2D Blur Effect
This chapter briefly describes how to use the 2D blur effect.
Ensure that this effect is supported by the device platform in use.
Chapters
Configure a 2D Blur Effect
Blur Effect
By using Candera::BlurBitmapBrushBlend, a bitmap node can be blurred, applying a gaussean filter convolution.
Blur Effect supports the following property:
  • Filtersize (Number of neighbour pixels)
In this example, the upper two pictures are the original ones, the lower two are blurred with a filter size of 15.
Refer to SceneComposer User Manual about how to configure a BlurBitmapBrushBlend effect in a 2D scene.
Back to the menu
Modify 2D Blur Effect Property
Set Blur Filtersize
When using this effect you only have to set the filtersize. This value defines the blur factor of, for example, an image. The bigger the value, the more the image is blurred. The following example shows how to set the filtersize.
UInt8 factor = 5;
blur->FilterSize() = factor;
Back to the menu
