Blood Pressure Sample
The blood pressure device sample is a Scene Composer sample that demonstrates a blood pressure measurement device with exemplary scenes and animations. For the Community Edition, the sample was extended with a voice activation feature and a data binding sample programmed in Python. The Python part of the sample relies on the Python-Based Player Data Binding Library to interact with the data bindings of the scene.
General information on this sample can be found in the Blood Pressure Solution documentation. This book goes over the sample Python extension, namely the voice activation feature and the integrated data binding.
\bin\CommuntiyEdition\Python\Samples\BloodPressureDevice.
The voice activation feature only works if the sample is started from Python using the Player Connector Library with the provided Python sample program. The feature doesn't work if the sample is started from the scene composer or directly with the player. Also, for enterprise edition users, if the Player Connector Library binary is built from source, it must be built with CMake flag CGIAPP_SAMPLE_SOUNDHOUND_ENABLED set to ON.
Python Environment Setup
To play the sample, a minimal Python setup is required. Verify that Python 3.x is installed on the system and either the py or the python command is on the path. Afterwards, create a virtual environment like below.
  1. Navigate to \bin\CommuntiyEdition\CommunityEdition\Python\Samples\BloodPressureDevice
    py -m venv .
    .\Scripts\activate
The CanderaAppConnector and other required types are an installable Python package under \bin\Player\PlayerConnector. Although, the package is listed in requirements.txt and installed by default. For more information refer to the Python-based Data Binding documentation.
Soundhound API Setup
  "action": "START_BPD"
like in the image below
The Soundhound service is now configured and the client credentials must be copied to the Python source files. Navigate to "Overview & API Key" and copy the credentials to the corresponding fields in the Python source file under:
\bin\Player\PlayerConnector\Samples\BloodPressureDevice\SoundhoundCommandClient.py
The sample can be started by executing the python blood pressure device sample program (\bin\CommuntiyEdition\Python\Samples\BloodPressureDevice\BloodPressureDevice.py) with the Python interpreter of the virtual environment. Note that the Python interpreter of the virtual environment is automatically used when the environment is activated. If the environment is activated, the terminal should have "(BloodPressureDevice)" written near the command input area.
  • "-lbp" is the path to the Player Connector Library binary. Either under \bin\CommuntiyEdition\<device>_Simulation\PlayerConnector\PlayerConnectorLibrary*.dll or where it was built
Blood Pressure Device Sample
When the sample starts, it plays an intro animation and activates the menu scene. The menu scene is active utiluntil an according voice command like "Start",  "Start measurement", "Start blood pressure device", ...  was recorded. A live transcription of the voice input is displayed in the menu scene.
