Using Candera TextEngine to draw Text
The simplest way to draw text with Candera is using a TextNode2D, a 3D text widget from CGI Studio Widget Library, or the 2D TextBrush effect. Refer to:
To learn about how to use Candera::TextNode2D, please refer to the following section:
To learn about details, how to use the Candera TextEngine interface directly, refer to the following chapters.
Chapters
Using Candera::TextNode2D
Chapters
TextNode2D represents a RenderNode specialized for fast text rendering.
Text and style have to be provided. In addition, it requires a BitmapBrush effect for rendering and a Candera::TextNodeRenderer object used for generating the images, which will be then rendered by the associated BitmapBrush effect.
There are four Candera::TextNodeRenderer implementations available, each corresponding to one CacheType option from the existing Candera::TextBrush rendering concept (Bitmap, Surface, Glyph and Glyph Cache).
Text layouting is supported by attaching a Candera::TextNode2DLayouter to the node. It is responsible for arranging and truncating the associated text of a Candera::TextNode2D. The default layouter implements both horizontal and vertical truncation.
Renderer
Candera::TextNodeRenderer object is used for generating the correct images from provided text.
The level cache strategies which apply for a Candera::TextNode2D are described below:
  • Bitmap: very large memory footprint, very large update times, small render time
  • Surface: large video memory footprint, large update times, small render time
  • Glyph (former NoCache): small memory footprint, small update times, very large render time.
  • GlyphCache: small memory footprint, small update times, medium render time
  • GlyphAtlas: small (but global) video memory footprint, small update times, small render time.
Choose the appropriate cache for a balance in performance. It is recommended to use either Bitmap or Surface rendering type when static texts are used, while for dynamic texts, GlyphCache is recommended.
Associated Effect
Please consider that only BitmapBrush type effects apply to a Candera::TextNode2D. In case other effects are used nothing will be rendered. The text appearance can be altered by the type of effect chosen, either by modifying the in-place effects (color, mask, HSL transformations, etc.) or by changing blending effects.
List of BitmapBrush effects which can be used are described below:
Not all BitmapBrush effects have the Color property available. Default color for a TextNode2D is white.
Layouter
Candera::TextNode2DLayouter is responsible for arranging and truncating the text associated to a Candera::TextNode2D. Candera::DefaultTextNode2DLayouter, derived from Candera::TextNode2DLayouter, is used for text truncation. More details are provided in the following section.
Back to the sub menu
Candera::TextNode2D Guidelines
The minimum necessary steps needed in order to render a TextNode2D are:
  • Create a TextNode2D instance
  • Set a Text: Text to be rendered.
  • Set a Style: Style object to be used for rendering.
  • Define a TextNodeRenderer: TextNodeRenderer used for generating the correct images from provided text.
  • Attach a BitmapBrush effect: The associated BitmapBrush effect is responsible for rendering the generated images.
Define node and effect
Define a Candera::TextNode2D and the associated BitmapBrush effect:
    TextNode2D* m_textNode;
    BitmapBrushColorBlend::SharedPointer m_textNodeEffect;
Create node and effect
Create an instance of Candera::TextNode2D class by using Candera::TextNode2D::Create() method:
    m_textNode = TextNode2D::Create();
In similar way create the BitmapBrush effect and add this effect to the newly created Candera::TextNode2D:
    m_textNodeEffect = BitmapBrushColorBlend::Create();
    m_textNode->AddEffect(m_textNodeEffect.GetPointerToSharedInstance());
Set Text
Use Candera::TextNode2D::SetText() to specify the text to be rendered:
    m_textNode->SetText("TextNode2D");
Set Style
Use Candera::TextNode2D::SetText() to specify the style object:
Renderer
Create and set a Candera::TextNodeRenderer to Candera::TextNode2D using Candera::TextNode2D::SetTextNodeRenderer() method:
    m_textNode->SetTextNodeRenderer(&GlyphCacheTextNodeRenderer::GetInstance());
Add to Scene
Finally, add the textNode directly to a Candera::Scene2D or a Candera::Group2D:
    m_textNodeGroup->AddChild(m_textNode);
Candera::TextNode2D Properties
Text Color
Changing the color of a Candera::TextNode2D is done through the associated BitmapBrush effect. Depending on the effect use, not all BitmapBrush effects expose a color property. In this case, the rendered text will be white.
    m_textNodeEffect->GetColorEffect().Color().Set(Color(0.0f, 0.0f, 0.0f, 1.0f));
Text Alignment
Text alignment is realized through the layouter properties of the Candera::TextNode2D, meaning that the position inside a layouter, as well as text position inside the Candera::TextNode2D will now be changed by the same Candera::TextNode2DLayouter::SetHorizontalAlignment() and Candera::TextNode2DLayouter::SetHorizontalAlignment() methods the layouter. In case it in necessary to have a different text position than the provided layouting options, it is possible to nest Candera::TextNode2D and set different alignment values for the inner TextNode.
