFloatValue
Parameters
Returns The float value
RegisterCallback
Parameters
  1. CallbackFn: Callable type with two parameters
ShutDown
Parameters None
