XML Definition
Builds are defined in an XML Schema file which is located at “cgi_studio_connector/schema/BuildProject.xsd”. This file can be used to validate xml files and with some editors (e.g. Visual-Studio) and provide code-completion when writing the XML file.
BuildProject-Element
Root Element. Contains list of Root-Paths, global Variables and Builds.
Attributes:
Argument Required Description
version Yes Version of the Build-Project file.
Children:
Argument Occurrence Description
RootPaths 1 List of Root-Paths
Variables 1 List of global Variables. These Variables can be used in any Build.
Builds 1 List of Builds
RootPaths-Element
Defines a list of Root-Paths.
Attributes:
None
Children:
RootPath 0 - * Root-Path
Variables-Element
Defines a list of Variables.
Attributes:
None
Children:
Variable 0 - * Variable
Builds-Element
Defines a list of Builds.
Attributes:
None
Children:
Build 0 - * Build
RootPath-Element
Defines a Root-Path. Root-Paths can be referenced by variables via their key allowing to base them on a common root.
Attributes:
name Yes Name of the Root-Path.
key Yes Key of the Root-Path. This key is used to reference the Root-Path.
description No Description of the argument.
Children:
None
Variable-Element
A variable for the build which will be applied for all executed scripts.
Attributes:
name Yes Name of the variable.
type Yes Type of the variable. Valid values are ‘Value’, ‘Path’ and ‘File’
root_path_key No Key to refence a Root-Path. If set, paths (or files) will be relative to the given Root-Path.
value Yes Value of the variable.
description Yes Description of the variable.
Children:
None
Build-Element
A build which can be executed.
Attributes:
name Yes Name of the build.
description Yes Description of the build.
Children:
ScriptPath 1 Path to the script files which should be executed for this build.
OutputPath 1 Output-Path for this build.
Variable 0 - * Variable for this build
ScriptPath-Element
Path to the script files which are executed when this build is executed. The script files should start with a number to indicate their execution order.
Attributes:
value Yes Relative path.
Children:
None
OutputPath-Element
Main output path for this build. Even if the build doesn’t produce any artifacts or generates output in other directories at least the log file will be saved here.
Attributes:
Children:
None
