Candera MISRA Compliance
Candera tries to be MISRA compliant as much as possible. For checking MISRA compliance, PC-Lint together with the supported MISRA rule set is used. For some reasons we cannot fulfil all MISRA rules, a set of Candera Misra Rules for PcLint is disabled due tu explained reasons.
The following file is taken from the PcLint distribution lnt/au-misra-cpp.lnt and is slightly modified for the needs of Candera.
- All the rules are left in as-is state and therefore they are enabled.
- Disabled rules can be identified as they are commented out or configured with '-esym(1960,...)' or '-esym(1963,...)'.
/* Date Stamp */ -d"_lint_au_misra_cpp_lnt=au-misra-cpp.lnt modified 12-Jun-2014" /* To document usage use: -message( "Using " _lint_au_misra_cpp_lnt ) */ // --------------------------------------------------------------------- // This file is provided by Gimpel Software (www.gimpel.com) for use with // its products PC-lint and FlexeLint. // // Redistribution and use of this file, with or without modification, is // permitted provided that any such redistribution retains this notice. // --------------------------------------------------------------------- // au-misra-cpp.lnt -- Author options - MISRA C++ /* This options file can be used to explicitly activate those checks advocated by the Motor Industry Software Reliability Association for C++ code. You can use this file directly when linting your programs as in: lin au-misra-cpp files Gimpel Software relies on the document, "MISRA-C++:2008 Guidelines for the use of the C++ language in critical systems", copyright 2008 by MIRA Limited, as the primary source for this file. Gimpel Software makes no warranty as to the completeness or applicability of this options file and reserves the right to amend or alter the official contents of such at any time. "MISRA" is a registered trademark of MIRA Limited, held on behalf of the MISRA Consortium. */ // ----- Candera modification ----- // Removing all the normal Lint errors and warnings -e830 // Location cited in prior message -e831 // Reference cited in prior messages (is not removed by -e*) -e686 // Removing warning 686: Option '-e*' is suspicious because of 'blanket suppression, which comes for every file -e* // -------------------------------- -misra(C++) +e1960 /* enable special MISRA messages */ +elib(1960) +e1963 /* enable special MISRA messages */ +elib(1963) /* Rule 0-1-1 (req) *********************************/ +e527 /* unreachable */ +elib(527) -append(527,[MISRA C++ Rule 0-1-1]) +e506 /* constant value boolean */ +elib(506) -append(506,[MISRA C++ Rule 0-1-1]) +e681 /* loop not entered */ +elib(681) -append(681,[MISRA C++ Rule 0-1-1]) +e827 /* loop not reachable */ +elib(827) -append(827,[MISRA C++ Rule 0-1-1]) +e685 /* relational operator always evaluates to true/false */ +elib(685) -append(685,[MISRA C++ Rule 0-1-1]) +e774 /* boolean always evaluates to true/false */ +elib(774) -append(774,[MISRA C++ Rule 0-1-1]) +e944 /* argument always evaluates to ... */ +elib(944) -append(944,[MISRA C++ Rule 0-1-1]) /* Rule 0-1-2 (req) *********************************/ +e685 /* relational operator always evaluates to true/false */ +elib(685) -append(685,[MISRA C++ Rule 0-1-2]) +e774 /* boolean always evaluates to true/false */ +elib(774) -append(774,[MISRA C++ Rule 0-1-2]) +e827 /* loop not reachable */ +elib(827) -append(827,[MISRA C++ Rule 0-1-2]) +e944 /* argument always evaluates to ... */ +elib(944) -append(944,[MISRA C++ Rule 0-1-2]) /* Rule 0-1-3 (req) *********************************/ +e528 /* symbol not referenced */ +elib(528) -append(528,[MISRA C++ Rule 0-1-3]) +e529 /* symbol not referenced */ +elib(529) -append(529,[MISRA C++ Rule 0-1-3]) +e714 /* symbol not referenced */ +elib(714) -append(714,[MISRA C++ Rule 0-1-3]) +e752 /* local declarator not referenced */ +elib(752) -append(752,[MISRA C++ Rule 0-1-3]) +e757 /* global declarator not referenced */ +elib(757) -append(757,[MISRA C++ Rule 0-1-3]) /* Rule 0-1-4 (req) *********************************/ +e528 /* symbol not referenced */ +elib(528) -append(528,[MISRA C++ Rule 0-1-4]) +e529 /* symbol not referenced */ +elib(529) -append(529,[MISRA C++ Rule 0-1-4]) +e550 /* symbol not accessed */ +elib(550) -append(550,[MISRA C++ Rule 0-1-4]) +e551 /* symbol not accessed */ +elib(551) -append(551,[MISRA C++ Rule 0-1-4]) +e552 /* symbol not accessed */ +elib(552) -append(552,[MISRA C++ Rule 0-1-4]) /* Rule 0-1-5 (req) *********************************/ +e751 /* local typedef not referenced */ +elib(751) -append(751,[MISRA C++ Rule 0-1-5]) +e753 /* local tag not referenced */ +elib(753) -append(753,[MISRA C++ Rule 0-1-5]) +e756 /* global typedef not referenced */ +elib(756) -append(756,[MISRA C++ Rule 0-1-5]) +e758 /* global tag not referenced */ +elib(758) -append(758,[MISRA C++ Rule 0-1-5]) /* Rule 0-1-6 (req) *********************************/ +e438 /* variable's last value not used */ +elib(438) -append(438,[MISRA C++ Rule 0-1-6]) /* Rule 0-1-7 (req) *********************************/ +e534 /* return value ignored */ +elib(534) -append(534,[MISRA C++ Rule 0-1-7]) /* Rule 0-1-8 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 0-1-8, Void return type for function without external side-effects */ -esym(1960, 0-1-8) /* Rule 0-1-9 (req) *********************************/ +e438 /* variable's last value not used */ +elib(438) -append(438,[MISRA C++ Rule 0-1-9]) +e587 /* predicate always evaluates to ... */ +elib(587) -append(587,[MISRA C++ Rule 0-1-9]) +e685 /* relational operator always evaluates to true/false */ +elib(685) -append(685,[MISRA C++ Rule 0-1-9]) +e774 /* boolean always evaluates to true/false */ +elib(774) -append(774,[MISRA C++ Rule 0-1-9]) +e838 /* previous value