Play Animation
Start/Stop Animation
If toolbar does not have the animation icons described below, to desplay them please select [ View > Toolbars > Animation ] from the menu bar.
Start Animation
You can start an animation in one of the following three ways,
Stop Animation
If theretoolbar isdoes nonot animation-relatedhave the animation icons on the toolbar described below,above, to desplay them please select [ View > Toolbars > Animation ] from the menu bar.
Play from Animation List
Play Direction
Play directions "Forward" and "Reverse" are available in the Properties Panel of the animation.
Speed Factor
Configure the Speed Factor in the Properties panel of the animation.
Animation Fast Finish
To play the animation faster, you can press the "Fast Forward" icon on the Toolbar or Animation Timeline panel. The field near "Fast Forward" button allows the user to set the the value of forwarding (in milliseconds).
