Python-based Data Binding
The Python Connector Library is a simple library written in python and c++ that provides functionality to start and load scene composer binary assets and interact with a predefined set of data binding items (Variant) through python scripting.
Python Connector Library Package
The main functionality of the library is contained in two files, CanderaAppConnector.py [1] and BindingSourceEnum.py [2]. These files contain three classes.
  • CanderaAppConnector: This is the main class to be used to play assets and interact with them using data binding
  • BindingSourceEnum: A python enum generated by the build pipeline that contains the enum keys to be used when setting and getting data binding items. The keys underlay the nomenclature "SOURCE<sourceIndex>ITEM<itemIndex>". Source - and item index start at one and go to ten, as we currently have ten predefined binding sources and ten items per source.
  • Logger: Logger class that my be used to generate logs with compliant format and logging levels
The sources and types listed above are contained in a file system python package that can be installed with pip.
Note: It is suggested to install the library to a virtual environment and not to the global python installation. For an exemplary usage refer to the Blood Pressure Sample documentation and source code.
[1]: cgi_studio_player/src/PlayerConnector/Python/CanderaAppConnector/CanderaAppConnector.py
[2]: cgi_studio_player/src/PlayerConnector/Python/Generated/BindingSourceEnum.py
Workflow
The general workflow using the python connector library package consists of:
  1. Constructing the library with the connector library binary contained in the delivered package (PlayerConnectorLibrary)
  2. Initializing the library with the asset binary
  3. Optionally register data binding callbacks
  4. Continuously calling step to invoke the render loop and internal message delivery
  5. Interact with data bindings. Note that internally, changes to the data bindings are reflected on the view when step is called
  6. Shutdown library and gracefully exit program
Documentation
    Constructor Init Step SetIntValue SetBoolValue SetStringValue SetFloatValue GetIntValue GetBoolValue GetStringValue GetFloatValue RegisterCallback ShutDown
    Constructor
    Creates and instance of this class. Expects and absolute or relative path to the player connector binary as parameter.
    Parameters
    1. BinaryLibraryPath: Absolute or relative path to the player connector binary
    Init
    Parameters
    1. AssetPath: Absolute or relative path to the asset binary
    Returns Boolean if operation was successful
    Step
    Parameters None
    SetIntValue
    Parameters
    1. BindingSourceItem: Enum that specifies the binding source item. Enum is defined in Generated/BindingSourceEnum.py
    2. Value: The integer value
    SetBoolValue
    Parameters
    2. Value: The bool value
    SetStringValue
    Parameters
    2. Value: The string
    SetFloatValue
    Parameters
    2. Value: The float value
    GetIntValue
    Parameters
    Returns The integer value
    GetBoolValue
    Parameters
    Returns The bool value
    GetStringValue
    Parameters
    Returns The string
    GetFloatValue
    Parameters
    Returns The float value
    RegisterCallback
    Parameters
    1. CallbackFn: Callable type with two parameters
    ShutDown
    Parameters None