not used */ +elib(838) -append(838,[MISRA C++ Rule 0-1-9]) +e944 /* argument always evaluates to ... */ +elib(944) -append(944,[MISRA C++ Rule 0-1-9]) +e948 /* operator always evaluates to ... */ +elib(948) -append(948,[MISRA C++ Rule 0-1-9]) /* Rule 0-1-10 (req) *********************************/ +e528 /* symbol not referenced */ +elib(528) -append(528,[MISRA C++ Rule 0-1-10]) +e714 /* symbol not referenced */ +elib(714) -append(714,[MISRA C++ Rule 0-1-10]) +e1714 /* member function not referenced */ +elib(1714) -append(1714,[MISRA C++ Rule 0-1-10]) +e1716 /* virtual member function not referenced */ +elib(1716) -append(1716,[MISRA C++ Rule 0-1-10]) +e1914 /* default constructor not referenced */ +elib(1914) -append(1914,[MISRA C++ Rule 0-1-10]) /* Rule 0-1-11 (req) *********************************/ +e715 /* symbol not referenced */ +elib(715) -append(715,[MISRA C++ Rule 0-1-11]) /* Rule 0-1-12 (req) *********************************/ +e715 /* symbol not referenced */ +elib(715) -append(715,[MISRA C++ Rule 0-1-12]) /* Rule 0-2-1 (req) *********************************/ /* See rule 9-5-1. */ /* Rule 0-3-1 (doc) *********************************/ /* Automatically accomplished by using PC-lint/FlexeLint */ /* Rule 0-3-2 (req) *********************************/ +e534 /* return value ignored */ +elib(534) -append(534,[MISRA C++ Rule 0-3-2]) /* Rule 0-4-1 (doc) *********************************/ /* not statically checkable */ /* Rule 0-4-2 (doc) *********************************/ /* not statically checkable */ /* Rule 0-4-3 (doc) *********************************/ /* not statically checkable */ /* Rule 1-0-1 (req) *********************************/ -A(C++2003) /* ensure ISO C++ 2003 compliance */ /* Rule 1-0-2 (req) *********************************/ /* not statically checkable */ /* Rule 1-0-3 (doc) *********************************/ /* not statically checkable */ /* Rule 2-2-1 (doc) *********************************/ /* not statically checkable */ /* Rule 2-3-1 (req) *********************************/ -ftg +e584 /* trigraph sequence detected */ +elib(584) -append(584,[MISRA C++ Rule 2-3-1]) +e739 /* trigraph sequence in literal */ +elib(739) -append(739,[MISRA C++ Rule 2-3-1]) /* Rule 2-5-1 (adv) *********************************/ /* we generate note 1963 as follows Note 1963: Violates MISRA C++ Required Rule 2-5-1, Possible digraph */ /* Rule 2-7-1 (req) *********************************/ -fnc +e602 /* comment within comment */ +elib(602) -append(602,[MISRA C++ Rule 2-7-1]) /* Rule 2-7-2 (req) *********************************/ /* not statically checkable */ /* Rule 2-7-3 (adv) *********************************/ /* not statically checkable */ /* Rule 2-10-1 (req) *********************************/ +e620 /* suspicious constant */ +elib(620) -append(620,[MISRA C++ Rule 2-10-1]) /* Rule 2-10-2 (req) *********************************/ // Disable - many false positives (different namespaces) // +e578 /* declaration hides symbol */ // +elib(578) // -append(578,[MISRA C++ Rule 2-10-2]) +e1411 /* hidden virtual member */ +elib(1411) -append(1411,[MISRA C++ Rule 2-10-2]) +e1511 /* hidden non-virtual member */ +elib(1511) -append(1511,[MISRA C++ Rule 2-10-2]) +e1516 /* member hides member */ +elib(1516) -append(1516,[MISRA C++ Rule 2-10-2]) +e1737 /* hidden operator new */ +elib(1737) -append(1737,[MISRA C++ Rule 2-10-2]) +e1761 /* hidden overloaded function */ +elib(1761) -append(1761,[MISRA C++ Rule 2-10-2]) /* Rule 2-10-3 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 2-10-3, Typedef is not a unique declarator */ /* Rule 2-10-4 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 2-10-4, Tag is not a unique declarator */ /* Rule 2-10-5 (adv) *********************************/ /* we generate note 1963 as follows Note 1963: Violates MISRA C++ Advisory Rule 2-10-5, Identifier with static storage is reused */ /* Rule 2-10-6 (req) *********************************/ +e18 /* redeclaration */ +elib(18) -append(18,[MISRA C++ Rule 2-10-6]) /* Rule 2-13-1 (req) *********************************/ +e606 /* non-ANSI escape sequence */ +elib(606) -append(606,[MISRA C++ Rule 2-13-1]) /* Rule 2-13-2 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 2-13-2, Octal constant used */ /* Rule 2-13-3 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 2-13-3, Unsigned octal and hexadecimal literals require a 'U' suffix */ -esym(1960, 2-13-3) /* Rule 2-13-4 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 2-13-4, Lower case literal suffix */ +e620 /* suspicious constant */ +elib(620) -append(620,[MISRA C++ Rule 2-13-4]) /* Rule 2-13-5 (req) *********************************/ +e707 /* mixing narrow and wide string literals in concatenation */ +elib(707) -append(707,[MISRA C++ Rule 2-13-5]) /* Rule 3-1-1 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 3-1-1, no object/function definitions in header files */ -esym(1960, 3-1-1) /* Rule 3-1-2 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 3-1-2, function not declared at file scope */ /* Rule 3-1-3 (req) *********************************/ +e85 /* zero-dimensioned array */ +elib(85) -append(85,[MISRA C++ Rule 3-1-3]) /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 3-1-3. extern array declared without size or initializer */ /* Rule 3-2-1 (req) *********************************/ +e18 /* redeclaration */ +elib(18) -append(18,[MISRA C++ Rule 3-2-1]) +e31 /* redefinition */ +elib(31) -append(31,[MISRA C++ Rule 3-2-1]) /* Rule 3-2-2 (req) *********************************/ +e15 /* redeclaration */ +elib(15) -append(15,[MISRA C++ Rule 3-2-2]) +e31 /* redefinition */ +elib(31) -append(31,[MISRA C++ Rule 3-2-2]) /* Rule 3-2-3 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 3-2-3, Object/function