Candera Transitions
New Default Transition Type
The transition framework now supports triggering of animations that can be defined via Transitions::Hint parameters.
Reverse Transition
It is now possible to trigger reverse transitions. In case reversible fragments are identified, the already running transition fragments will go reverse, from their current state to their original one. An optional flag has been added to the Transitions::Rule to specify whether it shall be allowed to reverse a transition or not. Default value is false. A Transitions::OnReverseTransitionFragment corresponding event notifier has been added.
