Candera Base
Enums in DynamicProperties namespace renamed
The enumerations DynamicProperties::PropertyFlags::Enum and DynamicProperties::PropertyType::Enum were renamed to DynamicProperties::PropertyFlags and DynamicProperties::PropertyType. Additionally, the Generic PropertyType was renamed to GenericType.
Added 9 OpenGL ES3.0 texture formats
The following OpenGL ES 3.0 formats have been added to Candera::Bitmap
| Bitmap::PixelFormat | Bits per pixel | Renderable | Description |
| EacCompressedUnsignedRPixelFormat | 4 | Compressed single channel unsigned alpha format | |
| EacCompressedSignedRPixelFormat | 4 | Compressed single channel signed alpha format (can preserve 0 exactly) | |
| EacCompressedUnsignedRGPixelFormat | 8 | Compressed two channel unsigned luminance alpha format | |
| EacCompressedSignedRGPixelFormat | 8 | Compressed two channel signed luminance alpha format (can preserve 0 exactly) | |
| SrgbUnsignedBytePixelFormat | 24 | sRGB | |
| SrgbaUnsignedBytePixelFormat | 32 | X | sRGBA |
| RgbFloatingPointR11G11B10PixelFormat | 32 | Floating point format with 5 bit exponent and 5/6 bit mantissa | |
| RgbFloatingPoint9E5FPixelFormat | 32 | Floating point format with shared 5 bit exponent and 9 bit mantissa | |
| RgbaUnsignedIntRev10A2PixelFormat | 32 | X | RGBA with 10 bit per rgb, 2 bit alpha |
Renderable means that the format can also be used as a render target.
Compressed single channel alpha formats deliver the best visual quality for transparency of all compressed formats using alpha. E.g., if the quality of transparency in a compressed texture is lacking, a combination of a compressed rgb texture together with a compressed single channel alpha texture should be favored over an uncompressed texture, since the 2 compressed textures still need less memory and bandwidth than an uncompressed one.
