Candera Base
Layout support for 2D and 3D (Canvas only)
The 2D feature to layout nodes by common dynamic layouters has been introduced into 3D now. As a starter only Canvas nodes are supported. This means CanvasGroup, CanvasSprite and CanvasText.
The supported layout types are equal to 2D:
- Baseline
- Grid
- Stack
- DockPanel
- Overlay
- Default
The layout is currently applied to the X,Y - plane. The layouter now uses AbstractNodePointer and CanderaObject types instead of the 2D only node types.
Restrictions on this version are given as follows:
- Layout clipping in 3D canvas is not supported yet
- Z-Fighting: When using the overlay layouter nodes are above each other but have the same Z coordinate. Therefore, these nodes have z fighting. It is planned to automatically solve this. However, for this version, it is advised to set the Depth Bias Unit of the Appearance - RenderMode. Changing the appearance of a CanvasSprite instead of CanvasText is strongly recommended. CanvasText requires only one draw call for all texts with equal conditions. One of them is the Appearance. Changing the render mode removes the shared appearance and produces an additional draw call.
