GettingStartedControls Part 1
This
The scene is built up using imported images and configuring various controls (such as TellTale, Gauge, DigitalClock, TextValue, Text, FlipBook). The use of a ForwardValue behavior will ensure that the Speed Gauge and an additional textual display will show the same value at any time.
Finally, the Panel is started to verify the coherency of the Speed Gauge and the speed's textual display.
Setting up the SceneComposer solutionSolution
Choose
Savea thenew Solution
Inside
You should have now the following file structure on disk:
The file GettingStartedControls.scs is the main solution file and can later be loaded via "Open Solution..." from SceneComposer.
Our GettingStartedControls solution will use a screen resolution of 1024x768 pixels. Since the default resolution settings are different we have to adapt them within the RenderTargets tabpanel on the top right ofand select [ Display (0) ]. In the SceneComposer.
Pleasebelow select "Display(0)" as can be seen above. This selection will showchange the propertiesdisplay's X and Y Resolution.
The "X Resolution" and "Y Resolution" properties have towill be changeddefined.
1024
Y Resolution
768
You
Preparing the Scene
Select "Scene2D" and rename it to "SceneHome" either by pressing <F2> on your keyboard or via the context menu "Rename".
Save the solution using
Tip: It might be a good idea to make a backup of your solution now! If you destroy something during execution of the following steps you always have the possibility to restart with a clean solution. To make a copy just make a copy of the GettingStartedControls folder or create a copy by archiving into a zip file.
Import
Deletion of unused ScenesImages
All content that we want to display is organized into scenes. There are available scenes for 2D and 3D content. In the beginning we will only use 2D scenes to keep things a little easier. In our current solution we already have scenes of both types available. And because we don't need a 3D scene, we will delete it now.
The contentimages needed for this solution will be imported. Some of athem solutionwill isbe alwaysused displayedas inplain thestatic Solutionimages, Explorerbut onmost thewill top left side of SceneComposer.
In the Solution Explorer a tree view isbe used to visualizeconfigure allcontrols.
Navigate to the
There are two scenes available. Pleasefolder, select theall Scene3Dfiles using your right mouse button and select "Delete"provided in thethis context"Cluster" menu. As an alternative you can select the scene with a left clickfolder and press the[ deleteOpen key from your keyboard to delete it.
There are some dependencies to other objects, therefore SceneComposer asks us how to handle it. Please select the following settings within the dropdown menus on the right side and press OK to discard the dialog.
You can save the solution again.
Creation of the first screen
The first screen of our GettingStartedControls application will look like this:
In order to start easy, the screen will consist mainly of static images. Only the gauge (speedometer) and the text displaying the current speed will have real functionality behind them. At the bottom border a few tabs are shown wherein the user can later switch between different screens of the application. These tabs therefore are not static image elements but controls which are able to react on user (touch) input. The orange tab marks our current screen which is our home (cluster) screen.
As already mentioned, SceneComposer is using scenes to organize content which can be shown to the app user. These scenes typically contain only parts of application screens. As a cinema film is using scenes to put in order segments of a story, scenes in our context is playing a similar role. During this tutorial we will create a scene per tab content and an additional scene which contains the tab bar itself.This will help us to not repeat ourselves. If we had organized the scene exactly like the screen content we would have to use a tab bar in every screen.
We are now renaming the left over Scene2D into "SceneHome" to have it easier later to find our home content. Please select the Scene2D and press F2 (or use the context menu) to enter "SceneHome" as the new name.
Please double click on the "SceneHome" to show this scene within the Scene Tree panel below the Solution Explorer.
The scene editor will show the whole content of an opened scene. If a scene is opened its visual content is also displayed in the Scene Editor window in the center of SceneComposer. If the scene is empty you can only see a yellow border which is representing the size of the application's screen resolution. You can zoom in and out using the mouse wheel. By holding the mouse wheel and dragging you can move around the content of your view while retaining the Zoom factor. To get back to the original 100% size, please use the icon in the toolbar (Set selected camera to predefined location and orientation)].
To be able to show some "fancy" graphics we have to import the images into our solution. We use the import images function of SceneComposer which you can find in the import menu.
You will now be asked to save your solution. Please confirm!
A Windows File Explorer titled "Import Resources" will be opened. Please navigate to the Cluster folder:
<cgi-studio-root>/cgi_studio_content/Resources/GettingStartedControls/Cluster
Select
The images are now processed and the "Import Images"Images ] dialog will be displayed:
The
Afterand thepress import[ theOK Solution].
Explorer
Position Images
Repeat your actionsimage with the "NewWarning80Bmp".
Yourlimit scene could now look like this:
It is now time to improve the placement of the images to make room for the speedometer. Towill be able to move the images using the mouse, change the Editor panel mode. You can find iconsplaced in the toolbarScene whichEditor.
The current mode is for selecting elementsappears in the EditorScene Tree panel.
To be able to place an element to a predefined position, select the element (in this case the Navi60Bmp) either using a click on the element in the editor panel or in the Scene Tree.Tree Whenpanel anselect elementthe isimages selectedindividually (suchand asmodify below)
Its properties are shownY in the Properties panel on the lowerbottom rightright.
of
Render Node
TransformationsPosition X Position Y Navi60Bmp
38
121
NewWarning80Bmp 38
612
Configure
PleaseControls positionare image NewWarning80Bmp to X=38 and Y=612.
In a real application, elements will be placed using layout controls to be able to adapt to different screen sizes or culture settings. Nevertheless direct placement is often needed within layout controls or where an application designer specifies absolute placement.