    TextNode2DLayouter::SetHorizontalAlignment(*m_textNode, Candera::HLeft);
    TextNode2DLayouter::SetVerticalAlignment(*m_textNode, Candera::VTop);
Truncation
Candera::TextNode2D provides only one truncation type - in case truncation is needed, the text gets cut and trailing ellipsis are added to fit the space. Truncation is not supported by default. For this, the Candera::DefaultTextNode2DLayouter needs to be attached to Candera::TextNode2D (see snippet below) and the text will be automatically truncated whenever the size of the text no longer fits in the specified Layout Size property of Candera::TextNode2D. Bounding rectangle size is not taken in account when performing text truncations.
    m_textNode->SetLayouter(&TextNode2DLayouter::GetDefault());
Multiline Support
Multiline layouting is enabled by default for a TextNode2D. This property can be enabled/disabled using Candera::TextNode2DLayouter::SetMultiLineEnabled() method.
Wordwrap Support
Wordwrap is not enabled by default for a TextNode2D. This property can be enabled/disabled using Candera::TextNode2DLayouter::SetWordWrapEnabled() method.
Text Height
Glyph based height computation is still done, but it is not used for layouting. The rectangle in which the text is layouted, if Size is (-1;-1), will be the one measured with old TextBrushConstantHeight option. The TextBrushActualHeight is always used for retrieving the bounding rectangle of the node, but it is also possible to retrieve the layout rectangle of the node too (see information about text length calculation below).
Text Length
The following methods are provided for retrieving the size of the rendered text:
Candera::TextNode2D in SceneComposer
The new TextNode2D is located in the Toolbox panel. In order to add a text to the scene, drag a TextNode from the panel to a Scene2D node.
From the Properties panel of the TextNode, configure the necessary properties for rendering: Text, Style.
Candera::TextNodeRenderer type of Candera::TextNode2D can be changed using the Renderer property. Default value in SceneComposer is Bitmap.
Candera::DefaultTextNode2DLayouter is attached by checking Enable Text Layouting. Additional layouter properties are exposed in the Properties Panel:
  • Multi line (enabled by default)
  • Word wrap (disabled by default)
For truncation to occur, Enable Text Layouting property needs to be enabled.
When a TextNode2D is created, a Candera::BitmapBrushColorBlend is automatically associated with the node, which is used for changing text color only. Any BitmapBrush effect present in the list of effects from Toolbox Panel can be used for text rendering. The visual appearance of the text will be affected depending on the type of effect chosen.
TextEngine Render Interface
Overview: Render Interface
The main interface to render text is the method
Text Render Context
A Candera::TextRendering::TextRenderContext is required to define a target for text rendering i.e. where to render the text to.
Configure Bitmap as Target for Text Rendering
A Candera::TextRendering::BitmapTextRenderContext can be used to draw text into a bitmap. So first of all the bitmap which shall be drawn needs to be defined with
  • the Candera::TextRendering::BitmapTextRenderContext::SetBitmap() method to assign a bitmap to render to,
  • the Candera::TextRendering::BitmapTextRenderContext::SetPenColor() method to define the text color
  • the Candera::TextRendering::BitmapTextRenderContext::SetClipRect() method to set a clipping rectangle for the text.
    BitmapTextRenderContext bmpRenderContext;
    static_cast<void>(bmpRenderContext.SetBitmap(m_bitmap));
    bmpRenderContext.SetPenColor(m_color);
Layouting Options
The Candera::TextRendering::LayoutingOptions define the layout of the rendered text with
See also:
Candera::TextRendering::LayoutingOptions for further options.
Shaping Options
The Candera::TextRendering::LayoutingOptions define how the text shall be transformed from logical to display presentation. The usage of one of the constructors is recommended:
  • Candera::TextRendering::ShapingOptions::ShapingOptions(const StylePtr &style)
  • Candera::TextRendering::ShapingOptions::ShapingOptions(const StylePtr &style, const CulturePtr &culture)
Text Properties
The Candera::TextRendering::TextProperties simply define the text itself which shall be rendered.
Back to the menu
Font Metrics and Text Sizes
Font Size
In Candera the font size (respectively the font height) has to be provided in pixel size. Note that in several word processing programs, like Microsoft Word, fonts are defined in point size. The conversion between pixel size and point size is calculated as follows (see FreeType Glyph Conventions):
  • pixel_size = point_size * resolution / 72
Microsoft Windows e.g. defines for historical reasons a default resolution of 96 PPI (DPI). A font in Microsoft Word with defined point size 18 has the same height as the font defined in Candera with pixel size 24 (24 = 18 * 96/72).
