Display Solution Controls as Vertical List
The solution controls are displayed as a vertical list instead of horizontal icon list (Mantis 8629).
See also:
FTCCmd Rules for Operations on Solutions Opened in SceneComposer
The following rules are applied when FTCCmd is used on a solution which is already loaded in SceneComposer:
  • the Info with Convert No option, Generate with Convert No option and ExportScl commands will not attempt locking;
  • the Info with Convert Yes option, Generate with Convert Yes option and Import commands will attempt locking and fail if solution is already loaded in SceneComposer (Mantis 8499).
See also:
Shader Compiler Plugin for Intel Apollo Lake
A new shader compiler plugin was created for Intel Apollo Lake platform. In this way it is possible to optionally compile the shaders (binary shader) for the desired target (Mantis 8405).
