Configuring and Loading an Animation
Candera Animation Concept
The following key concepts are required to run animations in a Candera application:
- Candera::Animation::AnimationPlayer provides the control interfaces (use Candera::Animation::AnimationGroupPlayer for animation groups)
- Candera::Animation::AnimationTimeDispatcher dispatches the current world time to animations; animations can also query the current world time from the dispatcher
- Candera::Animation::AnimationKeyframeSequence configures proper animation values for each time point of an animation.
- Candera::Animation::InterpolationStrategy specifies for a key frame sequence, how values between several key frames shall be calculated.
- Candera::Animation::AnimationPropertySetter applies animation values to animated properties
In SceneComposer, animations can be configured in the AnimationDesign view:
- Create a new animation - New Animation in SceneComposer User Manual
- Select a node property to animate - Add Animated Property in SceneComposer User Manual
- Specify the key frame sequence including property values and interpolation strategy - Animation Values in SceneComposer User Manual
It is also possible to import an animation to SceneComposer from a content generation tool via FBX format - Import FBX in SceneComposer User Manual
Animation Player Example
As an example, refer to
- the animation tutorial solution in \cgi_studio_player\content\Tutorials\06_AnimationManipulation
- as well as the AnimationPlayerWidget in \cgi_studio_player\LightPlayer\src\Widgets\Tutorial\AnimationPlayerWidget
Configuring Animation Player
In the Player or in an application, the animation can be retrieved from the generated asset by specifying its Candera name (e.g. MyModule#Animations#Animation).
AssetProvider* assetProvider = GetAssetProvider();
m_animPlayer = assetProvider->GetAnimation(m_animName);
In SceneComposer the animation can be retrieved from AssetProvider only if it was previously loaded in the scene. A better way to access it directly is to define it as a widget property.
// Define Animation property
CdaProperty(Animation,Candera::Animation::AnimationPlayer::SharedPointer, GetAnimation, SetAnimation)
CdaDescription("Animation")
CdaPropertyEnd()
// End Define Animation property
Next, as already explained in Initializing AssetLoader and Animations, an instance of Candera::Animation::AnimationTimeDispatcher is needed to provide current world time to animations.
For this, the new animation player must be added to the Candera::Animation::AnimationTimeDispatcher instance maintained by the application.
// Add player to time dispatcher
Animation::AnimationTimeDispatcher::SharedPointer timeDispatcher = GetAnimationTimeDispatcher();
if (timeDispatcher == 0) {
return;
static_cast<void>(timeDispatcher->AddPlayer(m_animPlayer));
// End Add player to time dispatcher
Now the animation player is ready to be used.
