Layout Borders
The borders of the grid cells can be visualized in SceneComposer scene editor. The border of every cell of the layouter will be visible as a yellow line. This border is visible if the group is selected or if just one single cell is selected.
Two different secondary borders - the bounding box of the parent node, and the bounding box of the effective node - will be visible, marked with blue, if some values are set (Mantis 8367).
See also:
No Displays in "Shareable Component Library" (SCL)
Since this version on, "shareable component library" (SCL) are not allowed to contain any display. The following two scenarios can result:
  • If an already created solution does contain any display, the user will be noticed through a specific dialogue.
  • If an older imported/converted solution already contains a .scl file with displays, the error will be showed in the Problems panel. In this way, the user will be noticed and will be allowed to correct this situation.
See also:
