2D Shadow Effect
This chapter briefly describes how to use the 2D shadow effect.
Ensure that this effect is supported by the device platform in use.
Chapters
2D Configure a Shadow Effect
Shadow Effect
By using Candera::ShadowBitmapBrushBlend, a colored shadow can be applied to a bitmap.
Following properties of the shadow can be configured:
  • Color (including alpha value)
  • Scale (the shadow size related to the bitmap)
  • Position Offset (related to the bitmap)
Following is an example of a grey colored shadow, with a scale of 70% and an offset of 80/80 related to the bitmap:
Refer to SceneComposer User Manual about how to configure a ShadowBitmapBrushBlend effect in a 2D scene.
Back to the menu
Modify 2D Shadow Effect Properties
Access Shadow Effect
To modify the shadow effect properties, first the shadow effect needs to be retrieved from its render node:
    // Get and cast first effect of render node
    Effect2D* effect2D = renderNode->GetEffect(0);
    ShadowBitmapBrushBlend* shadow = 0;
    if (effect2D != 0){
        shadow = (ShadowBitmapBrushBlend*) effect2D;
    // End Get and cast first effect of render node
Set Shadow Color
Specify a color with a red, a blue, a green and an alpha component and apply the color to the Shadow Effect.
Example:
Color::Data c;
c.alpha = 0.5f;
c.blue = 0.0f;
c.green = 0.0f;
c.red = 1.0f;
shadow->ShadowColor().Set(c);
Set Shadow Scale
For the shadow's scale you need the scale X and Y value. Add the two values to a Vector2 and set the shadow's scale.
Example:
Float shadowScaleX = 0.7f;
Float shadowScaleY = 0.7f;
shadow->ShadowScale().Set(Vector2(shadowScaleX, shadowScaleY));
Set Shadow Position Offset
It is possible to change the position of the shadow by changing its offset to the node. Therefore you need a Vector2 with the X and Y offset values again.
Example:
Float shadowPosOffX = 5.0f;
Float shadowPosOffY = 7.0f;
shadow->ShadowPositionOffset().Set(Vector2(shadowPosOffX, shadowPosOffY));
Back to the menu
