Candera Base
TextureImage to Image2D Adaptor
An adaptor class TextureImageToImage2DAdaptor was added to enable using a TextureImage (3D only) as an Image2D. The TextureImageToImage2DAdaptor class implements Image2D interfaces and can therefore be used directly with a corresponding effect.
This can for instance be used to make the DirectTextureImage functionality available in 2D scenes.
Example Usage:
TextureImageToImage2DAdaptor::SharedPointer image = TextureImageToImage2DAdaptor::Create();
image->SetTextureImage(texture, pixelFormat);
image->Upload();
Default layout alignment change
The default value for horizontal and vertical layout alignment was modified from HCenter and VCenter to HStretch and VStretch.
