Building SCHost for SceneComposer
To make the same set of widgets available for SceneComposer, as they are for the Player, a new SCHost.dll needs to be created and deployed to SceneComposer.
Enable COURIER_ADD_SCHOST_PROJECT in the CMake project in order to add the SCHost project to the Player solution.
That's the reason why the SCHostDll project is part of the C++ Player.sln, because this way the widget set configuration for the Player is identical to the one for SCHost.dll .
However, in difference to the Player, SceneComposer requires a specific set of Candera static libraries to link together with the widgets part of the solution. These specific libraries are created as part of the compilation process and collected into a library names SCHostLib.lib. The corresponding Visual Studio project is named SCHostLib.
When the SCHostDll project is built, SCHostLib.lib will be linked together with the widgets and the Candera Device lib part of the solution into the SCHostDll.dll library.
To automatically copy the generated SCHostDll.dll to your SceneComposer executable location as SCHost.dll after the build, take care to set the following CMake variable:
  • Make sure to select "x64" as optional platform for generator during CMake configuration for Visual Studio versions lower than Visual Studio 2019 (version 16) in order to build with 64-bit compiler.
  • "CGIAPP_SCENE_COMPOSER_PATH" to <SC-Install-Dir>/SceneComposer/ .
  • Close SceneComposer before building SCHost.dll, otherwise SCHost.dll cannot be copied to the SceneComposer location.
  • SCHost.dll will contain exactly the Candera Device which is selected in CMake during Player solution generation.
For using several platforms alternatively, it is also possible to specify the name of the SCHost dynamic link library as command line argument to SceneComposer. Example: "SceneComposer /schost device\iMX6\SCHost.dll"
SCHost and Memory Pools
As memory pools are introduced in FeatStd V1.2.0 resp. V1.1.0.3, and an SCHost build using this feature is not binary compatible to a build not using memory pools, a new restriction is added for building SCHost.dll:
  • In the solution for building SCHost.dll, the feature FEATSTD_MEMORYPOOL_ENABLED must not be set!
As a consequence, the build system for cgi_studio_dev will not add the SCHost project when Memory Pools are enabled.
  • Disable FEATSTD_MEMORYPOOL_ENABLED to integrate your widgets to SceneComposer
  • Enabled FEATSTD_MEMORYPOOL_ENABLED to integrate and test memory pool configurations on host simulation as preparation for the target
