Advanced Cluster Part 1
• Open the Scene Composer
• Open the Empty solution
• Save the solution to your custom destination
• Import the resource bitmaps (right click in the Solution Explorer -> Solution -> Resources -> Bitmaps)
• Click at the "Select Files" button
• Select all the images in the "<cgi-studio-root>/cgi_studio_content/Resources/AdvancedCustomGauge" folder
• Uncheck the "Create new folder for import" checkbox and press "OK"
• Now you should be able to see the imported bitmaps in the solution explorer (Solution -> Resources -> Bitmaps). By clicking at a single bitmap in the solution explorer, we can access its properties
• To be able to manipulate with the bitmaps easily, we can predefine their pivot point. Later we will use it as center of needle rotation and also for aligning the bitmaps together. Therefore we need to set the pivot to the middle of a gauge
• Click at the bitmaps and check the "Enable Pivot Hint" checkbox in its properties. Then set these numbers (in pixels) to set the pivot point to the bitmaps:
NeedleBmp: x = 17.5, y = 250
Needle_LighterBmp: x = 241, y = 245
Numbers_0-8Bmp: x = 325, y = 329
Numbers_0-240Bmp: x = 325, y = 329
Points_BlueBmp: x = 282, y = 282
Points_Blue_RedBmp: x = 282, y = 282
• Delete the Scene3D (right click in the Solution Explorer -> Solution -> Scenes -> Scene3D and press "delete")
• Open the Scene2D (double click in the Solution Explorer -> Solution -> Scenes -> Scene2D)
• Set the display size (find the "Render Targets" tab) to X = 1680 and Y = 720 pixels
• Enable the camera swapping. This will lead to refreshing the display after each time this scene is renderred.
• Select the Editor camera option
• Now you should be able to move and zoom the camera view. The yellow rectangle will show the scene part that will be displayed
• Go to Toolbox -> Controls -> Common and copy the gauge control (right click -> copy)
• Paste to the control folder in your solution (Solution Explorer -> Solution -> Controls)
• Rename the gauge to “Custom_Gauge”
