Animation Groups
Create an Animation Group
Create a more complex animated sequence in a scene with Animation Groups. Multiple animations are grouped and can run simultaneously.
Create a new animation group using the menu item "New Animation Group" from the Animation menu.
Created animation groups are displayed in the Solution Explorer panel like that:
Edited an animation group in the Animation Design view, with the Animation Timeline Editor. Drag animations from the Solution Explorer and drop them to the AnimationGroup in the Animation Timeline Editor. Another possibility is to use the "Add to Animation Group" option which is available in the context menu of every existing animation.
It is possible to select and drag simultaneously many animations into an animation group. When doing this operation, the user will be asked through the "Drop Animations" dialog if an animation chain has to be created.
You can also add both animations and animation groups to a specific animation group.
The main animation group is considered as the "root" and the group included inside as the "node".
It is not possible to include an animation group into another group, if it contains same animations as the root group.
Control Animations
Control animations are displayed in "Control animations" category in the Animation combo box (in the toolbar).
In the Solution Explorer there are two available commands to add items to an animation group. Right-click on an animation group offers the following possibilities in the context menu. The name of these command are self-explanatory:
When adding animations to the selected Animation Group, "Choose Item" dialog also displays control animations, for each control. It may display also nested control animations that are made available.
The following types of animations can be included in an Animation Group:
- animations on nodes included in solution scenes;
- animations from folders;
- animations of controls which belong to at least one scene (if the control contains other controls, then the animations of the child control are also available).
It does not allow selection of : FBX animations, animations already included, groups containing already included animations, animations of controls which do not belong to any scene.
The functionality of adding animations to an animation group allows multiple selection of: animations & animation groups
After a control animation is added, it behaves like any animation node. It inherits the "Delay" property and the "StartType" property if applicable.
The StartType property is only available if the animation has a predecessor, that means, if the animation is a child of another animation.
The AnimationGroup panel displays the full name of the animations and short version of the control animations:
Animation Section in the Properties Panel
For animations specific properties, an Animation section is available directly after the General section in the Properties panel.
The Animation properties for a regular animation (inside an animation group) is organized as follows:
- Delay: If a component has a delay defined and its predecessor is started/finished, it will not be automatically started, but prepared for start.
- StartType: A component with a predecessor can be configured to start with its predecessor or after it is finished. This property is only available if a predecessor (parent animation) is defined (this means, if the animation is a child animation).
- Animation: displays the name of the node animation (read-only property).
The Animation properties for a control animation (inside an animation group) are similar to the one above. Other read-only properties are available:
- Control Animation: The template animation;
- Animated control node: The control node that is animated by this animation node;
- Chain. The template items for the animated control nodes, the nested control nodes and the control animations.
Simultaneous or Consecutive Animations
Animations inside an animation group, can be arranged hierarchically: An animation can be configured to be the "child" of another animation simply by dragging the "child" animation onto the "parent" animation in the Animation Timeline panel. The relation (child or parent) will be reflected by proper indeting of the animation titles in the Animation Timeline panel. A "parent" animation is the predecessor of its "child" animation.
Every animation that has a "parent" animation, has a property StartType in the Properties panel (Animation part).
The StartType property can be configured for animations with a predecessor, defining the animation to start simultaneously with its predecessor or after the predecessing animation is finished.
The possible values of StartType are
- WithPrevious: The animation will start simultaneously with the predecessing animation.
- AfterPrevious: The animation will start after the predecessing animation is done.
StartType Toggle Button Indicator
In the animation timeline in the left in the following picture, you can see that "Animation1" is the child animation of "PreceedingAnimation". In the Properties panel on the right, you can see the StartType property highlighted.
To easily toggle the StartType for the animation, the Animation Timeline provides a button, that also indicates the current configuration. It is highlighted in orange in the picture above.
WithPrevious
AfterPrevious
Limitations of Animation Groups
Compared to AnimationPlayer, AnimationGroupPlayer does not have the following functions
- Specify the start time of the animation and the length of the animation
- Loop playback
- Reverse playback
- Speedup animation(a new feature available in CGI-Studio 3.9 or later)
- Jump to a specific point
