Candera Reference Shaders
This document describes content and usage of Candera Reference Shaders part of CGI Studio releases. Within this document the set of Candera Reference Shaders is listed with additional information how to use and combine them in 3D applications based on Candera.
Chapters
Location of Reference Shaders
Candera delivers a set of reference shader implementations, which can be found at following location:
  • \cgi_studio_candera\src\Candera\ReferenceShaders
The same set of reference shaders is available in SceneComposer.
Preferred way of usage is to export shaders to a binary asset file and to load it in an application based on Candera. Shaders part of exported scenes are automatically added to the asset file and loaded by Candera.
Used Include Files
Some parts of shader code used in Candera Reference Shaders have been collected into several files in order to be reused as include files.
Following files are available and can be used as include files:
Include File Supports Include In Note Displaces
RefEnvironment.inc Platform specific defines All Shaders Shall be included in each Shader as first statement Environment.incv, Environment.incf
RefLighting.inc Lighting specific functions, also functions for anisotropic lighting Shaders that support lighting Useful helper functions for vertex lighting and pixel lighting DefaultLighting.incv
RefTexturing.inc Texturing specific functions, e.g. Environment Mapping Shaders that support certain texture effects Useful helper functions especially for common texture effects Texturing.incv
Reference Vertex Shaders
Vertex Shaders Supports Combine with Fragment Shaders GenericShaderParamSetter Configuration Note
Core/RefTrans Transformation,
Texture
Core/RefTex,
Core/RefUniColor,
Core/RefUniColorTex,
Core/RefTex2LightMap,
Core/RefUniDiffuseMatTex,
Effects/RefTexDofBlur,
Effects/RefTexDofCombine
SetModelViewProjectionMatrix4Enabled(true)
SetMaterialActivationEnabled(true)
SetTextureActivationEnabled(true)
Lighting has no influence.
Core/RefTransColor Transformation,
VertexColor,
Texture
Core/RefColor,
Core/RefColorTex,
Core/RefColorTexAlpha,
Effects/RefColorTexAlphaOutline
Core/RefTransLight1 Transformation,
Vertex Lighting with one light source,
Texture
Core/RefColor,
Core/RefColorTex
SetLightActivationEnabled(true)
If Texture is used, depends on corresponding fragment shader only.
Core/RefTransLight2 Transformation,
Vertex Lighting with two light sources.
Texture
Core/RefColor,
Core/RefColorTex
Core/RefTransLight3 Transformation,
Vertex Lighting with three light sources.
Texture
Core/RefColor,
Core/RefColorTex
Core/RefTransWorldLight1 Transformation,
Lighting in WorldSpace with 1 Light
Texture
Core/RefColor,
Core/RefColorTex
SetLightsCoordinateSpace(World)
Lighting calculations are processed in world space instead of model space (For details see function Light::SetCoordinateSpace).
Effects/RefTransSphereMap Transformation,
Sphere Texture Mapping
Core/RefTex,
SetModelViewMatrix4Enabled(true)
SetNormalModelViewMatrix3Enabled(true)
Used to process a sphere texture for environment mapping.
Effects/RefTransLight1SphereMap Transformation,
Core/RefColorTex SetModelViewMatrix4Enabled(true)
Effects/RefTransLight2SphereMap Transformation,
Vertex Lighting with two light sources,
Effects/RefTransLight3SphereMap Transformation,
Vertex Lighting with three light sources,
Core/RefTransPointSprite Transformation of PointSprite Core/RefPointSprite SetModelViewProjectionMatrix4Enabled(true)
Use with PointSprite.
As usual for point sprites, lighting has no influence.
Core/RefTransLight1Morph Transformation,
VertexLighting with one lighe source,
Morphing Weights
Core/RefColor,
Core/RefColorTex
Use with MorphingMesh.
Effects/RefTransLight1BumpMap Transformation,
Calculation of lighting vectors in tangent space.
Effects/RefLight1BumpMap SetModelMatrix4Enabled(true)
SetNormalModelMatrix3Enabled(true)
SetCameraPositionEnabled(true)
Used to prepare lighting vectors for bump map shaders.
Effects/RefTransLight1ProceduralWood Transformation,
Passing position to fragment shader for procedural calculations.
