Advanced Cluster Part 2
• We will start modifying the "Custom_Gauge" by double-clicking at it in the solution explorer
• In the Scene Tree, rename the “Group” to “Group_Bitmaps”
• Change the Layout Type of Custom_Gauge from Overlay to None
• Inside of the group, clone the “BackgroundImage” and name it “ForegroundImage”
• Change properties for BackgroundImage: in the behavior “ProvideImageProperty", change the picture from “GaugeSpeedBmp” to “Points_Blue_RedBmp”
• Change properties for ForegroundImage: in the behavior “ProvideImageProperty", change the picture from “GaugeSpeedBmp” to “Numbers_0-8Bmp”
• Clone the "NeedleImage" and name it "NeedleEffectImage"
• Change properties for NeedleImage: in the behavior "ProvideImageProperty", change the picture from "GaugeNeedleBmp" to "NeedleBmp"
• Change properties for NeedleEffectImage: in the behavior "ProvideImageProperty", change the picture from "GaugeNeedleBmp" to "Needle_LighterBmp"
• Press CTRL and moveSelect the "NeedleEffectImage" in the scene tree toand bedrag&drop placedit above the "NeedleImage" so it gets rendered before it. Also place the "ForegroundImage" on the bottom so it gets rendered last
• Click NeedleImage. Rename the existing SetRotation behavior to "SetRotation_Needle"
• Click NeedleEffectImage. Rename the existing SetRotation behavior to "SetRotation_Effect". Drag the "SetRotation_Effect" behavior into the top node (Custom_Gauge)
• Click Custom_Gauge. Drag the SetRotation_Effect behavior as one of the Receivers of InterpolateValue
• Lastly, drag this SetRotation_Effect behavior back to the NeedleEffectImage in the Scene Tree. You will notice that an arrow sign will appear at the right side of SetRotation_Effect. Thanks to this, the needle effect will be rotated together with the needle.
• Go to the “NeedleEffectImage” and delete effect "Blend Mode"
• At the "NeedleEffectImage" change the settings of effect “BitmapBrushColorBlend”:
ColorBlendFactorSrc = DestColor, ColorBlendFactorDst = SourceAlpha
• Go to the “Custom_Gauge” behavior “MapValue” and set these properties:
OutputMin = -128.5, OutputMax = 128.5
