FeatStd Monitor
Non-blocking connection setup
The monitor supports non-blocking connection setup now. CGIAnalyzer and target can be connected any time now.
Performance logs: Payload reduction
The payload of performance logs are reduced to approx. 36 percentage of previous version. The buffer for streaming can be smaller now due to restructuring the sent data. Using the recording only functionality can store more recordings within the same buffer. The amount of recordings traced is defined by the size of buffer. Changes to the buffer size can be done by changing the CMake flag MONITOR_CANDERA_PERF_RECORD_BUFFER_SIZE.
See also:
FeatStd CMake Switches for the changed CMake feature flag related to Monitor functionality.
