Candera Engine 2D
Deterministic Render Order
In the past, RenderNodes with the same depth value have been rendered in an order which was dependent on the point of time the node has been added to the scene. The result was that in SceneComposer the render order could look different as when loading the scene from the asset on target.
The new implementation ensures that the render order of nodes with the same depth value is defined by the position within the scene tree. Nodes which appear on top of the scene tree (as shown in SceneComposer) are rendered before nodes that are located on the bottom of the scene tree. Therefore the render order is always the same during design on host (SceneComposer) and on target.
Cloning Interface
In accordance to basic Unified Cloning Interface, the following changes have been applied to the affected classes in Candera Engine 2D:
  • CloneSelf(CloneOperation) protected interface was removed.
  • Clone(TraverseOperation, CloneOperation) has become deprecated.
  • Copy constructor lost the optional CloneOperation argument.
  • Clone() const function was added.
The cloning interface was applied to:
Special considerations:
  • General. Descendants of Node implement deprecated "Node2D* Clone(Traversing) const" and "Node2D Clone(TraverseOperation, CloneOperation) const" for backward compatibility.
  • Camera2D. Camera2DRenderStrategy and RenderTarget2D are not linked to the clone anymore.
  • Node2D. Layouter is copied during deep node cloning. Because of this Node2D handles the destruction of Layouter upon disposing the node.
  • Scene2D. Scene2D may be cloned. Scene2D render order is not cloned, as it doesn't support different render order bins.
Deep Cloning Interface
In accordance to basic Tree Cloning Strategies, the following support is provided for deep cloning in 2D as follows:
CompositeGroup2D
CompositeGroup is a new Node2D type that is usually created by AssetLoader and which contain:
SharedPointer: Deprecated '...Ptr' types
All effect Ptr types like e.g. BitmapBrushPtr are marked as deprecated. Please use e.g. BitmapBrush::SharedPointer instead.
Deprecated BaseEffect2DPropertySetter
BaseEffect2DPropertySetter and its derivate classes became deprecated. Effect2D objects, as other objects with attached MetaInfo, can already animate their properties using built-in PropertyMetaInfo AnimationPropertySetters, with an improved performance.
AnimationPropertySetters Namespace Correction
All AnimationPropertySetters residing in <cgi_studio_candera>/src/Candera/Engine2D/AnimationPropertySetters have been moved from the Candera to the Candera::Animation namespace. The following classes are affected by this change:
Moved classes are still accessible via the Candera namespace in CGI-Studio 3.0.0 but these deprecated interfaces will be removed in the next release.
Candera2D Bitmap MipMap Flag
Candera2D internally uses MipMapping for Bitmaps, as long as OpenGL is used to render. Whereas this measure typically improves image quality, MipMaps consume ~1/3 more memory and might bear side effects (interpolation between MipMap levels may produce artifacts). Therefore a MipMapEnabled flag has been added.
See also:
Candera::Bitmap::SetMipMappingEnabled() and Candera::Bitmap::IsMipMappingEnabled().
Camera2D Viewport Transformation functions moved
Viewport transformation functions have been moved from Candera::Camera2D to new class Candera::Math2D. Picking in 2D considers window offset.
Reduced size of members
To reduce heap usage some elements in Candera 2D have been reduced in size:
DeviceObject2D listener.
DeviceObject2D now supports adding listeners that are notified before and after the object is uploaded and unloaded and before it is destroyied.
Layout Rectangle
The Layout is no longer done based on bounding rectangle. Instead, Node2D has a new property, layout rectangle. Bouding rectangle is used for picking and dirty area management. Computed layout and bounding rectangle are based on affect layout and bounding rectangle, respectively.
See also:
Node2D::SetLayoutingRectangle() and Candera::Effect2D::GetLayoutingRectangle(). Candera::Node2D uses new Layout Rectangle instead of Bounding Rectangle for layout.
TextBrush and TextBrushCaches compute their Layout Rectangle based on Text Cursor Position. MaximumSize property of TextBrush has been replaced by CacheArea. Bounding Box and Cache Size have been decoupled from Layout. To retrieve the height of a TextBrush with ConstantHeight use GetLayoutingRectangle, and for ActualHeight use GetBoundingRectangle.
Renderer2DListener
A Renderer2DListener allows to listen to Renderer-Events in Candera2D like in Candera 3D with RendererListener.