Effects/RefProceduralWood SetModelViewProjectionMatrix4Enabled(true)
Effects/RefTransAnisotropicLight1Strand Transformation, passes vertex attributes in world space to fragment shader. Calculates direction of anisotropy, eye vector and light direction. Effects/RefAnisotropicLight1StrandTex SetModelViewProjectionMatrix4Enabled(true)
Effects/RefTransAnisotropicLight1 Transformation,
Passes vertex attributes in world space to fragment shader.
Effects/RefAnisotropicLight1SpecularTex SetModelMatrix4Enabled(true)
Effects/RefTransFur Transformation,
Indexed Multi pass upscaling in direction of normals, Texture
Effects/RefUniColorTexFur SetModelViewProjectionMatrix4Enabled(true)
Effects/RefTransCubeMapReflection Transformation,
Texturing reflection using one CubeMap texture
Core/RefCubeMapTex SetModelMatrix4Enabled(true)
Environment mapping reflections using a CubeMap texture. Lighting is not considered.
Effects/RefTransCubeMapRefraction Transformaion,
Texturing refraction using one cubemap texture.
Environment mapping refractions using a CubeMap texture. Lighting is not considered. Refraction ratio has to be passed as additional uniform float refractionRatio.
Effects/RefTransCubeMapReflectionRefraction Transformation,
Texturing reflection and refraction using one cubemap texture.
Core/RefCubeMapTex2 SetModelMatrix4Enabled(true)
Environment mapping refractions and reflections using a CubeMap texture. Lighting is not considered. Refraction ratio has to be passed as additional uniform float refractionRatio.
Core/RefTransCubeMap Transformation,
Texturing using one CubeMap texture, addressed directly by object space vertex coordinates.
Core/RefCubeMapTex SetModelViewProjectionMatrix4Enabled(true)
Direct addressing of CubeMap texture using object space vertex positions. Can be used for e.g. a SkyBox using a CubeMap texture.
Effects/RefTransDof Transformation,
Texturing with one texture,
First render pass of depth-of-field rendering: Rendering the scene,
Scaled depth value passed as varying.
Effects/RefTexDof SetModelViewProjectionMatrix4Enabled(true)
First pass of depth-of-field rendering has to be applied to every node that is rendered. The resulting image then contains the scene's depth values as alpha value, which is used for further processing. If other effects (e.g. Light, bump mapping etc.) have to be applied on the nodes, then also the corresponding shaders have to be adapted to meet the depth-of-field requirements. Additional uniform u_depthScale has to be passed to scale the depth values.
Effects/RefTransLight1Dof Transformation,
Texturing with one Texture
Effects/RefColorTexDof SetModelViewProjectionMatrix4Enabled(true)
SetLightsCoordinateSpace(Light::Object);
First pass of depth-of-field rendering has to be applied to every node that is rendered. The resulting image then contains the scene's depth values as alpha value, which is used for further processing. If other effects (e.g. bump mapping etc.) have to be applied on the nodes, then also the corresponding shaders have to be adapted to meet the depth-of-field requirements. Additional uniform u_depthScale has to be passed to scale the depth values.
Supports per vertex lighting.
Effects/RefTransFragmentLightDof Transformation,
Texturing with one Texture,
Normal and position for per fragment lighting,
Effects/RefTexFragmentLightDof SetModelViewProjectionMatrix4Enabled(true)
SetLightsCoordinateSpace(Light::World);
SetModelMatrix4Enabled(true);
SetNormalModelMatrix3Enabled(true);
Supports per Fragment lighting.
Core/RefTransPos Transformation,
Texture,
Vertex position to fragment shader
Core/RefFlatLight1 SetModelViewProjectionMatrix4Enabled(true)
No light calculation, passing vertex position to fragment shader for FlatShading calculations.
Effects/RefTransLight1Gooch Transformation, Assignment of ambient light component, Calculation of varyings needed for computation of specular component in world space. First pass of gooch-shading: Shading. Effects/RefGoochShading SetModelMatrix4Enabled(true)
This vertex shader in conjunction with RefGoochShading.fragp realizes the first pass of an implementation of Gooch's rendering technique to simulate the appearance of technical illustrations, often occuring in e.g. manuals or schematic presentations etc. (SIGGRAPH'98 paper "A Non-Photorealistic Lighting Model For Automatic Technical Illustration"). The first pass renders the object using a transition from "cool" to "warm" colors according to the lighting model. While phong shading is normally used to simulate real lighting, this lighting model aims more on preserving details away from the light source. The second pass then draws the silhoutte of the object. For this the object is upscaled and rendered with a fixed color (e.g. black). On Candera side the first and the second pass have to be rendered with different Culling states, such that first pass renders the front of the object, and the second only the back side.
