Document usage
This section describes how to use this document (CGI Studio Documentation).
Structure of this document
This document consists of the following four levels.
| Shelves |
This is a large classification. It corresponds to the role of bookshelves in a library. |
| Books |
This is a middle classification within the large category. It corresponds to the role of books arranged in the bookshelf, which is a large classification. |
| Chapters | This is a small classification that bundles the Pages placed in the Books, a middle classification. |
| Pages |
This is an actual document is described. Pages are classfied according to its usage by Chapters/Books/Shelves. |
When this manual is launched, a list of Shelves is displayed, and from Shelves, you can navigate to Books and Chapters/Pages as child hierarchies to browse the desired document.
User Interface
| 1 | Search field |
You can search the entire document for keywords. See Keyword Search for more information. |
| 2 | Select button |
You can select the content view style from Shelves or Books. |
| 3 | API document button |
By clicking this button, a new window will open to display API documents. |
| 4 | Back/Forward |
Click this button to go backward or forward in the displayed content. See Document navigation for more information. |
| 5 | Contents search |
Performs a keyword search on the text currently displayed on the offline document screen. Search results are highlighted in yellow. See Contents search for more information. |
| 6 | Recent Views |
Shelves, Books, and Chapters/Pages that you have viewed in the past will be listed. See Recent Views for details. |
| 7 | Content display area |
Contents are displayed. When you navigate to a page, you will see the document. |
| 8 | Sort |
Items displayed in the contents display area can be sorted by any criteria. The sorting conditions can be selected from "Name", "Created Date", and "Updated Date". You can also switch the sort order from descending to ascending by clicking the up/down arrows on the right side of the pull-down menu. |
| 9 | Actions |
Switches the display style in the contents display area to List or Grid view. This section is displayed only when display Shelves or Books. |
Document navigation
Except in particular cases, Sleves is usually displayed. Navigate by clicking on the title of Books and Chapters/Pages to be viewed, in that order.
Home Key operation
When viewing a document, press the Home key to go to the beginning of the currently displayed page. This will make it easier to access Breadcrumb, Back/Forward buttons and the Search field.
Breadcrumb
When you move through the hierarchy, the path to the current display location is shown at the top of the content display area. To go back in the hierarchy, click on this path.
Recent Views
When you return to Shelves, your browsing history will be displayed on the left side of the screen, showing the books/chapters/pages you have moved to. By clicking anywhere in there, you can move to the target location. You can delete the entire browsing history by clicking the [ CLEAR ] button at the bottom of Recent Views.
Page Navigation/Book Navigation
On Pages view, Page Navigation/Book Navigation is displayed on the left side of the screen.
By moving the mouse cursor over the page body or Page Navigation/Book Navigation, the display can be scrolled up and down respectively.
Back/Foward
By clicking the "Back/Forward" button in the upper right corner of the screen, you can go back or forward through the content displayed on the screen based on your viewing history.
Keyword Search
You can search for keywords by entering any string of text in the search field at the top of the document and pressing the Enter key. Up to 10 search results will be displayed. If there are more than 10 results, click the [ MORE RESULTS ] button at the bottom of the search results screen to display them.
Contents search
Search for keywords in the displayed contents.
AfterAs enteringyou aenter keyword, presskeywords, the ENTERkeywords keyyou toentered highlightwill thebe keywordhighlighted in yellow (all text in the screen will be searched for). The highlighted search result can be moved by pressing the ENTER key. Press Ctrl+F to move to the content search field.
How to Download Video Data
Tutorial Videos chapter allows you to watch each tutorial video.
If you have issues with the video playback, you can download the video by clicking on the orange frame in the figure below and select "Download" from the menu that appears.
Feedback
At the bottom of each page is a feedback function. You can send us your comments directly about the content of the pages, such as the one below.
- The description was very clear.
- The description was not clear enough for me to understand the details of the feature or how to use it.
You can submit your feedback by following the steps below.
- At the bottom of the page, click the "Yes" or "No" button to the right of "Was this page helpful?
- The "Tell us more" area (shown in the yellow area below) will appear.
- In the text entry area, enter your opinion on whether or not you found the information useful.
- Click the "Submit Feedback" button at the bottom of the text entry area.
- Your feedback will be sent to Candera.
- The currently displayed feedback input area will disappear.
- If successful, the message "Thank you for your feedback" will be displayed.
- Otherwise, "Sorry, connection to the server timed out." will appear if it cannot connect to the server.
Callouts
In this document, statements that require special attention are indicated by the following two types.
Use for an information that should be conveyed incidentally in operations and configurations.
Use for an information that should be required an attention in operations and its configurations.
