Python-based Data Binding
WORK IN PROGRESS
The Python Connector Library is a simple library written in python and c++ that provides functionality to start and load scene composer binary assets and interact with a predefined set of data binding items (Variant) through python scripting. It does so, by calling exported methods of a dll binary.
Building
On host, the project can be built, using the new cmake environment and by setting <cgi-studio-root>/cmake/Candera/PlayerConnector as source code location. To build the project, right-click PlayerConnectorDll in Visual Studio and click Build. When the build finished
ReferenceThe commentslibrary consists of a python class CanderaAppConnector. This class has the methods for getting and setting values to databinding items. Also callbacks can be registered that are invoked when a data binding value has been changed.
    Constructor Init Step SetIntValue SetBoolValue SetStringValue SetFloatValue GetIntValue GetBoolValue GetStringValue GetFloatValue RegisterCallback ShutDown
    Constructor
    Creates and instance of this class. Expects and absolute or relative path to the player connector binary as parameter.
    Parameters
      BinaryPath: Absolute or relative path to the player connector binary
      Init
      Parameters
        AssetPath: Absolute or relative path to the asset binary Returns Boolean if operation was successful
        Step
        Parameters None Returns Boolean if operation was successful
        SetIntValue
        Parameters
          BindingSourceItem: Enum that specifies the binding source item. Enum is defined in scriptsGenerated/BindingSourceEnum.py Value: The integer value Returns Boolean if operation was successful
          SetBoolValue
          CopySets a simpliedbool versionvalue to documentationa (includingpredefined comments)databinding source item.
          Parameters
            BindingSourceItem: Enum that specifies the binding source item. Enum is defined in Generated/BindingSourceEnum.py Value: The bool value Returns Boolean if operation was successful
            SetStringValue
            Parameters
              BindingSourceItem: Enum that specifies the binding source item. Enum is defined in Generated/BindingSourceEnum.py Value: The string Returns Boolean if operation was successful
              SetFloatValue
              Parameters
                BindingSourceItem: Enum that specifies the binding source item. Enum is defined in Generated/BindingSourceEnum.py Value: The float value Returns Boolean if operation was successful
                GetIntValue
                Parameters
                  Returns The integer value
                  GetBoolValue
                  Parameters
                    Returns The bool value
                    GetStringValue
                    Parameters
                      Returns The string
                      GetFloatValue
                      Parameters
                        Returns The float value
