Part 1: Smart Importer
This section describes creating a new Solution and how to proceed importing IVI_Sample.psd file via Smart Importer. Specially about how to assign Controls to each image parts.
Create a new Solution
The first step is to create a new Solution for Scene Composer.
Double-click on the Empty template under Samples and Templates.
* Selecting “Empty” template creates a new solution based on the template.
Select "Render Targets" panel and click "Display". Change the resolution setting as the below.
- X Resolution 640
- Y Resolution 960
Click save icon in the menu bar.
A dialog box appears, allowing you to select an appropriate location. Input any name as a solution file name.
Smart Importer
As an example, here describ the actual import procedure using Smart Impoter. We will use IVI_Sample.psd for this explanation. From the menu bar, click Import > Smart Importer... and select the Photoshop file "IVI_Sample.psd".
The Smart Importer dialog box appears.
First, click on the left-most triangle button to extend the Header layer tree. Check the checkbox to the left of the Header and make sure that all items under the Header are checked. Click on DigitalCrock in the tree. From the Control List, click on the Apply button to the right side of the DigitalCrock control.
Click on “Basic Properties” tab and check “ShowFull24Hours” checkbox. This will make the display show 24 hours. Similarly, uncheck “ShowSeconds”. This will prevent the seconds from being displayed.
If a Control is set and imported with layers and properties that do not match when imported, the original group will not reflect the Control, and another new group node with Control applied will be added.
Following the previous operation, similar operations are performed on each item.
| Target Layer |
Control List |
| TellTale_Error |
Tell Tale |
| Target Layer |
Control List |
Basic Properties |
| TextButton_Car |
TextButton |
Text |
(blank space) |
| TextButton_Navigation |
TextButton |
Text |
(blank space) |
| TextButton_Phone |
TextButton |
Text |
(blank space) |
| TextButton_Music |
TextButton |
Text |
(blank space) |
Music Tree
| Target Layer |
Control List |
Basic Properties |
Slider
Slider
Value |
9000 |
| Minimum |
0 |
| Maximum |
18000 |
| Target Layer |
Control List |
Basic Properties |
| DigitalClock_Time |
DigitalClock |
ShowFull24Hours |
enable |
| ShowSeconds |
disable |
| Target Layer |
Control List |
Basic Properties |
| DigitalClock_Total_Time |
DigitalClock |
Time |
18000 |
| ShowFull24Hours |
enable |
| ShowSeconds |
disable |
| Target Layer |
Control List |
Basic Properties
| CheckBox |
CheckBox |
Text |
(blank space) |
Comfort Tree
| Target Layer |
Control List |
Basic Properties |
| Seat_Left |
TextValue_Temperature |
Text Value |
Value |
23 |
| FormatText |
%02d |
| Target Layer |
Control List |
| Seat_Left |
Icon_Button_+ |
IconButton |
| Icon_Button_- |
IconButton |
| Target Layer |
Control List |
Basic Properties |
| Seat_Left |
ProgressBar |
ProgressBar |
Value |
23 |
| Minimum |
16 |
| Maximum |
28 |
| Target Layer |
Control List |
Basic Properties |
| Seat_Left |
SeatHeating_Left(*) |
CheckBox |
Text |
(blank space) |
(*)The image is treated like a checkbox. So there is no additional rectangle for that.
| Target Layer |
Control List |
Basic Properties |
| Seat_Right |
Text Value |
Value |
23 |
| FormatText |
%02d |
| Target Layer |
Control List |
| Seat_Right |
Icon_Button_+ |
IconButton |
| Icon_Button_- |
| Target Layer |
Control List |
Basic Properties |
| Seat_Right |
ProgressBar |
ProgressBar |
Value |
23 |
| Minimum |
16 |
| Maximum |
28 |
| Target Layer |
Control List |
Basic Properties |
| Seat_Right |
SeatHeating_Right(*) |
CheckBox |
Text |
(blank space) |
| Target Layer |
Control List |
| Fan |
slider |
slider |
| Target Layer |
Control List |
Basic Properties |
| Air |
RadioButton_Outside Air |
RadioButton |
Text |
(blank space) |
| RadioButton_Inside Air |
RadioButton |
Text |
(blank space) |
| RadioButton_AUTO |
RadioButton |
Text |
(blank space) |
| Target Layer |
Configuration details |
| Air |
RadioButton_Outside Air/Control_Background |
disable |
| RadioButton_Inside Air/Control_Background |
disable |
| RadioButton_AUTO Air/Control_Background |
disable |
Navigation Tree
Since this tree is unchecked, check it. There is no need to apply the control in ControlList since it only imports Navigation image. After completing the settings up to this point, press OK button to perform the import. Now you can import while setting controls on each layer. On Scene Tree, you can confirm that the settings made in Smart Importer have been applied at the time of import.
After you finish importing, select Navigation below Navigation group in Scene Tree and unselect "Node Rendering Enabled”. Then this element will be not displayed by default.
