Play Animation
Start/Stop Animation
Start an animation via menu "Animation" > "Start Animation" or toolbar item.
You can also pause the animation via toolbar item.
Stop an animation via menu "Animation" > "Stop Animation" or toolbar item.
Play from Animation List
Play Direction
Play directions "Forward" and "Reverse" are available in the Properties Panel of the animation.
Speed Factor
Configure the Speed Factor in the Properties panel of the animation.
Animation Fast Finish
To play the animation faster, you can press the "Fast Forward" Toolbar Item. The field near "Fast Forward" button allows the user to set the the value of forwarding (in miliseconds).
