3D Scene Graph Dynamics
Usually all required nodes are already specified and preconfigured via SceneComposer, so in most cases it won't be necessary to make any adaptations within the scene graph loaded from an asset at runtime.
However, some use cases might require such adaptations. This tutorial covers the most common means to manipulate the scene graph structure dynamically.
Chapters
Example Solution
  • SceneGraphDynamicsSolution_3D in folder cgi_studio_player/content/Tutorials/03_SceneGraphAndNodes
Adding and Removing 3D Nodes
3D Scene Graph Dynamics Example
For creating and adding a new node, the following can be used:
  • SceneGraphDynamicsSolution_3D from folder cgi_studio_player/content/Tutorials/03_SceneGraphAndNodes
  • SceneGraphDynamicsWidget_3D (this is used in the example solution - refer to SceneGraphDynamicsWidget_3D)
As an example use case, a Candera::Billboard can be created, added and removed. Use the SceneGraphDynamicsWidget_3D properties described below:
  • AddBillboard: If AddBillboard is enabled a new Billboard is created and added to the widget node. If disabled, the Billboard will be removed.
        // Definition of WidgetProperty "AddBillboard"
        CdaProperty(AddBillboard, bool, GetAddBillboard, SetAddBillboard)
            CdaDescription("If AddBillboard is enabled a new Billboard is created and added to the widget Candera::Node. If disabled, the Billboard will be removed.")
        CdaPropertyEnd()
        // End Definition of WidgetProperty "AddBillboard"
Creating a new Billboard
The following code snippet generates a basic Candera::Billboard (size 30 x 30) with a Candera::Material and a matching Candera::Shader. The Shader has to be provided in the asset and is delivered through the AssetProvider by its name. Further, some translation is applied to the new Billboard.
        // Create and init a new Billboard
        SharedPointer<Appearance> myAppearance = Appearance::Create();
        SharedPointer<Material> myMaterial = Material::Create();
        myMaterial->SetEmissive(Color(0.5F, 0.0F, 0.0F, 1.0F));
        myAppearance->SetMaterial(myMaterial);
        myAppearance->SetShader(Base::GetAssetProvider()->GetShader(CgiAssetNames::RefTransLight1_RefColor));
        myAppearance->SetName("Generated Appearance");
        m_billboard = Billboard::Create(30.0F, 30.0F);
        m_billboard->SetAppearance(myAppearance);
        m_billboard->Translate(Vector3(30.0F, 0.0F, 0.0F));
        // end Create and init a new Billboard
Adding the new Billboard to the scene graph
Next the Billboard is uploaded to VRAM and appended to the node associated with the widget.
        // Add Billboard
        static_cast<void>(m_billboard->Upload());
        static_cast<void>(node->AddChild(m_billboard));
        // end Add Billboard
Removing and destructing the Billboard
To remove the Billboard simply from the scene graph, use Candera::Node::RemoveChild. If the Billboard will be used for further operations e.g. attaching it to an other node removing would be enough. Since in this example the Billboard isn't used further it should not only be removed but also be destructed completely (freeing the resources).
The following code snippet removes the previously generated billboard from its parents, unloads the Billboard from VRAM and frees with Candera::Node::Dispose the resources.
        // Remove previously generated billboard and destruct it
        Node* parent = m_billboard->GetParent();
        if (parent != 0){
            static_cast<void>(parent->RemoveChild(m_billboard));
            FEATSTD_LOG_ERROR("- Node %s removed from parent %s ...\n", m_billboard->GetName(), parent->GetName());
        // Destruct node
        static_cast<void>(m_billboard->Unload());
        m_billboard->Dispose();
        m_billboard = 0;
        // end Destruct node
        // end Remove previously generated billboard and destruct it
As Candera::Node::Dispose internally calls the Candera::Node::RemoveChild on parent node following code would be enough for removing and destructing a node.
        // Destruct node
        m_billboard = 0;
In SceneComposer the newly added Node does not appear in the Scene Tree view because it is only added dynamically by the widget.
- The used Shader for the generated Billboard in the widget has to be included when generating an asset from the solution - ensure that "Always include in asset" flag is marked at the Shaders properties.
- The widget must control memory and VRAM management of its internal dynamic subtree autonomously.
Widget Interaction in the Player
First, the asset must be exported and loaded in the Player. Then, one of the two existing SceneGraphDynamicsWidget_3D widgets must be selected for the 3D scene. After, ChangeAppearance, CloneOperation and AddBillboard properties can be enabled/disabled (1/0) to obtain different results.
Back to the sub chart menu
Changing Appearance and other 3D Node Attachments
For changing the appearance of a node, the following property of the SceneGraphDynamicsWidget_3D can be used:
  • ChangeAppearance: If ChangeAppearance is enabled, the appearance of the widgets associated node will be changed to a new generated appearance. If disabled, the previous appearance will be restored.
        // Definition of WidgetProperty "ChangeAppearance"
        CdaProperty(ChangeAppearance, bool, GetChangeAppearance, SetChangeAppearance)
            CdaDescription("If ChangeAppearance is enabled, the appearance will be exchanged to a new generated appearance. If disabled, the previus appearance will be restored.")
