XML Definition
Native Functions are defined in an XML Schema file which is located at “cgi_ctudio_connector/schema/NativeFunction.xsd”. This file can be used to validate xml files and with some editors (e.g. Visual-Studio) and provide code-completion when writing the XML file.
NativeFunctionDefinition-Element
Root Element. List of Function types.
Attributes:
None
Children:
Argument
Occurrence
Function
0 - *
A native function definition
Function-Element
Definition of a native Function.
Attributes:
Argument
Required
name
Yes
Name of the function.
uid
Yes
Unique Id of function.
has_result
Yes
Indicates if function has a result. If set, the function needs to return a bool value and can be called for checking events. In this case an event is triggered if the function returns true and all conditions are valid.
description
No
Description of the function.
Children:
Argument
Occurrence
Argument
0 - *
Argument of the function
Argument-Element
Definition of an argument of the function.
Attributes:
Argument
Required
name
Yes
Name of the argument.
uid
Yes
Unique Id of argument.
type
Yes
Type of the argument. This can be any basic or complex type if intended to be used for dynamic input/output. For static values any type is supported.
description
No
Description of the argument.
is_output
No
If set, this argument is passed as a reference with the intend to use it as an output value or in a condition.
Children:
None
