This section describes how to configure a simple IVI solution using the file IVI_sample.psd. This file can be found in the following location:
...\2D\PSD\IVI_Sample.psd
- This sample uses the Smart Importer to create the necessary Controls.
- A simple interaction will be configured using behaviors eg. moving a slider bar will change a value.
- State Machine Editor is used to create transitions between different scenes.
The following chapters provide a step by step operation guide. Please note that they are based on each other and it is recommended to work them through from Part 1 to part 5.