Font Metrics
For a font, static font metrics are provided describing font ascender, descender values in device pixel, the font line height and the maximum vertical advance of a font character: Candera::TextRendering::Font::GetMetrics()
    TextRendering::Metrics metrics;
    if (!m_font.GetMetrics(metrics)) {
        return false;
Text Bounds
Further, the text bounds (width, height, etc.) of a given string can be retrieved by calling GetTextRectangle method of Candera::TextRendering::GlyphTextMeasureContext or Candera::TextRendering::CursorTextMeasureContext.
Candera::TextRendering::GlyphTextMeasureContext builds a rectangle corresponding to the smallest surface covered by all the glyph bitmaps. The position of this rectangle( represented by (left, top) coordinates) can be offset from the text position. Therefore, when rendering the text, the Layouting Options should be constructed using the inverse of this offset.
Candera::TextRendering::CursorTextMeasureContext builds a rectangle corresponding to the whole surface swept by the cursor when moving while processing the text. The cursor is considered to be a segment of length equal to the style height. This rectangle does not usually have an offset and it contains the final advancement of the cursor.
    GlyphTextMeasureContext glyphContext;
    static_cast<void>(textRenderer.Render(glyphContext, LayoutingOptions(), ShapingOptions(m_style), TextProperties(m_text)));
    TextRect textBound = glyphContext.GetTextRectangle();
    mTextStartPos.SetX(-textBound.GetPosition().GetX());
    mTextStartPos.SetY(-textBound.GetPosition().GetY());
    Int16 textWidth = textBound.GetWidth();
    Int16 textHeight = textBound.GetHeight();
    static_cast<void>(textRenderer.Render(bmpRenderContext, LayoutingOptions(mTextStartPos), ShapingOptions(m_style), TextProperties(m_text)));
The Layouting Options describe the layout of the text. The Shaping Options define how the text is shaped (ligatures, text direction, ..) and they also contain the style.
Back to the menu
Simple Text Rendering
Rendering Simple Text
The Candera::TextRendering::TextRenderer provides the core function to render text.
For simple text rendering the Candera::TextRendering::TextRenderer::Render() method is called. Besides the actual text (type TChar*) and the BitmapTextRenderContext as target, layouting and shaping can be specified.
Finally the image has to be updated to apply the changes.
    bool success = m_textureImage->Update();
Back to the menu
Character-Glyph Position Mapping
Candera text engine provides an interface which allows to map positions in character string to positions in glyph string. This feature can be useful for applications and widgets in order to perform various operations depending on the character position like, for instance, highlighting text.
Example
For the convenience, we choose to improve the TextTextureWidget with this highlighting feature. The widget will highlight the text by rendering in red all the glyphs corresponding to the characters having the index in the interval m_start and m_end.
The character position information is accessible in the Blit method of the Candera::BitmapTextRenderContext class. Consequently, this class should be derived and the Blit method overwritten as follows:
class BitmapTextRenderContextSelection : public BitmapTextRenderContext
public:
    BitmapTextRenderContextSelection(Int selectionStart, Int selectionEnd, Color color) : m_start(selectionStart), m_end(selectionEnd), m_color(color) {}
    virtual void Blit(Int16 x, Int16 y, const GlyphBitmap& glyph);
private:
    typedef BitmapTextRenderContext Base;
    Color ComputeColorForCharPosition(TextPosition position);
    Int m_start;
    Int m_end;
    Color m_color;
void BitmapTextRenderContextSelection::Blit(Int16 x, Int16 y, const GlyphBitmap& glyph){
    SetPenColor(ComputeColorForCharPosition(glyph.characterPosition));
    Base::Blit(x, y, glyph);
Color BitmapTextRenderContextSelection::ComputeColorForCharPosition(TextPosition position){
    if(position >= m_start && position <= m_end){
        return Color(255,0,0);
    } else {
        return m_color;
In TextTextureWidget::UpdateTextureImage(), use the newly created class instead of Candera::BitmapTextRenderContext:
    BitmapTextRenderContextSelection bmpRenderContext(m_selectionStart, m_selectionEnd, GetTextColorPrv());
Back to the menu
Shortening Support For Bidirectional Text
Feature Overview
This feature ensures that the bidirectional text shall be shortened whenever it does not fit into its designated display area. The algorithm which does the shortening can deal with different levels of embedding of right-to-left text in left-to-right text and vice versa. Depending on the text direction of the last chunk, the shortening string is inserted after the last fitting text segment, on the left or on the right end.
