Advanced Cluster Part 4
• Get into the Scene2D and make sure your scene is being updated actively
• If there is not the default group in Scene2D, then add a new group node, else click on the default group and reset its position by clicking at the circular arrow next to the “Position” property text
• Name the group as “Group_Content”
• Insert the “BackgroundBmp” (Solution->Resources->Bitmaps) to the group
• Place a Custom_Gauge into the group, name it as “Custom_Gauge_Speed”
• Set the position: X = 60, Y = 30
• Clone the “Custom_Gauge_Speed”, name it as “Custom_Gauge_RPM” and set its X position: X = 965
• Select the “Custom_Gauge_Speed” and go to its properties. Set these settings:
Input Max = 240, Value = 120, Top_Text = Speed, Value_Format Text = %d, Bottom_Text = km/h
• Set the BackgroundImage to “Points_BlueBmp”
• Set the ForegroundImage to “Numbers_0-240Bmp”
• The scene is ready. Now you can try to run it in the Player by selecting "Generate and Play" and pressing the play button in the top panel
• When the Player appears, you can manually change the accessible values for selected controls:
• The changes should be immediately reflected on the display:
