Scene Composer 3.12
New Feature
  • Fusion
    • Fusion allows you to structure your scene logic easily in a visual node designer
Changes
  • State Machine
    • State machine editor functionality for annotations added. Annotations with text nodes without interaction to state machine) and nodes can be colored and annotated with an image.
    • UML pseudostate functionality added
  • Vector Graphics
    • Support for vector graphics is added, which can be created in Scene Composer or imported via SVG files.
  • Smart Importer
    • Support for Figma design files is added
    • AI for control detection is directly integrated in Scene Composer
    • Additional UI/UX improvements
  • Requirement tracking
    • For easier requirement tracking an URI, next to annotation and description, can be defined by the user. If the URI is valid a clickable link is available to directly access the resource (e.g. a link to your requirement tool).
  • Automatic import feature improved
    • Automatic import was improved to support new use cases and the handling was improved.
  • Improved Properties panel
  • Improved HMI Report function
    • HMI report doesn't require Python anymore and is executed faster.
  • Display Preview support
  • Display rotation support
    • Rotation of Scene can be configured, in case your HMI is physically rotated build into your product.
  • Referencing external resource functionality (Android Platform only)