With dragging the images directly from the Solution Explorer we used a direct method to create RenderNodes containing the dragged image. Normally we choose directly the node type within the Toolbox (top right of SceneComposer) and configure the properties in the next step.
Specialspecial types of nodes that already contain logic for handling of user actions (touch, click) and state changeschanges. are called Controls. YouThey can findbe these controlsfound in the Controls section on top of the Toolbox.Toolbox, which is by default located in the top right corner.
The most common control is a Button. In our home scene we used auses "TellTale"Tell ControlTale" Controls to indicate weather alerts, charging orstatus aninformation and incoming call.calls.
This will open the "Choose Item" dialog. In the left panel you can navigate to Solution > Resources > Cluster and select the correct image.
The TellTale's state can be configured choosing between On, Off and Blinking. For the blinking option the On Time and Off Time in ms can also be set. In the image below you can see the configuration for Tell Tale_Call.
You can now configure the TellTale controls' images and positions as follows:
| Scene |
Rename Node to Position X Position Y State
Tell Tale_Snow
Node On State Image
Off State Image
Tell Tale_Snow NewWeather_BBmp NewWeather_HBmp Tell Tale_Gas Ev_HBmp Ev_Bmp_HBmp Tell Tale_Call NewCall_HBmp NewCallBmp
In the Scene Tree or in the Scene Editor select "Tell Tall_Call". This Tell Tale Control is configured to keep blinking. Therefore, the speed of blinking has to be configured.
When "active rendering" is activated, this Tell Tale will be blinking in Scene Editor. "Active rendering" can be toggled using pinwheel button in the Scene Editor's bottom toolbar (see image below).
800 800
Configure a Gauge Control
AnotherTo control which is used in our home scene isdisplay the "Gauge".current It is very often used for Speedometers or visualizationspeed of RPM.the car a "Gauge Control" will be used.
Please
The Gauge Control also appears in the Scene Tree.
Asthe youProperties mightpanel's have[ figuredTransformations out] section configure the Gauge weControl's haveposition placed looks differentaccording to the onetable.
from
Position X
Position Y
Gauge
319
217
Use the Properties panel of our Gauge to change the images and edit the values:
Clickcorresponding magnifying glass toicon.
the
Background Image
Needle Image
Gauge
NewClusterBmp NewNeedleBmp
Press OK and repeat the same steps for the Needle Image selecting NewNeedleBmp.
As you can see the needle"NewClusterBmp" needs to be repositioned in order to be in the center of the Gauge. In order to do this, click NewClusterBmp in the Solution Explorer,Explorer andselect clickNewClusterBmp. the Enable Pivot Hint checkbox inIn the Properties panel.panel's Input[ Bitmap ] section tick the valuescheckbox 194"Enable Pivot Hint" and 194 intoconfigure the XPivot andHint Yaccording fields.
Doto the sametable below.
Thethe needle image should nowwill be positioneddisplayed toin the center of the gauge.
Properties panel [ Bitmap ]
Item Name Pivot Hint X
Pivot Hint Y
NewClusterBmp
194 194 NewNeedleBmp
112
8
You may need to trigger a refresh by hitting the <F5> button on your keyboard if the images' positions are not updated automatically.
Configure Digital Speed Display
Now,A place"Text theValue" controlControl atwill thebe centerused ofto the scene (X=319, Y=217).
In the Gauge's Properties the Value property representsdisplay the current speed.speed Inputas Mindigits
To display the digital speed please] drag a "Text Value" control to the lowerScene middleEditor ofjust below the gaugeGauge (X=468,Control.
Y=492).
Position X
Position Y
Text Value 486 492
In the Properties panel's [ Control ] section configure properties from the table below.
Format Text
Style
Text Alignment
Text Value
%3d OpenSans25 Center
Add
Transformation
Control Item Name
Position X
Position Y Text
Text Style
Text
482 522
km/h"h
Connect TextValue Control and Gauge Control
The Text Value control will now be connected to the Gauge control, so that both controls display the same value.
the Toolbox panel's [ Behaviors ] section under "Value Processing".
TargetNode Forward Value
Scenes/SceneHome/CompositeNode2D:Text Value
Next, we'll add
Add a FlipBook control to the right upper corner. Drag and drop a FlipBook from the ToolBox Controls - Common to the Scene Editor with the following configuration:
The top center of our home screen is decorated with a Digital Clock"DigitalClock" control. ThisWe will also add a "FlipBook" control canto the upper right corner of the scene.
Position X
Position Y DigitalClock
439 116 Drag and drop a FlipBook from the ToolBox (under [ Controls ] - [ Common ]) to the Scene Editor. Place it in the upper right corner.
Position X
Position Y Scale X
Scale Y
FlipBook
745 121 0.50 0.50
Check the First Scene
The first screen/scene is now finished.
To be able to simulate the final application it is necessary to export the asset of the application. An asset contains only used resources from your project (controls, scenes, images, …). This asset might be stored into flash on a real embedded target. For now we generate this asset to have it available as input for our Player application (simulation driver). To generate (export) the asset you can press CTRL+G or use the File Menu and select the "Generate Asset Library…" menu entry.
Use the Browse button to choose where the output filepanel will be stored.opened Nowin pressa floating way displaying the generatescene button. The asset will be written.
If you want to run the Player from SceneComposer, you can do so by clicking the Play buttonconfigured in the menusteps bar.
Just
In some cases you have to choose your target device. Set the checkmark in front of the SceneHome on the middle left. You now should see the newly created scene. You can now manipulate the Gauge value for example. Please use the controls"Scenes#SceneHome" on the left halfand click on the [ Controls ] tab.
