Configuring and Loading an Animation
Candera Animation Concept
The following key concepts are required to run animations in a Candera application:
In SceneComposer, animations can be configured in the AnimationDesign view:
  • Create a new animation - New Animation in SceneComposer User Manual
  • Select a node property to animate - Add Animated Property in SceneComposer User Manual
  • Specify the key frame sequence including property values and interpolation strategy - Animation Values in SceneComposer User Manual
It is also possible to import an animation to SceneComposer from a content generation tool via FBX format - Import FBX in SceneComposer User Manual
Animation Player Example
As an example, refer to
  • the animation tutorial solution in \cgi_studio_player\content\Tutorials\06_AnimationManipulation
  • as well as the AnimationPlayerWidget in \cgi_studio_player\LightPlayer\src\Widgets\Tutorial\AnimationPlayerWidget
Configuring Animation Player
In the Player or in an application, the animation can be retrieved from the generated asset by specifying its Candera name (e.g. MyModule#Animations#Animation).
    AssetProvider* assetProvider = GetAssetProvider();
    m_animPlayer = assetProvider->GetAnimation(m_animName);
In SceneComposer the animation can be retrieved from AssetProvider only if it was previously loaded in the scene. A better way to access it directly is to define it as a widget property.
                // Define Animation property
                CdaProperty(Animation,Candera::Animation::AnimationPlayer::SharedPointer, GetAnimation, SetAnimation)
                    CdaDescription("Animation")
                CdaPropertyEnd()
                // End Define Animation property
Next, as already explained in Initializing AssetLoader and Animations, an instance of Candera::Animation::AnimationTimeDispatcher is needed to provide current world time to animations.
For this, the new animation player must be added to the Candera::Animation::AnimationTimeDispatcher instance maintained by the application.
        // Add player to time dispatcher
        Animation::AnimationTimeDispatcher::SharedPointer timeDispatcher = GetAnimationTimeDispatcher();
        if (timeDispatcher == 0) {
            return;
        static_cast<void>(timeDispatcher->AddPlayer(m_animPlayer));
        // End Add player to time dispatcher
Now the animation player is ready to be used.
