Python-based Data Binding
WORK IN PROGRESS
The Python Connector Library is a simple library written in python and c++ that provides functionality to start and load scene composer binary assets and interact with a predefined set of data binding items (Variant) through python scripting.
Building
On host, the project can be built, using the new cmake environment and by setting <cgi-studio-root>/cmake/Candera/PlayerConnector as source code location. To build the project, right-click PlayerConnectorDll in Visual Studio and click Build. When the build finished
The library consists of a python class CanderaAppConnector. This class has the methods for getting and setting values to databinding items. Also callbacks can be registered that are invoked when a data binding value has been changed.
  • Constructor
  • Init
  • Step
  • SetIntValue
  • SetBoolValue
  • SetStringValue
  • SetFloatValue
  • GetIntValue
  • GetBoolValue
  • GetStringValue
  • GetFloatValue
  • RegisterCallback
  • ShutDown
Constructor
Creates and instance of this class. Expects and absolute or relative path to the player connector binary as parameter.
Parameters
  1. BinaryPath: Absolute or relative path to the player connector binary
Init
Parameters
  1. AssetPath: Absolute or relative path to the asset binary
Returns Boolean if operation was successful
Step
Parameters None
SetIntValue
Parameters
  1. BindingSourceItem: Enum that specifies the binding source item. Enum is defined in Generated/BindingSourceEnum.py
  2. Value: The integer value
SetBoolValue
Parameters
  2. Value: The bool value
SetStringValue
Parameters
  2. Value: The string
SetFloatValue
Parameters
  2. Value: The float value
GetIntValue
Parameters
Returns The integer value
GetBoolValue
Parameters
Returns The bool value
GetStringValue
Parameters
Returns The string
GetFloatValue
Parameters
Returns The float value
RegisterCallback
Parameters
  1. CallbackFn: Callable type with two parameters
ShutDown
Parameters None