Effects/RefTransScale Transformation, Upscaling in direction of normals, texture coordinates. Core/RefTex,
Core/RefUniColor,
Core/RefUniDiffuseMat,
Lighting has no influence. Used to upscale the vertices inside the vertex shader, using a float scale factor passed as uniform u_Scale. Is used for silhouette rendering in gooch-shading, but may be also used for other techniques.
Core/RefViewportSpace Texture
Adjusting the position of the screen aligned billboard by setting uniform u_offsetLeft and u_offsetTop.
Effects/RefTexGaussianBlurX,
Effects/RefTexGaussianBlurY,
Effects/RefTexDofCombine,
Effects/RefBloomThreshold,
Effects/RefCombineBloom,
Core/RefInterlaceMask
SetModelViewProjectionMatrix4Enabled(false)SetMaterialActivationEnabled(true)
Used in subsequent post processing passes in conjuction with a screen-aligned billboard. The billboard should be of size 0.0 to 1.0 with 1.0 being a fullscreen billboard. The position of the billboard on the screen can be adjusted by setting the left and top offset in the range of 0.0 to 1.0.
Passes the position and texture coordinate to the fragment shader without any matrix transformation. Therefore the incoming vertex buffer should already be in homogenous screen coordinates.
Note: Overlapping Billboards (in screen space) would produce Z-fighting artifacts. Disabling depth test and using render order as well as using depth bias can be used to avoid them.
Effects/RefTransLight1Carbon Transformation, Lighting with one light source, Texture, Line of Sight Effects/RefCarbon SetModelMatrix3Enabled(true)
Seamless texture utilized as carbon image
Effects/RefTransLight1FlopCarPaint Transformation, Lighting with one light source, Line of Sight, Mixes two color components diffuse and emissive based on camera position Effects/RefFlopCarPaint SetModelMatrix3Enabled(true)
SetTextureActivationEnabled(false)
Mixes two color components (diffuse and emissive) based on the camera position
Effects/RefTransLight1MetalFlakesCarPaint Transformation, Lighting with one light source, Line of Sight, Texture Effects/RefMetalFlakesCarPaint SetModelMatrix3Enabled(true)
Metal flake effect with one noise texture
Effects/RefTransLight1FlopMetalFlakesCarPaint Transformation, Lighting with one light source, Line of Sight, Texture, Mixes two color components diffuse and emissive based on camera position Effects/RefFlopMetalFlakesCarPaint SetModelMatrix3Enabled(true)
Core/RefCanvasTrans Applying scale and offset to vertices before transformation,
Transformation into world space,
Texturing with one texture.
Core/RefTex,
Core/RefUniColor,
SetCanvasActivationEnabled(true)
Similar to RefTrans, but additionally applies canvas offset and size before multiplying the mvp matrix.
Core/RefCanvasTransLight1 Applying scale and offset to vertices before transformation,
Transformation,
Texturing with one tetxture,
One light source with lighting in model space.
Core/RefColor,
Core/RefColorTex
Similar to RefTransLight1, but additionally applies canvas offset and size before multiplying the mvp matrix.
Core/RefCanvasTransUniDiffuseMat Applying scale and offset to vertices before transformation,
Forwarding of material diffuse color to fragment shader.
Core/RefCanvasUniDiffuseMat SetModelViewProjectionMatrix4Enabled(true)
Similar to RefTrans, but additionally applies canvas offset and size before multiplying the mvp matrix. Additionally it passes material diffuse color to fragment shader. This shader is used to achieve the same effect as a SolidColorBrush in 2D.
Effects/RefFxaa Coordinates in normalized device space. Effects/RefFxaa SetModelViewProjectionMatrix4Enabled(false)
SetLightActivationEnabled(false)
SetMaterialActivationEnabled(false)
Applies the "Fast approximate anti-aliasing" algorithm to its input, which should be a quad using normalized device coordinates. The uniform (u_Resolution) needs to be set to the width and height of the input texture measured in texels.
Effects/Ref Texture Effects/RefTexGaussianBlurX,
Passes texture coordinates and vertex position to fragment shader without applying a transformation. This is useful for post processing effects when the vertex buffer is just a quad in normalized device coordinates (-1,1).
Effects/RefTransGradientLinear Transformation into world space,
Vertex based linear gradient computations.
Effects/RefGradientLinear SetModelViewProjectionMatrix4Enabled(true) Vertex Shader for linear gradient computations.