type previously declared in location */ -esym(1960, 3-2-3) /* Rule 3-2-4 (req) *********************************/ +e15 /* redeclaration */ +elib(15) -append(15,[MISRA C++ Rule 3-2-4]) +e31 /* redefinition */ +elib(31) -append(31,[MISRA C++ Rule 3-2-4]) /* Rule 3-3-1 (req) *********************************/ +e759 /* could move declaration to module */ +elib(759) -append(759,[MISRA C++ Rule 3-3-1]) +e765 /* could be made static */ +elib(765) -append(765,[MISRA C++ Rule 3-3-1]) /* Rule 3-3-2 (req) *********************************/ +e401 /* not previously declared static */ +elib(401) -append(401,[MISRA C++ Rule 3-3-2]) +e512 /* previously used as static */ +elib(512) -append(512,[MISRA C++ Rule 3-3-2]) /* Rule 3-4-1 (req) *********************************/ /* not currently supported */ /* Rule 3-9-1 (req) *********************************/ /* not currently supported */ /* Rule 3-9-2 (adv) *********************************/ +e970 /* type or modifier outside of typedef */ +elib(970) -esym(970,wchar_t) -append(970,[MISRA C++ Rule 3-9-2]) // For the duration, we are presuming MISRA does not want // diagnostics for the bool type. -esym(970,bool) /* Rule 3-9-3 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 3-9-3, Bit representation of a floating point type used */ /* Rule 4-5-1 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 4-5-1, Boolean expression used with non-permitted operator */ /* Rule 4-5-2 (req) *********************************/ /* not currently supported */ /* Rule 4-5-3 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 4-5-3, Plain char used with prohibited operator */ -esym(1960, 4-5-3) /* Rule 4-10-1 (req) *********************************/ /* not currently supported */ /* Rule 4-10-2 (req) *********************************/ // Remains disabled, see Scott Myers "Effective C++", Item 25 // +e910 /* conversion from 0 to pointer */ // +elib(910) -emacro((910), NULL) /* explicit exception */ // -append(910,[MISRA C++ Rule 4-10-2]) /* Rule 5-0-1 (req) *********************************/ +e564 /* order of evaluation */ +elib(564) -append(564,[MISRA C++ Rule 5-0-1]) +e864 /* order of evaluation */ +elib(864) -append(864,[MISRA C++ Rule 5-0-1]) /* Rule 5-0-2 (adv) *********************************/ +e834 /* confusing operator sequence (same precedence) */ +elib(834) -append(834,[MISRA C++ Rule 5-0-2]) -esym(1963, 5-0-2) /* Rule 5-0-3 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 5-0-3, Implicit conversion of integer/floating point cvalue expression */ /* Rule 5-0-4 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 5-0-4, Implicit conversion changes signedness */ -esym(1960, 5-0-4) /* Rule 5-0-5 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 5-0-5, Implicit conversion from integer/floating point to floating point/integer type */ /* Rule 5-0-6 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 5-0-6, Implicit conversion of integer/floating point to smaller type */ -esym(1960, 5-0-6) /* Rule 5-0-7 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 5-0-7, Cast of cvalue expression from integer/floating point to floating point/integer type */ -esym(1960, 5-0-7) /* Rule 5-0-8 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 5-0-8, Cast of integer/floating point cvalue expression to larger type */ -esym(1960, 5-0-8) /* Rule 5-0-9 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 5-0-9, Cast of cvalue expression changes signedness */ -esym(1960, 5-0-9) /* Rule 5-0-10 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 5-0-10, Operators '~' and '<<' require recasting to underlying type for sub-integers */ /* Rule 5-0-11 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 5-0-11, Disallowed use of non-character value, or Plain char mixed with type other than plain char */ /* Rule 5-0-12 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 5-0-12, Disallowed use of non-numeric value */ /* Rule 5-0-13 (req) *********************************/ +e909 /* conversion to bool */ +elib(909) -append(909,[MISRA C++ Rule 5-0-13]) /* Rule 5-0-14 (req) *********************************/ +e909 /* conversion to bool */ +elib(909) -append(909,[MISRA C++ Rule 5-0-14]) /* Rule 5-0-15 (req) *********************************/ +e946 /* relational or subtract operator applied to pointers */ +elib(946) -append(946,[MISRA C++ Rule 5-0-15]) +e947 /* subtract operator applied to pointers */ +elib(947) -append(947,[MISRA C++ Rule 5-0-15]) /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 5-0-15, Pointer arithmetic other than array indexing used, or Pointer arithmetic by increment or decrement used */ -esym(1960, 5-0-15) /* Rule 5-0-16 (req) *********************************/ +e415 /* out-of-bounds pointer */ +elib(415) -append(415,[MISRA C++ Rule 5-0-16]) +e416 /* out-of-bounds pointer */ +elib(416) -append(416,[MISRA C++ Rule 5-0-16]) +e661 /* out-of-bounds pointer */ +elib(661) -append(661,[MISRA C++ Rule 5-0-16]) +e662 /* out-of-bounds pointer */ +elib(662) -append(662,[MISRA C++ Rule 5-0-16]) +e796 /* out-of-bounds pointer */ +elib(796) -append(796,[MISRA C++ Rule 5-0-16]) +e797 /* out-of-bounds pointer */ +elib(797) -append(797,[MISRA C++ Rule 5-0-16]) /* Rule 5-0-17 (req) *********************************/ +e946 /* relational or subtract operator applied to pointers */ +elib(946) -append(946,[MISRA C++ Rule 5-0-17]) +e947 /* subtract operator applied to pointers */ +elib(947) -append(947,[MISRA C++ Rule 5-0-17]) /* Rule 5-0-18 (req) *********************************/ +e946 /* relational or subtract operator applied to pointers */ +elib(946) -append(946,[MISRA C++ Rule 5-0-18]) +e947 /* subtract operator applied to pointers */ +elib(947) -append(947,[MISRA C++ Rule 5-0-18]) /* Rule 5-0-19 