Advanced Cluster Part 2
In this part of the Advanced Cluster Best Practice the Custom_Gauge control will be extended with a ForegroundImage and a NeedleEffectImage and new images will be configured to change the control's appearance completely.
Restructuring Custom_Gauge Control
  1. In the Solution Explorer double-click the "Custom_Gauge"Custom_Gauge".
    • The control "Custom_Gauge"Custom_Gauge" will be opened in the Scene Editor, ready to be edited.
    • Scene Tree will display the tree of nodes the control is composed of.
  2. In the Scene Tree panel rename the "Group" node to "Group_Bitmaps"Group_Bitmaps".
    • In the Scene Tree panel the Group node has been renamed.
      Rename from Rename to
      Group Group_Bitmaps
  3. In the Scene Tree panel select the root node Custom_Gauge. In the Properties panel's [Layouter] section change the Layout type from "Overlay" to "None".
    • The Layout Type has been changed.
  4. In the Scene Tree panel cloneright-click on the "BackgroundImage" usingand choose [Clone...] from the context menu's [Clone...].menu. In the opening "Clone Item" dialog enter "ForegroundImage" as name.name and press [OK].
    • A clone of "BackgroundImage" has been created. Its name is "ForegroundImage". The Scene Tree now looks as in the image below.
  5. Let'
Exchanging Custom_Gauge Control's changeImages
In steps 1 - 3 of this section the Custom_Gauge new images for the ForegroundImage and BackgroundImage nodes will be configured. These steps need to be performed for the BackgroundImage node as well as for the Foreground Image node.
In steps 4 - 5 of this section the NeedleImage will be cloned and the images displayedof by BackgroundImageNeedleImage and ForegroundImage:NeedleEffectImage will be exchanged.
    In the Scene Tree panel select the image. In the right side of the Scene Tree click on the [Fusion...] button.
    • Fusion will be opened, displaying the Fusion diagram for the image.
    In the Fusion diagram change the ProvideImageProperty's image by clicking the magnifying glass icon to the property's right.
    • The [Choose Item] dialog will be displayed.
    In the [Choose Item] dialog choose the appropriate new image for BackgroundImage given in the table below and click [OK].
    • The images displayed by the BackgroundImage and ForegroundImage nodes have been changed.
    • When activating the Scene Editor the Custom_Gauge with new Foreground and Background image can be viewed. It should look like the image below.
      To switch to the Fusion diagram of the second image simply double click it in the Scene Tree panel.
      Node ProvideImageProperty'snew ProvideImageProperty image
      BackgroundImage Solution > Resources > Bitmaps > Points_Blue_RedBmp
      ForegroundImage Solution > Resources > Bitmaps > Numbers_0-8Bmp
    In the Scene Tree panel create a clone of the "NeedleImage" and name it "NeedleEffectImage".
    • A clone of "NeedleImage" has been created. Its name is "NeedleEffectImage". The Scene tree looks as in the image below.
      Please follow the order of the nodes in the scene tree to ensure their proper visibility.
    Let's change the images displayed by NeedleImage and NeedleEffectImage. This can be done similarly to above. Select the image, open Fusion and click on the magnifying glass next to the ProvideImageProperty's image property. Configure the images given in the table below.
    • The images displayed by the NeedleImage and NeedleEffectImage nodes have been changed.
    • When activating the Scene Editor the Custom_Gauge with new Needle and NeedleEffect image can be viewed. It should look like the image below (the needle is pointing to 3 o'clock).
      Node ProvideImageProperty's image
      NeedleImage Solution > Resources > Bitmaps > NeedleBmp
      NeedleEffectImage Solution > Resources > Bitmaps > Needle_LighterBmp
    Configuring
    the
    Gauge
    Needle's
    Rotation
    Behavior
    In
    the
    Scene
    Tree
    panel
    •select Clickthe NeedleImage.NeedleImage Renamenode. In the Scene Tree panel's right side rename the existing SetRotation behavior according to "SetRotation_Needle"
    • Click NeedleEffectImage. Rename the existingtable below. Repeat the same steps for the NeedleEffectImage node.
      The SetRotation behaviorbehaviors toof "SetRotation_Effect".NeedleImage Dragand NeedleEffectImage have been renamed.
      Node New Name of SetRotation Behavior NeedleImage SetRotation_Needle NeedleEffectImage SetRotation_Effect In the "SetRotation_Effect"Scene behaviorTree intopanel select the Custom_Gauge node. In the Scene Tree panel's right side select the InterpolateValue behavior. In the Properties panel's [Receivers] section press the [+] button in the top noderight (Custom_Gauge)corner.
      •This Click[+] Custom_Gauge.button Dragis marked in orange in the image of step 4.
        In the Properties panel's Receivers section you can see that a new line for a new Receiver is added for the InterpolateValue behavior.
        Press the magnifying glass icon next to the new Receivers 1 entry.
          The [Choose Item] dialog will be opened.
          Select the behavior SetRotation_Effect, which can be found under the path given below, and click [OK].
            The NeedleEffectImage's SetRotation_Effect behavioris referenced as one of the Receivers of the CustomGauge's InterpolateValue
            behavior Lastly,as dragyou can see in the imaged below.
            Set Rotation_Effect Path
            Custom_Gauge > Group_Bitmaps > NeedleEffectImage > SetRotation_Effect
            Configuring Effects and MapValue Behavior's Limits
              In the Scene Tree panel select the NeedleEffectImage node. In the Scene Tree panel's right side under [Behaviors] select "Blend Mode" and press Delete on your keyboard to delete this SetRotation_Effectbehavior.
                The behavior backBlend toMode thehas been deleted.
                While NeedleEffectImage is selected in the Scene Tree.Tree Youpanel will notice that an arrow sign will appear atselect the BitmapBrushColorBlend effect in the Scene Tree panel's right side ofand SetRotation_Effect.adjust Thanksits properties in the Properties panel according to this,the table below.
                  The BitmapBrushColorBlend effect is configured correctly. In the Scene Editor you can see that the NeedleEffectImage is not a white gradient anymore. You can rather perceive a slight change of color compared to the original BackgroundImage (see image below, the needle effectis willpointing beto rotated3 togethero'clock). with
                  Property
                  Value ColorBlendFactorSrc DestColor ColorBlendFactorDst SourceAlpha
                  In the needle.Scene
                  Tree
                  panel
                  select
                  the
                  Custom_Gauge
                  node.
                  In
                  the
                  Scene
                  •Tree Gopanel's right side select the MapValue behavior. In the Properties panel configure its properties according to the “NeedleEffectImage”table below.
                    The MapValue behavior's minimum and deletemaximum effectvalue "Blendhave Mode"been configured.
                    MapValue Properties
                    AtValue the "NeedleEffectImage" changeOutputMin the-128.50 settings of effectOutputMax “BitmapBrushColorBlend”:
                    ColorBlendFactorSrc128.50 = DestColor, ColorBlendFactorDst = SourceAlpha
                    • Go to the “Custom_Gauge” behavior “MapValue” and set these properties:
                    OutputMin = -128.5, OutputMax = 128.5
