Editor
An editor for the Build-Projects definition can be found here:
cgi_studio_connector/bin/BuildProjectEditor.exe”
Global
Root-Paths
Root-Paths allow the user to make path/file variables relative to a specified path. Root-Paths are referenced via a Key. When a build is started these Root-paths must be set by the user beforehand.
They can be added and removed via the respective buttons on the right of the group.
Properties:
Property Name Description
Name Name of the Root-Path
Key Key used to reference this Root-Path. Description Description of the Root-Path.
Variables
Propertise:
Name Name of the Variable. This is the same name that is to be used in the scripts.
Description Description of the Variable.
Type
Type of the Variable. The following options are available:
- Value: Simple value type
- Option: Value typethat must be set at run time.
- Path: A path (folder)
- File: Full file path
Root-Path Key If the variable type is Path or File, the Root-Path keythis is used to reference a specified Root-Path. Doing so will treat the path as a relative path.
Value Value of the variablevariable. In case of ‘Option’ type values, the valid choices can be restricted by defining multiple values separated with a semicolon.
If the type is set to ‘Option’ the ‘Option Editor’ can be opened by clicking on the ‘…’ button next to the Value field.
In the Option Editor window individual options can be easily added and removed using the ‘plus’ and ‘minus’ buttons on the right side.
Builds
Properties
Name Name of the build.
Description Description of the build.
Script Path
Path to the script file which should be executed for this build. All scripts (.bat/.cmd) inside the specified folder are executed in alphabetical order so it is recommended to begin the filename with the number of the execution step.
Root-Path
(Script Path)
Root-Path Key of the Script Path.
Output Path Main output path for this build. Even if the build doesn’t produce any artifacts or generates output in other directories at least the log file will be saved here.
Root-Path
(Output Path)
Root-Path Key of the Output Path.
Variables
Variables for this build can be set here.
Properties:
Type
- Value: Simple Value type
- Option: Value that must be set at run time.
Root-Path Key