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 5-0-19, More than two pointer indirection levels used */ /* Rule 5-0-20 (req) *********************************/ /* not currently supported */ /* Rule 5-0-21 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 5-0-21, Bitwise operator applied to signed underlying type */ /* Rule 5-2-1 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 5-2-1, Non-postfix expression used with logical operator */ /* Rule 5-2-2 (req) *********************************/ +e1774 /* could use dynamic_cast */ +elib(1774) -append(1774,[MISRA C++ Rule 5-2-2]) +e1939 /* down_cast used */ +elib(1939) -append(1939,[MISRA C++ Rule 5-2-2]) /* Rule 5-2-3 (adv) *********************************/ /* not currently supported */ /* Rule 5-2-4 (req) *********************************/ +e1924 /* C-style cast */ +elib(1924) -append(1924,[MISRA C++ Rule 5-2-4]) /* Rule 5-2-5 (req) *********************************/ +e1773 /* casting away const/volatile */ +elib(1773) -append(1773,[MISRA C++ Rule 5-2-5]) /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 5-2-5, Attempt to cast away const/volatile from a pointer or reference */ -esym(1960, 5-2-5) /* Rule 5-2-6 (req) *********************************/ +e611 /* suspicious cast */ +elib(611) -append(611,[MISRA C++ Rule 5-2-6]) /*+e740*/ /* unusual cast */ /*deliberately not prohibited, shall be avoided*/ /*+elib(740)*/ /*-append(740,[MISRA C++ Rule 5-2-6])*/ /* Rule 5-2-7 (req) *********************************/ +e740 /* unusual cast */ +elib(740) -append(740,[MISRA C++ Rule 5-2-7]) +e916 /* pointer assignment conversion */ +elib(916) -append(916,[MISRA C++ Rule 5-2-7]) +e918 /* prototype coercion */ +elib(918) -append(918,[MISRA C++ Rule 5-2-7]) +esym(920,pointer) /* implicit conversion */ +elib(920) -append(920,[MISRA C++ Rule 5-2-7]) /*+e923*/ /* cast */ /*deliberately not prohibited, shall be avoided*/ /*+elib(923)*/ /*-append(923,[MISRA C++ Rule 5-2-7])*/ /*+e926*/ /* pointer cast */ /*deliberately not prohibited, shall be avoided*/ /*+elib(926)*/ /*-append(926,[MISRA C++ Rule 5-2-7])*/ /*+e927*/ /* pointer cast */ /*deliberately not prohibited, shall be avoided*/ /*+elib(927)*/ /*-append(927,[MISRA C++ Rule 5-2-7])*/ /*+e928*/ /* pointer cast */ /*deliberately not prohibited, shall be avoided*/ /*+elib(928)*/ /*-append(928,[MISRA C++ Rule 5-2-7])*/ /*+e929*/ /* pointer cast */ /*deliberately not prohibited, shall be avoided*/ /*+elib(929)*/ /*-append(929,[MISRA C++ Rule 5-2-7])*/ /*+e930*/ /* cast */ /*+elib(930)*/ /*-append(930,[MISRA C++ Rule 5-2-7])*/ /* Rule 5-2-8 (adv) *********************************/ +estring(64,ptrs to void/nonvoid) +e923 /* cast */ +elib(923) -append(923,[MISRA C++ Rule 5-2-8]) +e925 /* cast */ +elib(925) -append(925,[MISRA C++ Rule 5-2-8]) +esym(930,pointer) /* cast */ +elib(930) -append(930,[MISRA C++ Rule 5-2-8]) /* Rule 5-2-9 (adv) *********************************/ +e925 /* cast */ +elib(925) -append(925,[MISRA C++ Rule 5-2-9]) +esym(930,pointer) /* cast */ +elib(930) -append(930,[MISRA C++ Rule 5-2-9]) /* Rule 5-2-10 (adv) *********************************/ +e564 /* order of evaluation */ +elib(564) -append(564,[MISRA C++ Rule 5-2-10]) +e591 /* order of evaluation */ +elib(591) -append(591,[MISRA C++ Rule 5-2-10]) +e864 /* order of evaluation */ +elib(864) -append(864,[MISRA C++ Rule 5-2-10]) /* we generate note 1963 as follows Note 1963: Violates MISRA C++ Advisory Rule 5-2-10, Increment or decrement combined with another operator */ -esym(1963, 5-2-10) /* Rule 5-2-11 (req) *********************************/ +e1753 /* operator overloaded */ +elib(1753) -append(1753,[MISRA C++ Rule 5-2-11]) /* Rule 5-2-12 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 5-2-12, Array type passed to function expecting a pointer */ -esym(1960, 5-2-12) /* Rule 5-3-1 (req) *********************************/ +e909 /* conversion to bool */ +elib(909) -append(909,[MISRA C++ Rule 5-3-1]) /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 5-3-1, Boolean expression required for operator */ /* Rule 5-3-2 (req) *********************************/ +e501 /* expected signed type */ +elib(501) -append(501,[MISRA C++ Rule 5-3-2]) /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 5-3-2, Prohibited operator applied to unsigned underlying type: - */ /* Rule 5-3-3 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 5-3-3, Unary operator & overloaded */ /* Rule 5-3-4 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 5-3-4, 'sizeof' used on expressions with side effect */ /* Rule 5-8-1 (req) *********************************/ +e572 /* excessive shift value */ +elib(572) -append(572,[MISRA C++ Rule 5-8-1]) /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 5-8-1, out of bounds value for right hand side of shift operator */ /* Rule 5-14-1 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 5-14-1, side effects on right hand side of logical operator */ -esym(1960, 5-14-1) /* Rule 5-17-1 (req) *********************************/ /* not currently supported */ /* Rule 5-18-1 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 5-18-1, comma operator used */ /* Rule 5-19-1 (adv) *********************************/ +e648 /* overflow in computing constant */ +elib(648) -append(648,[MISRA C++ Rule 5-19-1]) /* Rule 6-2-1 (req) *********************************/ +e720 /* Boolean test of assignment */ +elib(720) -append(720,[MISRA C++ Rule 6-2-1]) +e820 /* boolean test of parenthesized assignment */ +elib(820) -append(820,[MISRA C++ Rule 6-2-1]) /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 6-2-1, assignment operator used in sub-expression */ /* Rule 6-2-2 (req) *********************************/ +e777 /* testing floats for equality */ +elib(777) -append(777,[MISRA C++ Rule 