FeatStd 3.9
Increased stack size for Integrity threads
The stack size has been increased for Integrity threads. Every thread created by FeatStd::Internal::Thread is affected. So every Candera engine thread other than the main thread has the new stack size.
Assertion function with message
Additional assertion function has been added which prints a defined messsage when hit. (9735) The macro FEATSTD_DEBUG_ASSERT_MESSAGE(condition, message, ...) can be found in FeatStd/Diagnostics/Debug.h.
This macro is resolved into the public interface:
bool FeatStd::Diagnostics::DebugControl::Assert(const Char* expression, const Char* filename, Int lineNr, const Char *msgFormat, ...);
Option to copy StringData
A CMake option FEATSTD_STRINGDATA_COPY_ENABLED has been added for copying the internal StringData of a FeatStd::String. When the flag is enabled (default: OFF), then instead of sharing and reference counting the internal StringData, it is copied. This might be useful in application environments, where FeatStd::String objects are modified by several threads without controlling access via FeatStd::String::GetCriticalSection().
