Play Animation
Start/Stop Animation
Start Animation
3通りの方法でアニメーションを開始することができます。You can start an animation in one of the following three ways,
  • Menu BarのSelect [ Animation ] > [ アニメーションを開始Start Animation ] を選択from the Menu Bar.
  • ToolClick Barのthe [ Start the playback of the selected animation ] アイコンをクリック(再生中に同アイコンをクリックすることでアニメーションを一時停止することもできます)icon in the Tool Bar (you can also pause the animation by clicking this icon during playback).
  • AnimationClick Timeline panelのthe [ Start the playback of the selected animation ] アイコンをクリック(再生中に同アイコンをクリックすることでアニメーションを一時停止することもできます)icon in the Animation Timeline panel (you can also pause the animation by clicking this icon during playback).
Stop Animation
アニメーションの開始と同様に、As with the start the animation operation, the animation can be stopped in three ways that are Menu Bar/Tool Bar/Toolbar/Animation Timeline panelの3通りの方法でアニメーションを停止することができます。panel.
Play from Animation List
Play Direction
Play directions "Forward" and "Reverse" are available in the Properties Panel of the animation.
Speed Factor
Configure the Speed Factor in the Properties panel of the animation.
Animation Fast Finish
To play the animation faster, you can press the "Fast Forward" icon on the Toolbar or Animation Timeline panel. The field near "Fast Forward" button allows the user to set the the value of forwarding (in miliseconds).