6-2-2]) /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 6-2-2, floating point test for equality or inequality */ -esym(1960, 6-2-2) /* Rule 6-2-3 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 6-2-3, null statement not in line by itself */ -esym(1960, 6-2-3) /* Rule 6-3-1 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 6-3-1, left brace expected for switch, while, do...while, and for */ /* Rule 6-4-1 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 6-4-1, left brace expected for if and else */ /* Rule 6-4-2 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 6-4-2, no 'else' at end of 'if ... else if' chain */ /* Rule 6-4-3 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 6-4-3, departure from MISRA switch syntax */ /* Rule 6-4-4 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 6-4-4, most closely enclosing compound statement of a case/default is not of a switch */ /* Rule 6-4-5 (req) *********************************/ +e616 /* control flows into case/default */ +elib(616) -append(616,[MISRA C++ Rule 6-4-5]) +e825 /* control flows into case/default without -fallthrough */ +elib(825) -append(825,[MISRA C++ Rule 6-4-5]) /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 6-4-5, missing unconditional break from switch case */ /* Rule 6-4-6 (req) *********************************/ +e744 /* switch statement has no default */ +elib(744) -append(744,[MISRA C++ Rule 6-4-6]) /* we also generate note 1960 as follows: Note 1960: Violates MISRA C++ Required Rule 6-4-6, case label follows default in switch statement */ /* Rule 6-4-7 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 6-4-7, boolean value in switch statement */ /* Rule 6-4-8 (req) *********************************/ +e764 /* no case */ +elib(764) -append(764,[MISRA C++ Rule 6-4-8]) /* Rule 6-5-1 (req) *********************************/ /* not currently supported */ /* Rule 6-5-2 (req) *********************************/ /* not currently supported */ /* Rule 6-5-3 (req) *********************************/ +e850 /* loop variable modified in body */ +elib(850) -append(850,[MISRA C++ Rule 6-5-3]) /* Rule 6-5-4 (req) *********************************/ /* not currently supported */ /* Rule 6-5-5 (req) *********************************/ /* not currently supported */ /* Rule 6-5-6 (req) *********************************/ /* not currently supported */ /* Rule 6-6-1 (req) *********************************/ /* not currently supported */ /* Rule 6-6-2 (req) *********************************/ +e107 /* label not defined */ +elib(107) -append(107,[MISRA C++ Rule 6-6-2]) /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 6-6-2, Goto jumps to an earlier point in the code */ /* Rule 6-6-3 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 6-6-3, continue statement detected */ -esym(1960, 6-6-3) /* Rule 6-6-4 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 6-6-4, more than one 'break' terminates loop */ -esym(1960, 6-6-4) /* Rule 6-6-5 (req) *********************************/ /* Deliberately disabled: Readability, Maintenance, Performance */ // +e904 /* return before function end */ // +elib(904) // -append(904,[MISRA C++ Rule 6-6-5]) /* Rule 7-1-1 (req) *********************************/ /* Deliberately disabled: Cost - Value ratio is negative */ // +e952 /* use const if read-only variable */ // +elib(952) // -append(952,[MISRA C++ Rule 7-1-1]) /* Rule 7-1-2 (req) *********************************/ +e818 /* use const on paramaters where appropriate */ +elib(818) -append(818,[MISRA C++ Rule 7-1-2]) /* Rule 7-2-1 (req) *********************************/ /* not currently supported */ /* Rule 7-3-1 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 7-3-1, Global declaration */ /* Rule 7-3-2 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 7-3-2, Non-global function, main, declared */ /* Rule 7-3-3 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 7-3-3, Unnamed namespace in header */ /* Rule 7-3-4 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 7-3-4, Using-directive used */ -esym(1960, 7-3-4) /* Rule 7-3-5 (req) *********************************/ /* not currently supported */ /* Rule 7-3-6 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 7-3-6, Using-directive/declaration in header file */ /* Rule 7-4-1 (doc) *********************************/ /* not statically checkable */ /* Rule 7-4-2 (req) *********************************/ /* only use the asm declaration to introduce assembly code */ -rw(_asm) -rw(__asm) -pragma(asm) -pragma(endasm) -ppw(asm) -ppw(endasm) /* Rule 7-4-3 (req) *********************************/ /* not currently supported */ /* Rule 7-5-1 (req) *********************************/ +e604 /* returning address of auto variable */ +elib(604) -append(604,[MISRA C++ Rule 7-5-1) /* Rule 7-5-2 (req) *********************************/ +e789 /* assigning auto address to static */ +elib(789) -append(789,[MISRA C++ Rule 7-5-2]) +e604 /* returning address of auto variable */ +elib(604) -append(604,[MISRA C++ Rule 7-5-2]) /* Rule 7-5-3 (req) *********************************/ +e1780 /* returning address of reference to a const parameter */ +elib(1780) -append(1780,[MISRA C++ Rule 7-5-3]) +e1940 /* address of reference parameter transferred outside of function */ +elib(1940) -append(1940,[MISRA C++ Rule 7-5-3]) /* Rule 7-5-4 (req) *********************************/ /* Deliberately disabled: Selected justified recursions contribute to readability and maintenance. */ // +stack() // +estring(974,*recursive*) /* worst case stack usage */ // -append(974,[MISRA C++ Rule 7-5-4]) /* Rule 8-0-1 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 8-0-1, Multiple declarators in a declaration */ /* Rule 8-3-1 (req) *********************************/ +e1735 /* virtual function has default parameter */ +elib(1735) -append(1735,[Potentially Violates MISRA C++ Rule 8-3-1]) /* Rule 8-4-1 (req) *********************************/ +e1916 /* ellipsis */ +elib(1916) -append(1916,[MISRA C++ Rule 8-4-1]) /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 8-4-1, Function has variable number of arguments */ -esym(1960, 8-4-1) /* Rule 8-4-2 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 8-4-2, Function parameter list differs */ /* Rule 8-4-3 (req) *********************************/ +e533 /* missing/extraneous return value */ +elib(533) -append(533,[MISRA C++ Rule 8-4-3]) /* Rule 8-4-4 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 8-4-4, Function identifier used without & or parenthesized parameter list */ -esym(1960, 8-4-4) /* Rule 8-5-1 (req) *********************************/ +e530 /* symbol not initialized */ +elib(530) -append(530,[MISRA C++ Rule 8-5-1]) +e1744 /* possibly not initialized */ +elib(1744) -append(1744,[MISRA C++ Rule 8-5-1]) +e1401 /* member not initialized */ +elib(1401) -append(1401,[MISRA C++ Rule 8-5-1]) /* Rule 8-5-2 (req) *********************************/ +e940 /* omitted braces */ +elib(940) -append(940,[MISRA C++ Rule 8-5-2]) /* Rule 8-5-3 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 8-5-3, should initialize either all enum members or only the first */ /* Rule 9-3-1 (req) *********************************/ /* Deliberately disabled: Not critical and inconsistent proof (SmartPointers are allowed). Const indicates that function does not change object. Critical situations are covered by compiler anyway. */ // +e605 /* increase in pointer capability */ // +elib(605) // -append(605,[MISRA C++ Rule 9-3-1]) // +e1536 /* exposing member */ // +elib(1536) // -append(1536,[MISRA C++ Rules 9-3-1]) // +e1763 /* const function modifies member */ // +elib(1763) // -append(1763,[MISRA C++ Rule 9-3-1]) /* Rule 9-3-2 (req) *********************************/ /* Deliberately disabled: Not critical. Const indicates that function does not change object. */ // +e1536 /* exposing member */ // +elib(1536) // -append(1536,[MISRA C++ Rules 9-3-2]) /* Rule 9-3-3 (req) *********************************/ +e1762 /* member could be const */ +elib(1762) -append(1762,[MISRA C++ Rule 9-3-3]) /* Rule 9-5-1 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 9-5-1, unions shall not be used */ -esym(1960, 9-5-1) /* Rule 9-6-1 (doc) *********************************/ /* not statically checkable */ /* Rule 9-6-2 (req) *********************************/ +e46 /* bit field should be int */ +elib(46) -append(46,[MISRA C++ Rule 9-6-2]) /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 9-6-2, Bit field must be explicitly signed int, unsigned int, or bool */ /* Rule 9-6-3 (req) *********************************/ +e46 /* bit field should be int */ +elib(46) -append(46,[MISRA C++ Rule 9-6-3]) /* Rule 9-6-4 (req) *********************************/ +e806 /* signed small bit field */ +elib(806) -append(806,[MISRA C++ Rule 9-6-4]) /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 9-6-4, Signed bit field is too small */ /* Rule 10-1-1 (adv) *********************************/ +e1749 /* base class need not be virtual */ +elib(1749) -append(1749,[MISRA C++ Rule 10-1-1]) /* Rule 10-1-2 (req) *********************************/ /* not currently supported */ /* Rule 10-1-3 (req) *********************************/ +e1748 /* multiple inclusion of non-virtual base class */ +elib(1748) -append(1748,[MISRA C++ Rule 10-1-3]) /* Rule 10-2-1 (adv) *********************************/ /* not currently supported */ /* Rule 10-3-1 (req) *********************************/ /* not currently supported */ /* Rule 10-3-2 (req) *********************************/ +e1909 /* 'virtual' assumed */ +elib(1909) -append(1909,[MISRA C++ Rule 10-3-2]) /* Rule 10-3-3 (req) *********************************/ /* not currently supported */ /* Rule 11-0-1 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 11-0-1, Non-private data member within a non-POD structure */ -esym(1960, 11-0-1) /* Rule 12-1-1 (req) *********************************/ +e1506 /* virtual function called inside constructor */ +elib(1506) -append(1506,[MISRA C++ Rule 12-1-1]) /* Rule 12-1-2 (adv) *********************************/ // +e1928 /* symbol not in constructor initializer list */ // +elib(1928) // -append(1928,[MISRA C++ Rule 12-1-2]) /* Rule 12-1-3 (req) *********************************/ /* not currently supported */ /* Rule 12-8-1 (req) *********************************/ +e1938 /* constructor access global data */ +elib(1938) -append(1938,[MISRA C++ Rule 12-8-1]) /* Rule 12-8-2 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 12-8-2, Public copy constructor in abstract class */ /* Rule 14-5-1 (req) *********************************/ +e1573 /* generic function template declared in namespace associated with type */ +elib(1573) -append(1573,[MISRA C++ Rule 14-5-1]) /* Rule 14-5-2 (req) *********************************/ +e1789 /* template constructor cannot be copy constructor */ +elib(1789) -append(1789,[MISRA C++ Rule 14-5-2]) /* Rule 14-5-3 (req) *********************************/ +e1721 /* non-assignment operator=() */ +elib(1721) -append(1721,[MISRA C++ Rule 14-5-3]) /* Rule 14-6-1 (req) *********************************/ +e1942 /* possible misinterpretation of name */ +elib(1942) -append(1942,[MISRA C++ Rule 14-6-1]) /* Rule 14-6-2 (req) *********************************/ /* awaiting clarification from MISRA */ /* Rule 14-7-1 (req) *********************************/ +e1795 /* template not instantiated */ +elib(1795) -append(1795,[MISRA C++ Rule 14-7-1]) /* Rule 14-7-2 (req) *********************************/ /* not currently