Scene Composer 3.12
New Feature
  • Fusion
    • Fusion allows you to structure your scene interactionslogic easily in a morevisual graphicalnode anddesigner intuitive
    way.
    Changes
    • State Machine
      • State machine editor functionality addedfor (annotations added. Annotations with text,text colornodes without interaction to state machine) and images)nodes can be colored and annotated with an image.
      • PseudoUML state machinepseudostate functionality added
    • Vector Graphics
      • Support for vector graphics is added, which can be created in Scene Composer or imported via SVG format supportfiles.
    • Smart Importer
      • Support for Figma formatdesign supportfiles is added
    • AI for control detection is directly integrated in Scene Composer
    Additional UI/UX improvements AddedRequirement URItracking functionality
    forFor easier requirement tracking an URI, next to annotation and description, can be defined by the user. If the URI is valid a clickable link is available to directly access the resource (e.g. a link to your requirement tool). Automatic import feature improved
      Automatic import was improved to support new use cases and the handling was improved.  Improved Properties panel Improved HMI Report function
        HMI report doesn't require Python anymore and is executed faster.  Display Preview support
        Display rotation support
          Rotation of Scene can be configured, in case your HMI is physically rotated build into your product. HMI Rotation support Referencing external resource functionality (Android Platform only)
