Part 2: Set-up Scene
This section describes the steps to prepare/configure a Scene Tree for the operations in the following chapters.
Create a new Scene
After Importing, a new folder with the same name as the Photoshop file IVI_Sample is created below Solution > Resources in Solution Explorer. The newly created scene IVI_Sample is located in that folder. Move that scene into Solution > Scenes by drag and drop operation.
After the above operation, IVI_Sample scene is selected in Scene Tree panel. If not, click IVI_Sample scene in Solution Explorer panel to display it in Scene Tree.
Configure a Node
Then, grouping buttons related to Air conditioner operation. The GroupBox control can be set the button as the default selected button for that group.
Drag and drop "Group" from Node 2D in the Toolbox on the right, into a Scene Tree placing it under Air.
Place GroupBox under Air from Controls in the Toolbox in the same way as when Group was placed in the previous step. Move Group that has been created in the previous step into that GroupBox.
Select GroupBox and set Default Selected Object in Control in Properties to .../Contetnt/Group/RadioButton_AUTO. This will set the Radio Button of AUTO as the default. Then uncheck the "Enable Background"checkbox below. The group background will be disabled.
