FeatStd CMake Switches
Note:
For detailed information on FeatStd configuration please see Application Development > FeatStd > FeatStd Features
V2.10.0 V3.0.0
CGIFEATURE_ENABLE_LOG has been unified with FEATSTD_ENABLE_LOG FEATSTD_LOG_ENABLED
CGIFEATURE_ENABLE_MEMORYPOOL has been unified with FEATSTD_ENABLE_MEMORYPOOL FEATSTD_MEMORYPOOL_ENABLED
CGIFEATURE_ENABLE_MEMORY_STATISTIC has been unified with FEATSTD_ENABLE_SYSTEM_MEMORY_STATISTIC FEATSTD_SYSTEM_MEMORY_STATISTIC_ENABLED
CGIFEATURE_SYSTEM_MEMORY_STATISTIC_FILE_AND_LINE_TRACKING has been unified with FEATSTD_ENABLE_SYSTEM_MEMORY_STATISTIC_FILE_AND_LINE_TRACKING FEATSTD_SYSTEM_MEMORY_STATISTIC_FILE
_AND_LINE_TRACKING_ENABLED
CGIFEATURE_FRACTIONAL_NUMBER_TYPE has been unified with FEATSTD_FRACTIONAL_NUMBER_TYPE FEATSTD_FRACTIONAL_NUMBER_TYPE
CGIFEATURE_ENABLE_MONITOR has been unified with FEATSTD_ENABLE_MONITOR FEATSTD_MONITOR_ENABLED
COURIER_ENABLE_IPC has been unified with FEATSTD_ENABLE_IPC FEATSTD_IPC_ENABLED
FEATSTD_ENABLE_THREADSAFETY FEATSTD_THREADSAFETY_ENABLED
FEATSTD_ENABLE_UNITTEST_FRAMEWORK FEATSTD_UNITTEST_FRAMEWORK_ENABLED
FEATSTD_ENABLE_DLT FEATSTD_DLT_ENABLED
Note:
Refer to the Candera 3.0.0 CMake Changelog to learn about Candera V3.0.0 CMake switch modifications.