supported */ /* Rule 14-7-3 (req) *********************************/ +e1576 /* specialization occurs in different file than template definition */ +elib(1576) -append(1576,[MISRA C++ Rule 14-7-3]) +e1577 /* specialization occurs in different file than template definition */ +elib(1577) -append(1577,[MISRA C++ Rule 14-7-3]) /* Rule 14-8-1 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 14-8-1, Explicit specialization of overloaded function templates */ /* Rule 14-8-2 (adv) *********************************/ /* we generate note 1963 as follows Note 1963: Violates MISRA C++ Advisory Rule 14-8-2, Viable set contains both function and template */ /* Rule 15-0-1 (doc) *********************************/ /* not statically checkable */ /* Rule 15-0-2 (adv) *********************************/ /* we generate note 1963 as follows Note 1963: Violates MISRA C++ Advisory Rule 15-0-2, dependence placed on C's operator precedence */ /* Rule 15-0-3 (req) *********************************/ +estring(646,try,catch) /* misplaced case? */ -append(646,[MISRA C++ Rule 15-0-3]) /* Rule 15-1-1 (req) *********************************/ /* not currently supported */ /* Rule 15-1-2 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 15-1-2, Explicit throw of the NULL macro */ /* Rule 15-1-3 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 15-1-3, Empty throw outside of a catch block */ /* Rule 15-3-1 (req) *********************************/ +e1546 /* throw() inside destructor */ +elib(1546) -append(1546,[MISRA C++ Rule 15-3-1]) /* Rule 15-3-2 (adv) *********************************/ /* not currently supported */ /* Rule 15-3-3 (req) *********************************/ /* not currently supported */ /* Rule 15-3-4 (req) *********************************/ +e1560 /* uncaught exception */ +elib(1560) -append(1560,[MISRA C++ Rule 15-3-4]) /* Rule 15-3-5 (req) *********************************/ +e1752 /* non-reference catch parameter */ +elib(1752) -append(1752,[MISRA C++ Rule 15-3-5]) /* Rule 15-3-6 (req) *********************************/ /* not currently supported */ /* Rule 15-3-7 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 15-3-7, Catch handler after catch(...) */ /* Rule 15-4-1 (req) *********************************/ +e1548 /* conflicting exception specifications */ +elib(1548) -append(1548,[MISRA C++ Rule 15-4-1]) /* Rule 15-5-1 (req) *********************************/ +e1546 /* throw() inside destructor */ +elib(1546) -append(1546,[MISRA C++ Rule 15-5-1]) +e1559 /* uncaught exception */ +elib(1559) -append(1559,[MISRA C++ Rule 15-5-1]) /* Rule 15-5-2 (req) *********************************/ +e1549 /* exception thrown in no-throw function */ +elib(1549) -append(1549,[MISRA C++ Rule 15-5-2]) /* Rule 15-5-3 (req) *********************************/ +e1546 /* throw() inside destructor */ +elib(1546) -append(1546,[MISRA C++ Rule 15-5-3]) +e1560 /* uncaught exception */ +elib(1560) -append(1560,[MISRA C++ Rule 15-5-3]) +e1559 /* uncaught exception */ +elib(1559) -append(1559,[MISRA C++ Rule 15-5-3]) /* Rule 16-0-1 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 16-0-1, only preprocessor statements and comments before '#include' */ /* Rule 16-0-2 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 16-0-2, '#undef'/'#define' used within a block */ /* Rule 16-0-3 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 16-0-3, '#undef' is discouraged */ /* Rule 16-0-4 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 16-0-4, function-like macro defined */ -esym(1960, 16-0-4) /* Rule 16-0-5 (req) *********************************/ +e436 /* preprocessor directive in invocation of macro */ +elib(436) -append(436,[MISRA C++ Rule 16-0-5]) /* Rule 16-0-6 (req) *********************************/ +e665 /* unparenthesized macro parameter */ +elib(665) -append(665,[MISRA C++ Rule 16-0-6]) /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 16-0-6, unparenthesized macro parameter in definition of macro */ // disabled due to the following warning in all cpp files: unparenthesized macro parameter in definition of macro: '__identifier' -esym(1960, 16-0-6) /* Rule 16-0-7 (req) *********************************/ +e553 /* undefined preprocessor variable */ +elib(553) -append(553,[MISRA C++ Rule 16-0-7]) /* Rule 16-0-8 (req) *********************************/ +e16 /* # directive not followed by recognizable word */ +elib(16) -append(16,[MISRA C++ Rule 16-0-8]) +e544 /* endif or else not followed by EOL */ +elib(544) -append(544,[MISRA C++ Rule 16-0-8]) /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 16-0-8, all preprocessing directives must be valid */ /* Rule 16-1-1 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 16-1-1, Non-standard use of 'defined' preprocessor statement */ /* Rule 16-1-2 (req) *********************************/ +e405 /* #if not closed off */ +elib(405) -append(405,[MISRA C++ Rule 16-1-2]) /* Rule 16-2-1 (req) *********************************/ /* not currently supported */ /* Rule 16-2-2 (req) *********************************/ +e1923 /* macro could be const variable */ +elib(1923) -append(1923,[MISRA C++ Rule 16-2-2]) /* Rule 16-2-3 (req) *********************************/ +e967 /* no standard include guard */ +elib(967) -append(967,[MISRA C++ Rule 16-2-3]) /* Rule 16-2-4 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 16-2-4, header file name with non-standard character */ /* Rule 16-2-5 (adv) *********************************/ /* we generate note 1963 as follows Note 1963: Violates MISRA C++ Advisory Rule 16-2-5, header file name with non-standard character */ /* Note: If your system requires the '\' be used as a directory separator, uncomment the following option. */ // -estring(1963,\) /* Rule 16-2-6 (req) *********************************/ +e12 /* Need < or " after #include */ +elib(12) -append(12,[MISRA C++ Rule 16-2-6]) /* Rule 16-3-1 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 16-3-1, Multiple use of '#/##' operators in macro definition */ /* Rule 16-3-2 (adv) *********************************/ /* we generate note 1963 as follows Note 1963: Violates MISRA C++ Advisory Rule 16-3-2, '#/##' operator used */ -esym(1963, 16-3-2) /* Rule 16-6-1 (doc) *********************************/ /* not statically checkable */ /* Rule 17-0-1 (req) *********************************/ +e683 /* complain about #define standard functions */ +elib(683) -append(683,[MISRA C++ Rule 17-0-1]) /* Rule 17-0-2 (req) *********************************/ /* we generate note 1960 as follows Note 1960: Violates MISRA C++ Required Rule 17-0-2, Re-use of reserved identifier */ /* Rule 17-0-3 (req) *********************************/ /* not currently supported */ /* Rule 17-0-4 (req) *********************************/ /* See various +elib options throughout this file. */ /* Rule 17-0-5 (req) *********************************/ +e586 /* Symbol is deprecated */ +elib(586) -deprecate( function, longjmp, [MISRA C++ Rule 17-0-5] ) -deprecate( macro, setjmp, [MISRA C++ Rule 17-0-5] ) /* Rule 18-0-1 (req) *********************************/ +e829 /* header warning */ +elib(829) +headerwarn(time.h) +headerwarn(limits.h) +headerwarn(float.h) +headerwarn(stddef.h) +headerwarn(errno.h) +headerwarn(locale.h) +headerwarn(stdio.h) +headerwarn(ctype.h) +headerwarn(string.h) +headerwarn(math.h) +headerwarn(stdlib.h) +headerwarn(assert.h) +headerwarn(stdarg.h) +headerwarn(setjmp.h) +headerwarn(signal.h) -append(829,[MISRA C++ Rule 18-0-1]) /* Rule 18-0-2 (req) *********************************/ +e586 /* Symbol is deprecated */ +elib(586) -deprecate( function, atof, [MISRA C++ Rule 18-0-2] ) -deprecate( function, atoi, [MISRA C++ Rule 18-0-2] ) -deprecate( function, atol, [MISRA C++ Rule 18-0-2] ) /* Rule 18-0-3 (req) *********************************/ +e586 /* Symbol is deprecated */ +elib(586) -deprecate( function, abort, [MISRA C++ Rule 18-0-3] ) -deprecate( function, exit, [MISRA C++ Rule 18-0-3] ) -deprecate( function, getenv, [MISRA C++ Rule 18-0-3] ) -deprecate( function, system, [MISRA C++ Rule 18-0-3] ) /* Rule 18-0-4 (req) *********************************/ +e829 /* header warning */ +elib(829) +headerwarn(ctime) -append(829,[MISRA C++ Rule 18-0-4]) /* Rule 18-0-5 (req) *********************************/ +e586 /* Symbol is deprecated */ +elib(586) -deprecate( function, strcpy, [MISRA C++ Rule 18-0-5] ) -deprecate( function, strcmp, [MISRA C++ Rule 18-0-5] ) -deprecate( function, strcat, [MISRA C++ Rule 18-0-5] ) -deprecate( function, strchr, [MISRA C++ Rule 18-0-5] ) -deprecate( function, strspn, [MISRA C++ Rule 18-0-5] ) -deprecate( function, strcspn, [MISRA C++ Rule 18-0-5] ) -deprecate( function, strpbrk, [MISRA C++ Rule 18-0-5] ) -deprecate( function, strrchr, [MISRA C++ Rule 18-0-5] ) -deprecate( function, strstr, [MISRA C++ Rule 18-0-5] ) -deprecate( function, strtok, [MISRA C++ Rule 18-0-5] ) -deprecate( function, strlen, [MISRA C++ Rule 18-0-5] ) /* Rule 18-2-1 (req) *********************************/ +e586 /* Symbol is deprecated */ +elib(586) -deprecate( macro, offsetof, [MISRA C++ Rule 18-2-1] ) /* Rule 18-4-1 (req) *********************************/ +e586 /* Symbol is deprecated */ +elib(586) -deprecate( function, operator new, [MISRA C++ Rule 18-4-1] ) -deprecate( function, operator delete, [MISRA C++ Rule 18-4-1] ) -deprecate( function, calloc, [MISRA C++ Rule 18-4-1] ) -deprecate( function, malloc, [MISRA C++ Rule 18-4-1] ) -deprecate( function, realloc, [MISRA C++ Rule 18-4-1] ) -deprecate( function, free, [MISRA C++ Rule 18-4-1] ) /* Rule 18-7-1 (req) *********************************/ +e829 /* header warning */ +elib(829) +headerwarn(csignal) -append(829,[MISRA C++ Rule 18-7-1]) /* Rule 19-3-1 (req) *********************************/ +e586 /* Symbol is deprecated */ +elib(586) -deprecate( variable, errno, [MISRA C++ Rule 19-3-1] ) /* Rule 27-0-1 (req) *********************************/ +e829 /* header warning */ +elib(829) +headerwarn(cstdio) -append(829,[MISRA C++ Rule 27-0-1]) /****************************************************************************** * FEAT ******************************************************************************/ -e537 // Repeated includes are standard practice within CGI framework induced by code complexity. Multiple inclusions are prevented by include-guards. -e763 // Redundant declaration for symbol '...' previously declared. -e830 // Location cited in prior message. -e831 // Reference cited in prior messages (is not removed by -e*). -e788 // Enum constant is caught in case "default". -e1502 // Defined object 'Symbol' of type Name has no non-static data members. Is used for Singletons, also. -e1536 // Exposing low access member 'Symbol'. Design decision to allow access of complex object chains. +fet // Explicit Throw flag - CGI Studio does not support exception handling. +fnn // C++ new-operation can return NULL. +e414 // Possible division by 0. -e1774 // Could use dynamic_cast to downcast ptr to polymorphic type 'Symbol'. CGI Studio does not support RTTI, the usage // of dynamic_cast requires RTTI. Thus the warning is globally disabled. -esym(31, std::_Lhs) // warning 31 introduced by in Visual Studio 2013 exception.h system header file -e835 // Info -- A zero has been given as right argument to operator '+', e.g constants from Windows -e1774 // Info -- Could use dynamic_cast to downcast polymorphic type 'Courier::Foundation::FrameworkWidget' -e1551 // Throws exception in DTOR -e1702 // Operator != is both -efile(766, cstring) // lint bug?