You can take advantage of this feature by using one of the following, depending on the type of scene being rendered:
Scene type Node name Widget name
2D Candera::TextNode2D -
3D - TextTextureWidget
Truncation using TextNode2D
This feature is active only when the node parameter Enable Text Layout is enabled. The text will be automatically truncated whenever its size no longer fits in the specified Size property of the node. TextNode2D provides only one truncation method, by cutting text and adding trailing ellipsis to fit the space.
Truncation using TextTextureWidget
This feature is active only when the widget parameter Truncation method is set to the Text value. The character(s) used for visual feedback of text shortening is configurable by setting the Truncation text property of the 3D widget.
Examples
The image below exemplifies three scenarios :
  1. Shortening of the right-to-left text (Arabic)
  2. Shortening of the left-to-right text (Latin)
  3. Shortening of right-to-left text embedded in left-to-right text (left-to-right and right-to-left)
Back to the menu
Font Hinting
Font hinting is the use of mathematical instructions to adjust the display of an outline font so that it lines up with a rasterized grid. This is done by interpolating the pixels in order to more clearly render the font. At low screen resolutions, hinting is critical for producing clear, legible text. It can be accompanied by antialiasing and (on liquid crystal displays) subpixel rendering for further clarity.
The hinting applies only to outline fonts so the bitmap fonts and the stroke fonts will not be affected by this feature.
Hints are usually created in a font editor during the typeface design process and embedded in the font. In general, there are three possible ways to hint a glyph:
  • The font contains hints to guide the rasterizer, telling it which shapes of the glyphs need special consideration. The hinting logic is partly in the font and partly in the rasterizer.
  • The font contains exact instructions (also called bytecode) on how to move the points of its outlines, depending on the resolution of the output device, and which intentionally distort the (outline) shape to produce a well-rasterized result. The hinting logic is in the font; ideally, all rasterizers simply process these instructions to get the same result on all platforms.
  • The font gets auto-hinted (at run-time). The hinting logic is completely in the rasterizer. No hints in the font are used or needed; instead, the rasterizer scans and analyzes the glyphs to apply corrections by itself.
Enabling Hinting
The hinting can be enabled or disabled by the means of the method Candera::TextRendering::Font::SetHintingEnabled(). When hinting is disabled, the glyphs may appear blurred, as you can see below. The text was rendered with a small size font (9px) and then zoomed in:
Enabling AutoHint
The usage of the automatic hinter of the font driver can be controlled by calling the method Candera::TextRendering::Font::SetAutohintEnabled(). When the automatic hinter is disabled either the native hinter of the font is used either the hinting is disabled (zoomed in image):
Enabling Force AutoHint
If a given font driver doesn't provide its own hinter, the auto-hinter is used by default. If a format-specific hinter is provided, it is still possible to use the auto-hinter by enabling it using the method Candera::TextRendering::Font::SetForceAutohintEnabled().
Hinting Mode
The driver autohinter can be configured by calling the Candera::TextRendering::Font::SetHintingMode() method with one of the following parameters(hinting algorithms):
  • GlyphHinter::Normal : normal hinting, optimized for standard gray-level rendering
  • GlyphHinter::Light : applies less corrections than normal hinting for better performance
  • GlyphHinter::Monochrome : appropriate for monochrome rendering
  • GlyphHinter::Lcd : appropriate for horizontally decimated LCD displays
  • GlyphHinter::VerticalLcd : appropriate for vertically decimated LCD displays
All modes except GlyphHinter::Monochrome use 256 levels of opacity.
Code Example
    m_font1.SetHintingMode(GlyphHinter::Monochrome);
    m_font2.SetHintingMode(GlyphHinter::Light);
Glyph Bitmap Format
The output type of the glyph rendering process can be configured by calling the method Candera::TextRendering::Font::SetRequestedGlyphFormat() with one of the following render modes as parameters:
  • GlyphBitmap::Unknown : format is unspecified
  • GlyphBitmap::Monochrome : correspond to 1-bit bitmaps (two levels of opacity)
  • GlyphBitmap::Lcd : format use with horizontally decimated RGB or BGR sub-pixel LCD displays
  • GlyphBitmap::VerticalLcd : format use with vertically decimated LCD displays
  • GlyphBitmap::Grayscale : format is grayscale, one byte per pixel; this is the default render mode
Each of the render modes above correspond to a specific type of scanline conversion performed on the outline.
Code Example
    m_font1.SetRequestedGlyphFormat(GlyphBitmap::VerticalLcd);
    m_font2.SetRequestedGlyphFormat(GlyphBitmap::Grayscale);
Monochrome Render Mode
The monochrome render mode removes anti-aliasing because it's using only two levels of opacity and gives clearer appearance for small size fonts (no blurring). Please see below a comparison between monochrome and grayscale render modes:
An another advantage of using this render mode is the smaller memory footprint for glyphs because of 1bit format.
Back to the menu