        CdaPropertyEnd()
        // End Definition of WidgetProperty "ChangeAppearance"
Try the ChangeAppearance property at the SceneGraphDynamics_3D_Billboard widget in the example solution to change the Billboards appearance from a texture appearance to a material appearance.
Creating and changing an Appearance
The following code snippet generates a basic Candera::Appearance. A Candera::Material is created and its emissive color is set to a light green. The material and a proper shader is set to the Appearance. The shader has to be provided in the asset and is delivered through the AssetProvider by its name.
    // Create and set a new Appearance
    myAppearance->SetMaterial(Material::Create());
    myAppearance->GetMaterial()->SetEmissive(Color(0.0F, 0.5F, 0.0F, 1.0F));
    // end Create and set new Appearance
In the next step the node's previous Appearance is saved (for restoring purpose) and the new generated appearance is set to the node associated with the widget.
    // Change Appearance
    m_previousAppearance = node->GetAppearance();
    node->SetAppearance(myAppearance);
    static_cast<void>(myAppearance->Upload());
    // end Change Appearance
Restoring / releasing an Appearance
Restore the previous Appearance and destruct the dynamically generated appearance.
        // Restoring appearance and destructing
        SharedPointer<Appearance> currentAppearance = node->GetAppearance();
        static_cast<void>(currentAppearance->Unload());
        currentAppearance.Release();
        node->SetAppearance(m_previousAppearance);
        // end Restoring appearance and destructing
In SceneComposer the changed Appearance does not appear in the Appearance panel because it is only changed dynamically by the widget.
- The used shader for the generated Billboard in the widget has to be included when generating an asset from the solution - ensure that "Always include in asset" flag is marked at the Shaders properties.
- The widget must control memory and VRAM management of dynamically created node attachments autonomously.
Cloning 3D Nodes
For cloning a node, the following property of the SceneGraphDynamicsWidget_3D can be used:
  • NodeToClone: Select an arbitrary node in the scene graph, which shall be cloned and added to the widget node
        // Definition of WidgetProperty "NodeToClone"
        CdaProperty(NodeToClone, Candera::Node*, GetNodeToClone, SetNodeToClone)
            CdaDescription("Select a Candera::Node which shall be cloned and added to the widget Candera::Node. The Candera::Node must be a child of this widget's scene.")
        CdaPropertyEnd()
        // End Definition of WidgetProperty "NodeToClone"
  • CloneOperation: If enabled, the clone operation will be executed and the cloned node will be added to the widget node.
        // Definition of WidgetProperty "CloneOperation"
        CdaProperty(CloneOperation, bool, GetCloneOperation, SetCloneOperation)
            CdaDescription("If CloneOperation is enabled, the Candera::Node to clone will be cloned and added to the widget Candera::Node. If disabled, the clone will be removed.")
        CdaPropertyEnd()
        // End Definition of WidgetProperty "CloneOperation"
For the cloning operation, refer to Candera::Node::Clone. The following code snippets illustrate, what the SceneGraphDynamicsWidget_3D is actually doing for cloning a node and destructing it again.
Validating Node to Clone
This example should allow to clone nodes, which are part of the scene graph the widget is linked to. The scene graph can be traversed from a given node up to its actual top level scene node to check whether it is part of the scene graph.
    // Search the parent scene of a given node
    Node* currentNode = node;
    while (currentNode != 0) {
        if (currentNode->IsTypeOf(Scene::GetTypeId())) {
            return static_cast<Scene*>(currentNode);
        currentNode = currentNode->GetParent();
    return 0;
    // end Search the parent scene of a given node
Creating and Adding Clone
If the widget node and the node to clone have same top level scene, the node can be cloned and added to the widget node according to the following code snippet.
        // Clone the node and add it to the widgets associated node
        m_clonedNode = TreeCloner().CreateClone(*m_nodeToClone);
        static_cast<void>(node->AddChild(m_clonedNode));
        static_cast<void>(m_clonedNode->UploadAll());
        m_clonedNode->SetName("Clone");
        // end Clone the node and add it to the widgets associated node
Nodes can be attached to any 3D node.
TreeCloner and Cloning Strategies
For more complex cloning see Candera::TreeCloner and Candera::TreeCloneStrategy. Candera::TreeClonerBase is provided for cloning trees.
  • The default clone strategy is to call the Clone interface on each node, and build the clone tree with the same node pattern as the original tree.
  • For deeper cloning, TreeClonerBase supports attaching a Candera::TreeCloneStrategy. This TreeCloneStrategy is typically aware of different types of nodes, and delegates to other strategies.
Removing and Destructing Clone
Analogous to Removing and destructing the Billboard (removing/destructing a 3D node) the cloned node is destructed.
        // Remove a previously cloned node
        static_cast<void>(m_clonedNode->UnloadAll());
        m_clonedNode->Dispose();
        m_clonedNode = 0;
        // end Remove a previously cloned node
In SceneComposer the newly added node clone does not appear in the Scene Tree view because it is only added dynamically by the widget.
- It is not allowed to modify the scene graph maintained by SceneComposer outside of the subtree owned by the widget!
Back to the Chapter menu