Effects/RefTransGradientRadial Transformation into world space,
Passing vertex position to fragment shader.
Effects/RefGradientRadial SetModelViewProjectionMatrix4Enabled(true)
Reference Fragment Shaders
Fragment Shaders Supports Combine with Vertex Shaders GenericShaderParamSetter Configuration Note
Core/RefColor Color from varying Core/RefTransLight*,
Core/RefTransWorldLight*,
See configuration of RefTransLight* or RefTransWorldLight1 Normaly used for models that support lighting but no texture.
varying color (v_Color) is typically either set by lit material or by vertex color.
Core/RefTex Texture Core/RefTrans,
Effects/RefTransSphereMap,
See configuration of RefTrans or RefTransSphereMap Lighting has no influence.
Core/RefColorTex Color from varying,
Texture
Core/RefTransColor,
Core/RefTransLight1Morph,
Core/RefTransLight*SphereMap
See configuration of RefTransLight* or RefTransWorldLight1 Normaly used for models that support lighting and one texture.
varying color (v_Color) is normaly either set by lit material or by vertex color.
Core/RefUniColor Color from uniform Core/RefTrans,
Effects /RefTransScale
See configuration of RefTrans Useful if certain color is set via uniform (u_Color) directly.
Lighting or vertex colors have no influence.
Core/RefUniColorTex Color from uniform,
Texture
Core/RefTrans,
See configuration of RefTrans or RefTransSphereMap Useful if certain color is set via uniform (u_Color) directly and blended with one texture.
Core/RefUniDiffuseMatTex Material diffuse color,
Texture
Core/RefTrans,
See configuration of RefTrans or RefTransSphereMap Final color = materials diffuse color * texel color.
The uniform value of the materials diffuse color is set by Candera automatically if a Material is applied to a Node. Lighting or vertex colors have no influence.
Core/RefPointSprite Pointsprite incl. Texturing Core/RefTransPointSprite See configuration of RefTransPointSprite Used for point sprites only.
Core/RefTex2LightMap Texture,
LightMap
Core/RefTrans,
See configuration of RefTrans Lightmap Multitexturing: A Lightmap typically defines an illumination texture at unit 1 that is multiplied with texture at unit 0.
Effects/RefLight1BumpMap Per pixel lighting using the normals supplied in u_Texture1 (normal map). Computed color is combined with the texture in u_Texture0. Effects/RefTransLight1BumpMap See configuration of RefTransLight1BumpMap Used to display rough surfaces without adding polygon complexity to it.
The shader accepts two textures. u_Texture0 defines the color map used. u_Texture1
defines a normal map, that stores normals in tangent space to be used for lighting
calculations.
Effects/RefProceduralWood Procedural calculation of interpolated rings, which appears like annual rings of wood if the right colors are chosen. Effects/RefTransLight1ProceduralWood See configuration of RefTransLight1ProceduralWood For procedural calculations two color, the orgin of the annual rings and a multiplier that controls the densitiy of the rings can be passed.
Effects/RefAnisotropicLight1StrandTex Per pixel anisotropic lighting, using a strand texture Effects/RefTransAnisotropicLight1Strand First texture for color, second for strand. The strand texture must hold the diffuse and specular light intensity in the R and G channels, respectively.
Effects/RefAnisotropicLight1SpecularTex Per pixel anisotropic lighting Effects/RefTransAnisotropicLight1 See configuration of RefTransAnisotropicLight1 Using alternative anisotropic specular highlights, according to Ward's SIGGRAPH 92 paper "Measuring and Modeling Anisotropic Reflection". Additional calculated specular component is combined with u_Texture0.
Used to display the reflection behavior of multiple surfaces. Uniforms u_AlphaX and u_AlphaY model the distribution of the specular highlight. Combined with a texture it can for example be used to simulate metallic surfaces like brushed steel. In the cited paper alphaX and alphaY for several materials can be found.
Effects/RefUniColorTexFur Assignment of product of alpha mask, texture and fixed color. Effects/RefTransFur See configuration of RefTransFur Simulates the appearance of fur if applied with MulitPassRendering. Is also intended to demonstrate multi pass rendering.
Core/RefCubeMapTex Addressing one cube map texture using a single varying vec3. Effects/RefTransCubeMapReflection, Effects/RefTransCubeMapRefraction,
See configuration of RefTransCubeMapReflection, RefTransCubeMapRefraction,
RefTransCubeMap
Cube Map addressing, material colors or lighting are not considered.
