SceneComposer Known Issues
  • After switching between some scenes, an "Attempted to read or write..." occurs (Mantis 7147).
  • An image used in a 2D scene becomes invisible in Scene Editor after it is renamed (Mantis 6955).
  • Some textures are not loaded correctly when solution is first opened (Mantis 6418).
  • Missind dependencies are displayed in "Problems" after converting a certain solution (Mantis 7102).
  • Elements from scene are disappearing when cloning an appearance collection template (Mantis 6128).
  • Asset setting ignored in Automation Script (Mantis 6683).
  • Attempted to read error occurs when two displays have the same id (Mantis 5821).
  • Child element of a canvas composite anchor is not visible in Scene Editor and can't be manipulated using gizmos (Mantis 7100).
  • Rendering elements are altered inside Scene Editor when check/uncheck render targets (Mantis 5797).
  • When a saved texture template is dragged on Appearance Editor, a critical error occurs (Mantis 7169).
  • Error occurs during import from a specific solution (Mantis 7173).
