Advanced Cluster Part 4
The following steps describe how to use the Custom_Gauge control in a scene. Speed gauge and RPM gauge are realized with the same control. Using the public properties for customization these Gauge controls appear similar yet different.
Once the advanced cluster scene is fully configured, it's time to test its functionality using the Scene Composer's Player.
Create a Cluster Scene with 2 Custom_Gauge Controls
  1. In the Solution Explorer navigate to the Scene2D and double click it.
    • Scene2D will be opened and visible in Scene Editor and Scene Tree panel.
    • In Scene Tree panel you can see that the scene contains a camera.
  2. In the Scene Editor's bottom toolbar make sure that "active rendering" and "widgets updating" is enabled.
    • In the Scene Editor's bottom toolbar "active rendering" and "widgets updating" are highlighted as seen in the image below.
  3. From the Toolbox panel under [Nodes 2D] drag a Group node into the Scene Tree panel or the Scene Editor.
    • In the Scene Tree panel you can see the newly created Group node.
    • In the Scene Editor you can see an indicator of the Group node's current position.
  4. Rename the Group node according to the table below either via the context menu "Rename" or the keyboard shortcut <F2>.
    • The Group node has been renamed accordingly.
      Old Name New Name
      Group Group_Content
  5. In the Scene Tree panel select the Group node. In the Properties panel's [Transformations] section reset the Position property according to the table below.
    • In the Scene Editor you can see the Group node's current position.
      A property can easily be reset in the Properties panel by clicking on the curled arrow icon on the property's left.
      Target Item Position
      X Y
      Group_Content 0.00 0.00
  6. From the Solution Explorer drag the image according to the table below into the Scene Tree panel directly onto the Group_Content node.
    • In Scene Tree panel you can see that a new RenderNode2D with a BitmapBrushBlend effect has been created inside Group_Content.
    • In Scene Editor you can see the rendered background image.
      Path in Solution Explorer Image
      Solution > Resources > Bitmaps BackgroundBmp
  7. From the Solution Explorer drag two Custom_Gauge into the Scene Tree panel directly onto the Group_Content. The path to the Custom_Gauge control is given in the table below.
    • In the Scene Editor only one Custom_Gauge will be displayed since both controls are located at the same position and therefore are completely overlapping. One Custom_Gauge is hiding the other.
    • In the Scene Tree panel the Group_Content node contains a RenderNode2D and the newly created Custom_Gauges.
      Path in Solution Explorer Control
      Solution > Controls Custom_Gauge
  8. Rename the Custom_Gauge nodes according to the table below either via the context menu "Rename" or the keyboard shortcut <F2>.
    • The Custom_Gauge node has been renamed accordingly.
      Old Name New Name
      Custom_Gauge Custom_Gauge_Speed
      Custom_Gauge_1 Custom_Gauge_RPM
  9. Select the Custom_Gauge controls one after the other. In the Properties panel configure the properties as given in the tables below.
    • In the Scene Editor the gauge controls for RPM and Speed are both visible.
    • The Scene2D starts to look like a cluster, see image below.
      Custom_Gauge_RPM Property Value
      Transformation
      Position X 965.00
      Position Y 30.00
      Custom_Gauge_Speed Property Value
      Transformation
      Position X 60.00
      Position Y 30.00
      Control
      Value 120
      Input Max 240
      Top_Text Speed
      Value_Format Text %d
      Bottom_Text km/h
      BackgroundImage Solution/Resources/Bitmaps/Points_BlueBmp
      ForegroundImage Solution/Resources/Bitmaps/Numbers_0-240Bmp
Check the Scene in the Player
  1. Save your work and start the Player to test the functionality of your configuration. To do this, please perform similar steps to the ones described in the GettingStartedControls Best Practice.
    • The Speed Gauge can be tested by manipulating Custom_Gauge_Speed's Value Property (The property is changed to 50 in the image below).
    • The RPM Gauge can be tested by manipulating Custom_Gauge_RPM's Value Property.