Core/RefCubeMapTex2 Mixing two different addressed fragments of a CubeMap using a varying ratio. Addressing is done using two varying vec3. Effects/RefTransCubeMapReflectionRefraction See configuration of RefTransCubeMapReflectionRefraction Cube Map addressing, material colors or lighting are not considered.
Core/RefUniDiffuseMat Material diffuse color Core/RefTrans See configuration of RefTrans Final color = materials diffuse color
Effects/RefTexDof Assignment of Texture, First render pass of depth-of-field rendering: Rendering the scene, Depth encoded into alpha channel. Effects/RefTransDof See configuration of RefTransDof First pass of depth-of-field rendering has to be applied to every node that is rendered. The resulting image then contains the scene's depth values as alpha value, which is used for further processing. If other effects (e.g. Light, bump mapping etc.) have to be applied on the nodes, then also the corresponding shaders have to be adapted to meet the depth-of-field requirements.
Effects/RefColorTexDof Color from varying,
Effects/RefTransLight1Dof See configuration of RefTransLight1Dof First pass of depth-of-field rendering has to be applied to every node that is rendered. The resulting image then contains the scene's depth values as alpha value, which is used for further processing. If other effects (e.g. bump mapping etc.) have to be applied on the nodes, then also the corresponding shaders have to be adapted to meet the depth-of-field requirements.
Support per vertex lighting.
Effects/RefTexFragmentLightDof Per fragment lighting with one light source,
Effects/RefTransFragmentLightDof See configuration of RefTransFragmentLightDof First pass of depth-of-field rendering has to be applied to every node that is rendered. The resulting image then contains the scene's depth values as alpha value, which is used for further processing. If other effects (e.g. bump mapping etc.) have to be applied on the nodes, then also the corresponding shaders have to be adapted to meet the depth-of-field requirements.
Supports per fragment lighting.
Effects/RefTexDofBlur Assignment of texture, second render pass of depth-of-field: blurring the texture, simulating an optical circle of confusion, caused by lens refraction out of focus. Core/RefTrans See configuration of RefTrans Second pass of depth-of-field rendering: blurring the incoming image. Result is a blurred image of the passed texture. u_CocScale controls the size of the circle of confusion, and therefore the blur strength.
Effects/RefTexDofCombine Third pass of depth of field: Assignment and blending of two textures, representing the sharp and blurred image. Blend weights result from focus and focus range of the simulated camera lens. Core/RefViewportSpace, Effects/Ref See configuration of RefTrans Third pass of depth rendering: Combines the sharp and the blurred image according to the set focus of the simulated camera lens. u_Focus controls the distance of the focus plane (where a sharp image would be formed). u_Range controls the size of the area around the focus plane, where a sharp image would be drawn.
Effects/RefTexGaussianBlurX Assignment of texture,
Subsequent pass of post-processing effect: blurring the texture with a Gaussian blur,
Gaussian blur step width from unifrom
Core/RefViewportSpace, Effects/Ref See configuration of RefViewportSpace
plus
SetUniform("u_blurFactor",Shader::Float, &blurFactor)
Subsequent pass of post-processing effect: blurring the incoming image horizontally. Result is a blurred image of the passed texture. u_blurFactor controls the step width of the Gaussian function. u_blurFactor should always be 1.0/TextureWidth so that every step will correlate with one pixel.
Effects/RefTexGaussianBlurY Assignment of texture,
plus
Subsequent pass of post-processing effect: blurring the incoming image vertically. Result is a blurred image of the passed texture. u_blurFactor controls the step width of the Gaussian function. u_blurFactor should always be 1.0/TextureHeight so that every step will correlate with one pixel.
Core/RefFlatLight1 Per fragment lighting with one light source for Flat Shading. Core/RefTransPos See configuration of RefTransPos In order to use derivative functions dFdx and dFdy the extension GL_OES_standard_derivatives has to be enabled and supported by driver.
Effects/RefGoochShading Per Fragment calculation of specular component, Mixing cool and warm color using the dot product of light direction and vertex normal as weight, Output: Mixed color + specular and ambient lightcomponent. Effects/RefTransLight1Gooch See configuration of RefTransLight1Gooch This fragment shader in conjunction with RefTransLight1Gooch.vertp realizes the first pass of an implementation of Gooch's rendering technique to simulate the appearance of technical illustrations, often occuring in e.g. manuals or schematic presentations etc. (SIGGRAPH'98 paper "A Non-Photorealistic Lighting Model For Automatic Technical Illustration"). For details please refer to the description of the vertex shader, and to the cited paper. The following unifiorms are needed: u_CoolColor and u_CoolColor are 4-component vectors that describe the colors for the cool to warm transition. u_CoolDiffuseWeigth and u_WarmDiffuseWeight are float values that describe, how the original diffuse color is combined with the warm and cool colors.
