XML Definition
Native Functions are defined in an XML Schema file which is located at “cgi_ctudio_connector/cgi_studio_connector/schema/NativeFunction.xsd”. This file can be used to validate xml files and with some editors (e.g. Visual-Studio) and provide code-completion when writing the XML file.
NativeFunctionDefinition-Element
Root Element. List of Function types.
Attributes:
None
Children:
| Argument | Occurrence | Description |
| Function | 0 - * | A native function definition |
Function-Element
Definition of a native Function.
Attributes:
| Argument | Required | Description |
| name | Yes | Name of the function. |
| uid | Yes | Unique Id of function. |
| has_result | Yes | Indicates if function has a result. If set, the function needs to return a bool value and can be called for checking events. In this case an event is triggered if the function returns true and all conditions are valid. |
| description | No | Description of the function. |
Children:
| Argument | 0 - * | Argument of the function |
Argument-Element
Definition of an argument of the function.
Attributes:
| name | Yes | Name of the argument. |
| uid | Yes | Unique Id of argument. |
| type | Yes | Type of the argument. This can be any basic or complex type if intended to be used for dynamic input/output. For static values any type is supported. |
| description | No | Description of the argument. |
| is_output | No | If set, this argument is passed as a reference with the intend to use it as an output value or in a condition. |
Children:
None
