Play Animation
Start/Stop Animation
If toolbar does not have the animation icons described below, to desplay them please select [ View > Toolbars > Animation ] from the menu bar.
Start Animation
You can start an animation in one of the following three ways,
  • Select [ Animation ] > [ Start Animation ] from the Menu Bar.
  • Click the [ Start the playback of the selected animation ] icon in the Tool Bar (you can also pause the animation by clicking this icon during playback).
    If the Animation toolbar is not visible, it can be activated through the menu "View > Toolbar > Animation".
  • Click the [ Start the playback of the selected animation ] icon in the Animation Timeline panel (you can also pause the animation by clicking this icon during playback).
Stop Animation
As with the start the animation operation, the animation can be stopped in three ways that are Menu Bar/Toolbar/Animation Timeline panel.
Play from Animation List
Play Direction
Play directions "Forward" and "Reverse" are available in the Properties Panel of the animation.
Speed Factor
Configure the Speed Factor in the Properties panel of the animation.
Animation Fast Finish
To play the animation faster, you can press the "Fast Forward" icon on the Toolbar or Animation Timeline panel. The field near "Fast Forward" button allows the user to set the the value of forwarding (in milliseconds).