Effects/RefBloomThreshold Assignment of texture,
Subsequent pass of bloom effect: extracting only the bright parts of the image that should be blurred,
brightness threshold from unifrom
Core/RefViewportSpace, Effects/Ref See configuration of Core/RefViewportSpace Subsequent pass of post-processing bloom effect: extracting only the bright parts of the incoming texture. Those bright parts are blurred in the next step to generate a bloom effect.
Effects/RefCombineBloom Subsequent pass of bloom effect: Assignment and djustable combination of the original and the bloomed texture Core/RefViewportSpace, Effects/Ref See configuration of RefViewportSpace Subsequent pass of post-processing bloom effect: The incoming texture of the original scene and the incoming texture of the bright, bloomed parts are combined. The blending of the two textures is adjustable by uniforms representing the intensity and saturation of the images.
Core/RefInterlaceMask Uses a texture's color to create a mask through discarding pixels with low transparency. No value is written to the discarded fragments, so also no depth or stencil values. Core/RefViewportSpace See configuration of RefViewportSpace Is especially useful for e.g. Creating stencil masks for stereoscopic 3D.
Effects/RefCarbon Wraps a seamless texture multible times around the object to achieve carbon look. Effects/RefTransLight1Carbon See configuration RefTransLight1Carbon Creates a car paint with typical carbon look.
Effects/RefFlopCarPaint Mixes the two color components together based on the camera position and a user defined bias Effects/RefTransLight1FlopCarPaint See configuration RefTransLight1FlopCarPaint Creates a car paint with shiny, anisotropic two color look.
Effects/RefMetalFlakesCarPaint Adding a noise to the spectral part of the light. Noise can be wrapped around the object multible times. Create the illusion of metal flakes in the car paint. Effects/RefTransLight1MetalFlakesCarPaint See configuration RefTransLight1MetalFlakesCarPaint Creates a car paint with shiny, sparkling look produced by metal flakes within specular highlight
Effects/RefFlopMetalFlakesCarPaint Mixes the two color components together based on the camera position and a user defined bias.
Effects/RefTransLight1FlopMetalFlakesCarPaint See configuration RefTransLight1FlopMetalFlakesCarPaint Creates a car paint with shiny, sparkling look produced by metal flakes within specular highlight combined with anisotropic two color look.
Core/RefCanvasUniDiffuseMat Assignment of material's diffuse color to fragment color Core/RefCanvasTransUniDiffuseMat See configuration
Effects/RefFxaa Coordinates in normalized device space. Effects/RefFxaa See configuration of Effects/RefFxaa Applies the "Fast approximate anti-aliasing" algorithm to its input, which should be a quad using normalized device coordinates. The uniform (u_Resolution) needs to be set to the width and height of the input texture measured in texels.
Effects/RefGradientLinear Mixing fragment color according to gradient computations. Effects/RefTransGradientLinear See configuration
Fragment Shader for linear gradient computations.
Effects/RefGradientRadial Assignment of radial gradient color to fragment color. Effects/RefTransGradientRadial See configuration
Fragment Shader for radial gradient computations.
Core/RefColorTexAlpha, Assignment of product of varying color and texture color to fragment color. Core/RefTransColor See configuration RefTransColor This fragment shader shall be used for text or alpha mask rendering.
Effects/RefColorTexAlphaOutline This fragment shader renders an outline of color "u_outlineColor" and width specified by
"u_outlineWidth" around the contents in the texture "u_Texture". The input texture is also
multiplied by the vertex color. If the "u_outlineWidth" value is bigger than 10, the contents
of the texture need be bigger than 10 too, otherwise artefacts will start to appear with increasing
outline width.
There is no instancing version of this shader, because it will usually be applied to text
rendering which is batched by Canvas rather than the Renderer.
Additionally:
SetTexelSizeActivationEnabled(true)
Custom uniforms:
uniform vec4 u_outlineColor; // Color of outline.
uniform float u_outlineWidth; //Width of outline.
This fragment shader shall be used if a text or an alpha mask shall receive an outline.
